Пытаюсь запустить Мултикаст поток 224.1.1.1.
маршрутизатор cisco 3662.
конфиг:
ip multicast-routing
interface FastEthernet0/1.21
encapsulation dot1Q 21
ip address ххх.ххх.80.254 255.255.255.0
ip helper-address ххх.ххх.146.108
ip flow ingress
ip flow egress
ip pim dense-mode
ip nat inside
ip virtual-reassembly
ip igmp join-group 224.1.1.1
no ip mroute-cache
no snmp trap link-status
arp authorized
no cdp enable
interface FastEthernet0/1.22
encapsulation dot1Q 22
ip address ххх.ххх.146.118 255.255.255.252
ip pim dense-mode
no ip mroute-cache
no cdp enable
stream сервер ххх.ххх.146.117
router# sh ip mroute
(*, 224.1.1.1), 04:08:37/00:02:59, RP 0.0.0.0, flags: SJCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
FastEthernet0/1.22, Forward/Dense, 03:57:17/00:00:00
FastEthernet0/1.21, Forward/Dense, 04:08:37/00:00:00
(*, 224.0.1.40), 04:11:45/00:01:59, RP 0.0.0.0, flags: DCL
FastEthernet0/1.22, Forward/Dense, 04:11:45/00:00:00
(*, 239.255.255.250), 04:11:41/00:02:18, RP 0.0.0.0, flags: SJC
FastEthernet0/1.21, Forward/Dense, 04:11:41/00:00:00
FastEthernet0/1.22, Forward/Dense, 00:42:06/00:00:00
router#sh ip igmp interface
FastEthernet0/1.22 is up, line protocol is up
Internet address is zzz.zzz.146.118/30
IGMP is enabled on interface
Current IGMP host version is 2
Current IGMP router version is 2
IGMP query interval is 60 seconds
IGMP querier timeout is 120 seconds
IGMP max query response time is 10 seconds
Last member query count is 2
Last member query response interval is 1000 ms
Inbound IGMP access group is not set
IGMP activity: 5 joins, 2 leaves
Multicast routing is enabled on interface
Multicast TTL threshold is 0
Multicast designated router (DR) is zzz.zzz.146.118 (this system)
IGMP querying router is zzz.zzz.146.118 (this system)
Multicast groups joined by this system (number of users):
224.0.1.40(1) 224.1.1.1(1)
FastEthernet0/1.21 is up, line protocol is up
Internet address is zzz.zzz.80.254/24
IGMP activity: 4 joins, 2 leaves
Multicast designated router (DR) is zzz.zzz.80.254 (this system)
IGMP querying router is zzz.zzz.80.254 (this system)
224.1.1.1(1)
что делаю не так ума не приложу...
Edited by kir22
  • 2 years later...
нашел причину ;-)
Скажи в чем причина? заколебался уже настраивать multicast
или напиши последовательность комманд для его настройки.
Edited by Spawn-2002
