Доброго времени суток, коллеги!
Впервые столкнулся с dhcp snooping , видимо что-то недопонимаю. Вот такая схема:
dhcp_server - g1/7(Catalyst 4503)g1/9 - DSLAM
часть конфига каталиста:
ip dhcp snooping vlan 99,444,555
ip dhcp snooping information option allow-untrusted
no ip dhcp snooping information option
ip dhcp snooping database tftp://tftp_server/dhcp_snooping.txt
ip dhcp snooping database timeout 500
no ip dhcp snooping verify mac-address
ip dhcp snooping
interface GigabitEthernet1/7
description _dhcp-server_
switchport access vlan 99
switchport mode access
ip dhcp snooping trust
interface GigabitEthernet1/9
description _DSLAM_
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 555,4000
switchport mode trunk
switchport nonegotiate
switchport block multicast
switchport block unicast
storm-control broadcast level 5.00
storm-control action trap
no cdp enable
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
ip verify source vlan dhcp-snooping
ip dhcp snooping limit rate 100
interface Vlan99
description _dhcp-server-net_
ip address 192.168.1.254 255.255.255.0
interface Vlan555
description _DSLAM_
ip address 10.10.7.254 255.255.255.0
ip helper-address 192.168.1.1
no ip redirects
no ip unreachables
c4503#sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
99,444,555
Insertion of option 82 is disabled
Option 82 on untrusted port is allowed
Verification of hwaddr field is disabled
Interface Trusted Rate limit (pps)
GigabitEthernet1/7 yes unlimited
GigabitEthernet1/9 no 100
GigabitEthernet1/16 no 100
Пакеты до DHCP сервера не доходят. Включил отладку
на каталисте, вот что имею:
Apr 24 11:06:52 MSK: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Gi1/9, MAC da: ffff.ffff.ffff, MAC sa: 0080.48df.4358, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0080.48df.4358
Apr 24 11:06:52 MSK: DHCP_SNOOPING_SW: lookup packet destination port failed to retrieve source interface idb, mac: 0080.48df.4358, mat entry type: 1, port cookie: 413559912
Сдется мне, что в данном случае dhcp пакеты на vlan интерфейсе просто не обрабатываются. Но хотелось бы услышать мнение более опытных.
Заранее благодарен.
  • 3 weeks later...
А влан DHCP сервера активен?
Размеется. Более того, я несколько менял схему. Отключал relay и прямо в этот vlan втыкал dhcp сервер, порт с dhcp сервером прописывал как trusted. Результат тот же самый.
Edited by Andrey Andruschenko
А DSLAM не умеет вставлять opt 82?
Если умеет, то на eth должно быть ip dhcp snooping trust, убрать snooping rate limit.
Вот это не понятно зачем:
DSLAM opt82 как раз умеет
Это чтобы пакеты с opt82, которую вставляет DSLAM не резались на каталисте.
Насчет убрать rate-limit невижу связи... На каком именно eth должно быть trust? Если на том, что смотрит в DSLAM, то тут вы неправы.
Я все-таки доверяю своим свичам/dslam, на транковых портах у меня стоит trust. Все работает.
На агрегирующем свиче можно сделать по такой схеме...
Btw если rate limit будет превышен, интерфейс перейдет в error-disable. Оно вам надо? Транковые порты класть.
Edited by kuru
Да я вообщем тоже доверяю... Недоверяю клиентам :) Хотя DSLAM'ы и фильтруют всякие попытки со стороны клиента вставить opt82 и прочее. Но все же.
trust я возможно и пробовал ставить, сейчас уже всех телодвижений не упомню, но будет возможно - проверю этот вариант, хотя imho дело не в этом. Насчет errdisable незнал, в документации об этом не сказано(или я был не внимателен), но ставить rate-limit настойчиво рекомендуют в качестве защиты от DoS на DHCP.
by default:
mskswic73#sh errdisable detect
ErrDisable Reason Detection status
udld Enabled
bpduguard Enabled
security-violatio Enabled
channel-misconfig Enabled
psecure-violation Enabled
vmps Enabled
loopback Enabled
unicast-flood Enabled
pagp-flap Enabled
dtp-flap Enabled
link-flap Enabled
sfp-config-mismat Enabled
gbic-invalid Enabled
dhcp-rate-limit Enabled
storm-control Enabled
community-limit Enabled
invalid-policy Enabled
mskswic73#
