shmit Posted July 22, 2007 Posted July 22, 2007 точка приказала долго жить, подключил к ней jtag вроди работает но неполучается ничего на нее зашить, может кто-то уже сталкивался с такой проблемой? вот что выдает jtag jtag> include athsx Initializing Xilinx DLC5 JTAG Parallel Cable III on parallel port at 0x378 IR length: 5 Chain length: 1 Device Id: 00000000000000000000000000000001 Manufacturer: Atheros Part: ar2312 Stepping: 1 Filename: /usr/local/share/jtag/atheros/ar2312/ar2312 ImpCode=01000000010000000100000000000000 EJTAG version: 2.6 EJTAG Implementation flags: R4k ASID_8 NoDMA MIPS32 dev ID=00c8 man ID=001f Found Atmel AT49xV322x flash, size = 4194304 bytes. Query identification string: Primary Algorithm Command Set and Control Interface ID Code: 0x0002 (AM /Fujitsu Standard Command Set) Alternate Algorithm Command Set and Control Interface ID Code: 0x0000 ( ull) Query system interface information: Vcc Logic Supply Minimum Write/Erase or Write voltage: 0 mV Vcc Logic Supply Maximum Write/Erase or Write voltage: 0 mV Vpp [Programming] Supply Minimum Write/Erase voltage: 0 mV Vpp [Programming] Supply Maximum Write/Erase voltage: 0 mV Typical timeout per single byte/word program: 0 us Typical timeout for maximum-size multi-byte program: 0 us Typical timeout per individual block erase: 0 ms Typical timeout for full chip erase: 0 ms Maximum timeout for byte/word program: 0 us Maximum timeout for multi-byte program: 0 us Maximum timeout per individual block erase: 0 ms Maximum timeout for chip erase: 0 ms Device geometry definition: Device Size: 4194304 B (4096 KiB, 4 MiB) Flash Device Interface Code description: 0x0001 (x16) Maximum number of bytes in multi-byte program: 0 Number of Erase Block Regions within device: 2 Erase Block Region Information: Region 0: Erase Block Size: 8192 B (8 KiB) Number of Erase Blocks: 8 Region 1: Erase Block Size: 65536 B (64 KiB) Number of Erase Blocks: 63 No. Manufacturer Part Stepping Instruction Register ------------------------------------------------------------------------------- ------------- 0 Atheros ar2312 1 EJTAG_DATA EJDATA Active bus: *0: EJTAG compatible bus driver via PrAcc (JTAG part No. 0) start: 0x00000000, length: 0x20000000, data width: 8 bit start: 0x20000000, length: 0x20000000, data width: 16 bit start: 0x40000000, length: 0x20000000, data width: 32 bit jtag> flashmem 0x1fc00000 bootloader.bin program blocks: Chip: AMD Flash Manufacturer: Atmel Chip: AT49BV322A Protected: 0090 flash_unlock_block 0x1FC00000 IGNORE block 0 unlocked flash_erase_block 0x1FC00000 ................................................................................ ................................................................................ ........................................flash_erase_block 0x1FC00000 FAILED erasing block 0 to program 8192 bytes, status: 99 addr: 0x1FC00000 и так далее, сообщения вида flash_erase_block 0xXXXXXXXX FAILED. поставльте на правильный путь! Вставить ник Quote
shmit Posted July 22, 2007 Author Posted July 22, 2007 аналогичная ситуация описывается в http://vbm.lan23.ru/books/JTAG_dwl_2100ap.pdf но из-за незнания итальянкого языка я так ничего и непонял, promt выдал бредни сумашедшего ;) Вставить ник Quote
tchern Posted July 23, 2007 Posted July 23, 2007 Если вы пользуетесь jtag-brecis-ok В файле jtag-brecis-ok/libbrux/flash/AMD.c замените if (amdstatus( bus, adr, 0xffff )) { printf( "flash_erase_block 0x%08X DONE\n", adr ); amd_flash_read_array( cfi_array ); /* AMD reset */ return 0; на if (amdstatus( bus, adr, 0xff )) { printf( "flash_erase_block 0x%08X DONE\n", adr ); amd_flash_read_array( cfi_array ); /* AMD reset */ return 0; потому что вы стираете в однобайтном режиме но в принципе все и так работает хотя и ругается Вставить ник Quote
