Возможно-ли на данном устройстве перебросить часть таймслотов с одного порта Е1 на другой порт Е1 для передачи на другое устройство ?
Спасибо!
Нашёл, кому интересно
http://www.interprojekt.pl/doc/ras/max800-...fg/confgwan.htm
You can set Line 1 and Line 2 to trunk service (indicating a standard T1 interface with signaling information) or disabled. For Line 2, you can also specify D&I (Drop-and-Insert) service. Drop-and-Insert on Line 2 specifies that some of Line 1's channels transparently pass over to Line 2. A device (such as a PBX) connected to Line 2 assumes that it is connected to the WAN switch and is not aware that the channels actually pass through the MAX before going to the WAN.
