MaDDoG Posted September 17, 2007 Posted September 17, 2007 Доброго времени суток. Есть 7204 которая является бордером, тестово на ней поднимается pptp и easy vpn. PPTP работает без проблем, Cisco VPN Client подключается, но ничего не работает, даже ип выданный клиенты с него не пингуется. Конфиг: c7204#sh runBuilding configuration... Current configuration : 17652 bytes ! upgrade fpd auto version 12.4 service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname c7204 ! boot-start-marker boot-end-marker ! logging userinfo no logging buffered enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx ! aaa new-model ! ! aaa authentication login default local aaa authentication login userlist group radius aaa authentication login vty local aaa authentication ppp default group radius aaa authorization network default group radius aaa authorization network grouplist local ! aaa session-id common ! resource policy ! clock timezone Vld 10 ip subnet-zero ip cef ! ! ! ! no ip domain lookup ip domain name xxxxx.ru ip rcmd rcp-enable ip rcmd rsh-enable ip rcmd remote-host user 172.17.0.x root enable ip rcmd remote-host user2 172.17.0.x root enable 8 ip rcmd remote-username user vpdn enable vpdn authen-before-forward vpdn authorize directed-request vpdn aaa attribute nas-ip-address vpdn-nas vpdn search-order domain dnis ! vpdn-group 1 ! Default PPTP VPDN group accept-dialin protocol pptp virtual-template 1 ! ! ! ! ! ! ! crypto isakmp policy 50 encr aes authentication pre-share group 2 ! crypto isakmp policy 100 encr 3des authentication pre-share group 2 ! crypto isakmp client configuration group cisco key cisco dns 193.34.x.x 193.34.x.x acl nas access-restrict GigabitEthernet0/1.1 save-password include-local-lan crypto isakmp profile vi virtual-template 2 ! ! crypto ipsec transform-set TSET esp-3des esp-sha-hmac ! crypto ipsec profile vi set isakmp-profile vi ! ! crypto dynamic-map TEST 10 set transform-set TSET ! crypto dynamic-map mode 1 set transform-set dessha ! crypto dynamic-map vladlink 1 set transform-set TSET reverse-route crypto dynamic-map cisco 10 set peer 172.17.0.15 ! ! crypto map VPN client authentication list userlist crypto map VPN isakmp authorization list grouplist crypto map VPN client configuration address respond crypto map VPN 10 ipsec-isakmp dynamic TEST ! crypto map mode 1 ipsec-isakmp dynamic mode ! crypto map vladlink 1 ipsec-isakmp dynamic cisco ! bridge irb ! interface Tunnel0 no ip address tunnel source GigabitEthernet0/1.2 tunnel destination 193.34.x.x tunnel mode ipsec ipv4 ! interface GigabitEthernet0/1 description To Catalyst gi 4/12 no ip address duplex auto speed auto media-type rj45 negotiation auto ! interface GigabitEthernet0/1.1 description Default LAN GW encapsulation dot1Q 10 ip address 172.17.0.5 255.255.255.0 secondary ip address 172.17.0.15 255.255.255.0 ip accounting output-packets ip nat inside ip virtual-reassembly ip policy route-map to_nat no snmp trap link-status crypto map VPN service-policy output bezlimit_lan ! interface GigabitEthernet0/1.2 description GW for Servers encapsulation dot1Q 14 ip address 193.34.x.1 255.255.255.240 secondary ip address 193.34.x.1 255.255.255.240 secondary ip address 193.34.x.1 255.255.255.240 no snmp trap link-status ! interface GigabitEthernet0/1.3 description Uplink TTK encapsulation dot1Q 20 ip address 217.150.x.x 255.255.255.252 ip accounting output-packets ip nat outside ip virtual-reassembly no snmp trap link-status ! ! interface FastEthernet0/2 no ip address duplex full speed auto no mop enabled ! interface GigabitEthernet0/2 no ip address duplex auto speed auto media-type rj45 negotiation auto ! interface GigabitEthernet0/3 no ip address shutdown duplex auto speed auto media-type rj45 negotiation auto ! interface Virtual-Template1 ip unnumbered GigabitEthernet0/1.1 autodetect encapsulation ppp no peer default ip address ppp encrypt mppe auto ppp authentication pap chap ms-chap ms-chap-v2 ! interface Virtual-Template2 type tunnel ip unnumbered GigabitEthernet0/1.2 tunnel mode ipsec ipv4 tunnel protection ipsec profile vi ! ! ip classless ip route 10.18.0.0 255.255.255.0 Null0 ip route 172.26.0.0 255.255.0.0 172.17.0.1 ip route 172.27.0.0 255.255.0.0 172.17.0.1 ip route 172.28.0.0 255.255.0.0 172.17.0.1 ip route 172.29.0.0 255.255.0.0 172.17.0.1 ip route 172.30.0.0 255.255.0.0 172.17.0.1 ip route 172.31.0.0 255.255.0.0 172.17.0.1 ip route 192.168.0.0 255.255.0.0 Null0 no ip http server no ip http secure-server ! ! ! radius-server attribute 32 include-in-access-req radius-server attribute 30 original-called-number radius-server attribute nas-port format d radius-server attribute 4 172.17.0.15 radius-server configure-nas radius-server host 172.17.0.8 auth-port 1812 acct-port 1813 key 7 044B041E0A33 radius-server vsa send cisco-nas-port radius-server vsa send accounting radius-server vsa send authentication ! control-plane ! bridge 1 protocol ieee bridge 1 route ip ! ! ! ! ! gatekeeper shutdown ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 0 4 password 7 XXXXXXXXXXXXXXXX ! ! end c7204# Вставить ник Quote
MaDDoG Posted September 19, 2007 Author Posted September 19, 2007 Спасибо всем кто посмотрел топик :) Вообщем вроде все настроил, есдинственно не совсем понимаю как Vpn клиенту отдать маршруты для Local Routes Table. Если на группу cisco повесить acl, то маршруты отдаются в secured routes, соответственно матрика на локальном маршруте ниже чем на внешем и все пытается уйти в локалку. Вставить ник Quote
kostas Posted November 18, 2009 Posted November 18, 2009 Спасибо всем кто посмотрел топик :) Вообщем вроде все настроил, есдинственно не совсем понимаю как Vpn клиенту отдать маршруты для Local Routes Table. Если на группу cisco повесить acl, то маршруты отдаются в secured routes, соответственно матрика на локальном маршруте ниже чем на внешем и все пытается уйти в локалку. Таже фигня - тунель поднимается, но через него ничего не ходит. С циски даже IP клиента не пропинговать. В чем хоть дело было, может помните? :) Вставить ник Quote