shmit Posted July 23, 2007 Author Posted July 23, 2007 (edited) Если вы пользуетесь jtag-brecis-ok В файле jtag-brecis-ok/libbrux/flash/AMD.c замените if (amdstatus( bus, adr, 0xffff )) { printf( "flash_erase_block 0x%08X DONE\n", adr ); amd_flash_read_array( cfi_array ); /* AMD reset */ return 0; на if (amdstatus( bus, adr, 0xff )) { printf( "flash_erase_block 0x%08X DONE\n", adr ); amd_flash_read_array( cfi_array ); /* AMD reset */ return 0; потому что вы стираете в однобайтном режиме но в принципе все и так работает хотя и ругается имено его и использую но он у меня нехочет собираться $ make make all-recursive make[1]: Entering directory `/tmp/jtag-brecis-ok' Making all in libbrux make[2]: Entering directory `/tmp/jtag-brecis-ok/libbrux' make all-recursive make[3]: Entering directory `/tmp/jtag-brecis-ok/libbrux' Making all in po make[4]: Entering directory `/tmp/jtag-brecis-ok/libbrux/po' make libbrux.pot-update make[5]: Entering directory `/tmp/jtag-brecis-ok/libbrux/po' /usr/bin/xgettext --default-domain=libbrux --directory=.. \ --add-comments=TRANSLATORS: --keyword=_ --keyword=N_ \ --files-from=./POTFILES.in \ --copyright-holder='ETC s.r.o.' \ --msgid-bugs-address='marcel@telka.sk' test ! -f libbrux.po || { \ if test -f ./libbrux.pot; then \ sed -f remove-potcdate.sed < ./libbrux.pot > libbrux.1po && \ sed -f remove-potcdate.sed < libbrux.po > libbrux.2po && \ if cmp libbrux.1po libbrux.2po >/dev/null 2>&1; then \ rm -f libbrux.1po libbrux.2po libbrux.po; \ else \ rm -f libbrux.1po libbrux.2po ./libbrux.pot && \ mv libbrux.po ./libbrux.pot; \ fi; \ else \ mv libbrux.po ./libbrux.pot; \ fi; \ } make[5]: Leaving directory `/tmp/jtag-brecis-ok/libbrux/po' test -z "" || make touch stamp-po make[4]: Leaving directory `/tmp/jtag-brecis-ok/libbrux/po' make[4]: Entering directory `/tmp/jtag-brecis-ok/libbrux' if gcc -DHAVE_CONFIG_H -I. -I. -I. -I/usr/local/include/openwince -I/usr/local /include/openwince/device -I/usr/local/include/openwince/arm -I./../include -g -O2 -Wall -MT cmd_detectflash.o -MD -MP -MF ".deps/cmd_detectflash.Tpo" -c -o cm d_detectflash.o `test -f 'cmd/cmd_detectflash.c' || echo './'`cmd/cmd_detectflas h.c; \ then mv -f ".deps/cmd_detectflash.Tpo" ".deps/cmd_detectflash.Po"; else rm -f ".deps/cmd_detectflash.Tpo"; exit 1; fi cmd/cmd_detectflash.c: In function `cmd_detectflash_run': cmd/cmd_detectflash.c:49: warning: passing arg 2 of `cmd_get_number' from incomp atible pointer type cmd/cmd_detectflash.c:52: error: too many arguments to function `detectflash' make[4]: *** [cmd_detectflash.o] Error 1 make[4]: Leaving directory `/tmp/jtag-brecis-ok/libbrux' make[3]: *** [all-recursive] Error 1 make[3]: Leaving directory `/tmp/jtag-brecis-ok/libbrux' make[2]: *** [all] Error 2 make[2]: Leaving directory `/tmp/jtag-brecis-ok/libbrux' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/tmp/jtag-brecis-ok' make: *** [all] Error 2 root@shmit /tmp/jtag-brecis-ok $ может выложите собраный с вашим патчем? Edited July 23, 2007 by shmit Вставить ник Quote
tchern Posted July 23, 2007 Posted July 23, 2007 http://wifitst2007.narod.ru/jtag_bin.zip Вставить ник Quote
shmit Posted July 23, 2007 Author Posted July 23, 2007 (edited) собрал я эту штуку с патченым jtag-brecis-ok/libbrux/flash/AMD.c на под cigwin(под freebsd несобралась а больше ничего нету) ситуация такая jtag> flashmem 0x1fc00000 redboot.bin program blocks: Chip: AMD Flash Manufacturer: Atmel Chip: AT49BV322A Protected: 0090 flash_unlock_block 0x1FC00000 IGNORE block 0 unlocked flash_erase_block 0x1FC00000 ................................................................................ ................................................................................ ........................................flash_erase_block 0x1FC00000 FAILED erasing block 0 to program 8192 bytes, status: 99 ejtag.c(132) Reset occurred, ctrl=11111111111111111100000000001000 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ................................................................................ ................................................................................ ........................................ flash error jtag> Edited July 23, 2007 by shmit Вставить ник Quote
