Канал на Breezee от Alvarion, более 1 мегабита не поднимается...
Расстояние 14 км, сигнал 69 dbi, 6 ризок горит.
Как не бился, канал получается ровный мегабит, пинг по каналу 9-14 мс.
Как попробывать поднять скорость?
Конфиг:
Current Values:
IP Address : 010.084.078.021
Subnet Mask : 255.255.255.000
Default Gateway Address : 010.084.078.001
Run Time Values:
DHCP Options : Disable
Access to DHCP : From Wlan Only
ESSID : ESSID2
Run Time ESSID : ESSID2
Maximum Data Rate : 2 Mbps
Acknowledge Delay Limit : Low
Hopping Shift : 0
Frequency Offset : 18
Decrement Hopping Frequencies : Disable
Hopping Band : Single Channel 3.5 GHz (3.5a1-1.75/2)
Transmit Power Level : 15 Units
Runtime Transmit Power Level : 15 Units
Current Receive Attenuation : 0 dB
Automatic Transmit Power Control Parameters:
ATPC Option : Enabled
ATPC Maximum Last Level Time After Reset : 30 [sec]
ATPC Maximum Last Level Time After Synchronization Loss
: 120 [sec]
ACSE Option : Disable
ACSE Number of Retransmissions for data : 6
Best AU Support : Disable
Max. Number Of Scan Attempts : 20
Preferred AU MAC Address : Not Set
Scanning Mode : Active
Wireless Trap Threshold : 84
Send Roaming SNAP : Disable
AU Transmission Rate Control : Enable
Access to Network Management(SNMP/Telnet/TFTP/ICMP)
: From Both Ethernet&Wlan
Management IP Filtering : Disable
Network Management IP Addresses
1 - 000.000.000.000
2 - 000.000.000.000
3 - 000.000.000.000
TRAP Sending : Disable
Send SU Associated Trap : Enable Traps Sending
Send SU Wireless Quality Trap : Enable Traps Sending
Send Parameter Changed Trap : Enable Traps Sending
Send Power Up From Reset Trap : Disable Traps Sending
Send Monitor Status Trap : Enable Traps Sending
Send Cold/Warm Start Trap : Disable Traps Sending
IP address Community
1 - 000.000.000.000, public
2 - 000.000.000.000, public
3 - 000.000.000.000, public
VLAN ID - Data : 121
VLAN ID - Management : 118
VLAN Link Type : Access
VLAN Priority - Data : 0
VLAN Priority - Management : 0
VLAN Priority Threshold : 4
VLAN Forwarding Support : Disable
VLAN Forwarding List :
ToS Precedence Threshold : 3
Bridge Aging Time : 1800 (sec)
Ethernet Broadcast Filter : Disable
DHCP Broadcast Override Filter : Disable
PPPoE Broadcast Override Filter : Disable
ARP Broadcast Override Filter : Enable
Ethernet Port : Enable
RTS Threshold : 60
Number of Retransmissions : 1
Number of Dwells to Retransmit : 2
Number of Retransmissions to Decrease Rate : 0
Min. Contention Window : 31
Dwell Time : 128 Kilo-microsecond
Carrier Sense Level : -90 [dBm]
Carrier To Interference Difference : 8 [dB]
Noise Floor Level : -112 [dBm]
Multi-Rate Support : Enabled
Multi-Rate Decision Window Size : 12
Number of Failures in Multi-Rate Decision Window : 8
User Filtering : Disable
1 - 000.000.000.000 Mask:255.255.255.255 Range: 0
2 - 000.000.000.000 Mask:255.255.255.255 Range: 0
3 - 000.000.000.000 Mask:255.255.255.255 Range: 0
4 - 000.000.000.000 Mask:255.255.255.255 Range: 0
5 - 000.000.000.000 Mask:255.255.255.255 Range: 0
6 - 000.000.000.000 Mask:255.255.255.255 Range: 0
7 - 000.000.000.000 Mask:255.255.255.255 Range: 0
8 - 000.000.000.000 Mask:255.255.255.255 Range: 0
The Range Includes Base Address!!!
