там хорошо и понятно написано как от VxWOrks избавиться
Tip: The WRT54G-v5,v6 as well as the WRT54GS-v5,v6 devices run VxWorks. You
need to replace the VxWorks bootloader by a CFE first. It is easy:
- Grab a copy of http://www.bitsum.com/files/vximgtoolgui.zip and
run "vximgtoolgui.exe" (Windows) or "wine vximgtoolgui.exe" (Linux)
Write out a file vxkill.bin with the MAC adress of your WRT
- Grab http://www.bitsum.com/files/vxworks_prep_v03.zip and upload
the unzipped binary via Web UI to enter the "Management Console".
WRT54gs-v5/v6: http://www.bitsum.com/files/vxworks_prep_gs_v03.zip
- In the "Management Console" upload your customized vxkill.bin
- Upload a Freifunk TRX file via TFTP as ususal. Start meshing.