shmit Posted July 23, 2007 Author Posted July 23, 2007 заметил что ругань идет кадрые 2 тысячи сначала 0x1FC00000 потом 0x1FC02000 итд Вставить ник Quote
tchern Posted July 23, 2007 Posted July 23, 2007 goblin# jtag JTAG Tools 0.6-cvs-20051228 Copyright © 2002, 2003 ETC s.r.o. JTAG Tools is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. There is absolutely no warranty for JTAG Tools. Warning: JTAG Tools may damage your hardware! Type "quit" to exit! Type "help" for help. jtag> cable parallel 0x378 WIGGLER Initializing Macraigor Wiggler JTAG Cable on parallel port at 0x378 jtag> detect IR length: 5 Chain length: 1 Device Id: 00000000000000000000000000000001 Unknown manufacturer! chain.c(110) Part 0 without active instruction chain.c(133) Part 0 without active instruction chain.c(110) Part 0 without active instruction jtag> include atheros/ar2312/ar2312 jtag> poke 0x58400000 0x000e3ce1 ImpCode=01000000010000000100000000000000 EJTAG version: 2.6 EJTAG Implementation flags: R4k ASID_8 NoDMA MIPS32 jtag> detectflash 0x1fc00000 dev ID=0049 man ID=0001 Using CFI flash chip detection, not jedec Query identification string: Primary Algorithm Command Set and Control Interface ID Code: 0x0002 (AMD/Fujitsu Standard Command Set) Alternate Algorithm Command Set and Control Interface ID Code: 0x0000 (null) Query system interface information: Vcc Logic Supply Minimum Write/Erase or Write voltage: 2700 mV Vcc Logic Supply Maximum Write/Erase or Write voltage: 3600 mV Vpp [Programming] Supply Minimum Write/Erase voltage: 0 mV Vpp [Programming] Supply Maximum Write/Erase voltage: 0 mV Typical timeout per single byte/word program: 16 us Typical timeout for maximum-size multi-byte program: 0 us Typical timeout per individual block erase: 1024 ms Typical timeout for full chip erase: 0 ms Maximum timeout for byte/word program: 512 us Maximum timeout for multi-byte program: 0 us Maximum timeout per individual block erase: 16384 ms Maximum timeout for chip erase: 0 ms Device geometry definition: Device Size: 2097152 B (2048 KiB, 2 MiB) Flash Device Interface Code description: 0x0002 (x8/x16) Maximum number of bytes in multi-byte program: 1 Number of Erase Block Regions within device: 4 Erase Block Region Information: Region 0: Erase Block Size: 16384 B (16 KiB) Number of Erase Blocks: 1 Region 1: Erase Block Size: 8192 B (8 KiB) Number of Erase Blocks: 2 Region 2: Erase Block Size: 32768 B (32 KiB) Number of Erase Blocks: 1 Region 3: Erase Block Size: 65536 B (64 KiB) Number of Erase Blocks: 31 jtag> flashmem 0x1fc00000 2100.boot program blocks: Chip: AMD Flash Manufacturer: AMD Chip: AM29LV160DB Protected: 0000 flash_unlock_block 0x1FC00000 IGNORE block 0 unlocked flash_erase_block 0x1FC00000 ............................................................................flas h_erase_block 0x1FC00000 DONE erasing block 0 to program 16384 bytes, status: 0 flash_unlock_block 0x1FC04000 IGNORE block 1 unlocked flash_erase_block 0x1FC04000 ..............................................................................fl ash_erase_block 0x1FC04000 DONE erasing block 1 to program 8192 bytes, status: 0 ^Cdr: 0x1FC04CC0 goblin# работает и во freebsd собрано под debian Вставить ник Quote
shmit Posted July 24, 2007 Author Posted July 24, 2007 (edited) наконец мне удалось прошить точку через jtag, несмотря на вылетающие ошибки ;) чтобы зашить bootloader у меня шуло часа 3, страшно падумать сколько будит шиться вся флэшка в 4 мегабайта! может можно как-то побыстрее? сейчас буду пробывать зашить redboot ;) Edited July 24, 2007 by shmit Вставить ник Quote
yKpon Posted December 8, 2007 Posted December 8, 2007 (edited) http://forum.nag.ru/forum/index.php?showto...39798&st=20 Edited December 11, 2007 by yKpon Вставить ник Quote