MIR/CIR : Disable
RunTime MIR/CIR : Disable
MIR AU to SU in KBit : 512
MIR SU to AU in KBit : 512
CIR AU to SU in KBit : 128
CIR SU to AU in KBit : 128
Maximum Delay : 5000
Maximum Burst Duration : 5
User Name : 0020D6D4719A
User Password : RadiusPassword1
Shared Secret : RadiusSecret12345678
Authentication Option : Disable
RADIUS Server Authentication IP Address : 000.000.000.000
RADIUS Server Authentication Port : 1812
RADIUS Authentication status : Idle
Accounting Option : Disable
RADIUS Server Accounting IP Address : 000.000.000.000
RADIUS Server Accounting Port : 1813
Accounting Interval : 90
Authentication : Open System
Default WEP Key : 1
WEP key #1 : 0000000000
WEP key #2 : 0000000000
WEP key #3 : 0000000000
WEP key #4 : 0000000000
Сообшение типа.
Моя Ямаха не едет больше 40 км час.
Как я не бился.
Под брендом бризз есть более десятка изделий причем разительно разных по назначению радиодиапозону и тд.
Breeze Access SU3500 - 3.5 GHz
Судя то что ты пишешь SU.
Ты клиент.
И базу не контролируешь?
Тогда два варианта.
По вероятности
1 Зарезана так скорость на базе.
2 Много помех и изделие автоматом перешло на помехозашишеную модуляцию которая и дает 1 мегабит полезной ппропускной способности.
Да , могу просить перенастроить базу как нужно. Скорость на базе не зажата.
Вообщем больше я понял не выжить, крутить нечего так сказать...
ну на 14 км лучше изделие с внешней антеной использовать
и на клиенте практичеси никаких настроек и нет
только ссид настроить да логи посмотреть
У вас Maximum Data Rate : 2 Mbps. Это никак не поменять на базе или на клиенте?
эта позиция практически ни на что не влияет
она просто говорит с какой именнно скорости начинать АВТОПОДБОР скорости при включении .
Тоесть если поставить 100 это повлияет только на то что линк будет подниматся какоето время дольше.
Используется внешняя антенна с ридиоблоком панельная.
Видимость прямая, клиент и база на возвышенности.
тоесть у тебя встроеная антенна.А они если мне паямть не изменяет рекомедуются километров до 10.
А есть радиоблоки с разьемом под антену.
тебе наверное нужна более узко направленая.Не обязательно с большим усилением.
Других типов антен на сайте Алвариона нет.
Антенна представляет из себя панель с металлическим радиатором сзади.
Туда прикручивается кабель и идет на SUшку. На самой антенне есть риски сигнала.
Поднимается 6-ть из 7-ит.
Поискать другой тип антенны?
Да, на сушке и зажал до 2-х мегабит, сколько не делаю, а скорость всегда 1,2-1,4 Мбит/сек - проверялась иперфом.
Уточните у владельца базы какую модуляцию они используют.
Вот таблица для 3500:
Модуляция/
кодирование
Битовая
скорость
Чувствительность
[dBm]
Битовая
скорость
Чувствительность
[dBm]
BFSK 1/2
1.41 Мбит/с
-100.0
0.71 Мбит/с
-103.0
BFSK 3/4
2.12 Мбит/с
-98.0
1.06 Мбит/с
-101.0
QPSK 1/2
2.82 Мбит/с
-97.0
1.41 Мбит/с
-100.0
QPSK 3/4
4.23 Мбит/с
-94.0
2.12 Мбит/с
-97.0
QAM16 1/2
5.64 Мбит/с
-91.0
2.82 Мбит/с
-94.0
QAM16 3/4
8.47 Мбит/с
-88.0
4.24 Мбит/с
-91.0
QAM64 2/3
11.29 Мбит/с
-83.0
5.65 Мбит/с
-86.0
QAM64 3/4
12.71 Мбит/с
-82.0
6.35 Мбит/с
-85.0
Оригинал http://64.233.183.104/search?q=cache:4G-5N...;cd=6&gl=ru
Edited by adron2
Xa
так 2 мегабита это в эфире.
Вот ты кекус.На интерфейсе естественно меньше.
1.2-1.4 это норма.
baalbes, а если до трешки (Mbit/s) на железках поднять, 1,2-1,4 те же получатся, или немногим скорость будет можно поднять?
Edited by Кашмир
пробуй
вообше до 30 работало.(На VL конечно, не как у тебя у тебя можно 2,6-2.8 получить в идеальных условиях)
Сильно зависит от качества линка.У тебя и растояние большое и антена штатная.
Edited by baalbes
