Имеется 5350 и Панас соедененные по E1. Звонки с АТС на циску проходят голос ходит отлично
а вот в обратную сторону с 5350 на АТС проходит только вызов и дальше тишина полная. где грабли ?
Лог нерабочего направления.
*Oct 4 11:56:00: ISDN Se3/1:15 Q931: Applying typeplan for sw-type 0x16 is 0x0
0x0, Calling num 387789
0x0, Called num 237
*Oct 4 11:56:00: ISDN Se3/1:15 Q931: TX -> SETUP pd = 8 callref = 0x008D
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Calling Party Number i = 0x80, '387789'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '237'
High Layer Compat i = 0x9181
*Oct 4 11:56:00: ISDN Se3/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x808D
*Oct 4 11:56:00: ISDN Se3/1:15 Q931: TX -> STATUS pd = 8 callref = 0x008D
Cause i = 0x80E018 - Mandatory information element missing
Call State i = 0x01
*Oct 4 11:56:00: ISDN Se3/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x808D
Call State i = 0x01
*Oct 4 11:56:02: ISDN Se3/1:15 Q931: RX <- CONNECT pd = 8 callref = 0x808D
Progress Ind i = 0x8182 - Destination address is non-ISDN
Connected Number i = 'I', 0x80, '237'
*Oct 4 11:56:02: ISDN Se3/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x008D
Cause i = 0x82E0 - Mandatory information element missing
*Oct 4 11:56:14: ISDN Se3/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x808D
Cause i = 0x8190 - Normal call clearing
*Oct 4 11:56:14: ISDN Se3/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x008D
*Oct 4 11:56:14: ISDN Se3/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x808
D
Лог рабочего направления
*Oct 4 12:01:04: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8 callref = 0x002C
Standard = CCITT
Calling Party Number i = 0xC1, '387789'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0x81, '9966504'
Plan:ISDN, Type:Unknown
*Oct 4 12:01:04: ISDN Se3/1:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0x802C
*Oct 4 12:01:19: ISDN Se3/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x802C
*Oct 4 12:01:19: ISDN Se3/1:15 Q931: TX -> ALERTING pd = 8 callref = 0x802C
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Oct 4 12:01:26: ISDN Se3/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x802C
*Oct 4 12:01:26: ISDN Se3/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x002C
*Oct 4 12:01:30: ISDN Se3/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x802C
Cause i = 0x8290 - Normal call clearing
*Oct 4 12:01:34: ISDN Se3/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x002C
*Oct 4 12:01:34: ISDN Se3/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x802
C
Должна быть не тишина а отбой. Numbering plan на цыске попробуйте прописать. Из лога только видно что панасоник отсылает disconnect. Надо на нем логи еще смотреть.
Необходимо видеть логи с панасоника, почему он отсылает disconnect. По логам только видно что соединение установилось, 12 секунд что-то происходило после чего панас дал отбой.
  • 2 weeks later...
сталкивался с подобной проблемой но только у меня циска подключена к алкателю, выделили дополнительно несколько каналов DSP ресурсов и поправили диал пиры прописав жестко на это направление кодек
