С АТС SI-2000 приходит поток Е1, сигнализация DSS1, втыкается в VWIC-2MFT-E1-DI, который в свою очередь стоит в модуле NM-HDV
вопрос: Как пробросить таймслоты с 1 по 25 на второй порт Е1 (там модемный пул Ascend MAX6000), а с 26 по 31 использовать как voice-port ?
Тоесть кусок потока с одним номером как диалап, второй кусок потока с другим номером как voice
Router#sh ver
Cisco Internetwork Operating System Software
IOS (tm) 3600 Software (C3640-IK9O3S-M), Version 12.2(34a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Tue 02-May-06 12:32 by pwade
Image text-base: 0x60008930, data-base: 0x612E0000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
C3640-ATS uptime is 2 weeks, 14 hours, 57 minutes
System returned to ROM by power-on
System restarted at 01:59:14 YEKT Fri Jun 1 2007
System image file is "flash:c3640-ik9o3s-mz.122-34a.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco 3640 (R4700) processor (revision 0x00) with 59392K/6144K bytes of memory.
Processor board ID 10524925
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
2 Channelized E1/PRI port(s)
4 Voice FXO interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Спасибо!
