Kadet Posted April 17, 2007 Posted April 17, 2007 Целуй день провозился, так и не решил проблемку, может рыл не в том месте. Вообщем поставил я на фрю 6.2 профтп указаной версии когда пытаюсь запустить пишет: [root@frya /etc]# proftpd - IPv4 getaddrinfo 'frya.kiev.oa' error: hostname nor servname provided, or not known - warning: unable to determine IP address of 'frya.kiev.oa' - error: no valid servers configured - Fatal: error processing configuration file '/usr/local//etc/proftpd.conf' [root@frya /etc]# при попытке зайти по фтп на айпишник фрии выпадает сообщение: Apr 17 21:45:14 frya proftpd[762]: Fatal: error processing configuration file '/usr/local//etc/profrp.conf когда в настройках sysinstall, сетевого интерфейса поле, где должен быть прописан адрес домена, осталяю пустым, все запускается на ура. НО когда грузится система, на время зависает. может кто сталкивался с таким, плз, помогите советом. # This is a basic ProFTPD configuration file (rename it to # 'proftpd.conf' for actual use. It establishes a single server # and a single anonymous login. It assumes that you have a user/group # "nobody" and "ftp" for normal operation and anon. ServerName "ftp" ServerType inetd DefaultServer on RootLogin on # Port 21 is the standard FTP port. Port 21 # Umask 022 is a good standard umask to prevent new dirs and files # from being group and world writable. Umask 022 # To prevent DoS attacks, set the maximum number of child processes # to 30. If you need to allow more than 30 concurrent connections # at once, simply increase this value. Note that this ONLY works # in standalone mode, in inetd mode you should use an inetd server # that allows you to limit maximum number of processes per service # (such as xinetd). MaxInstances 30 # Set the user and group under which the server will run. User nobody Group nogroup # To cause every FTP user to be "jailed" (chrooted) into their home # directory, uncomment this line. #DefaultRoot ~ # Normally, we want files to be overwriteable. AllowOverwrite on # Bar use of SITE CHMOD by default <Limit SITE_CHMOD> /usr/local/etc/proftpd.conf: 64 lines, 1911 characters. [root@frya /etc]# proftpd - IPv4 getaddrinfo 'frya.kiev.oa' error: hostname nor servname provided, or not known - warning: unable to determine IP address of 'frya.kiev.oa' - error: no valid servers configured - Fatal: error processing configuration file '/usr/local//etc/proftpd.conf' [root@frya /etc]# vi /usr/local/etc/proftpd.conf # This is a basic ProFTPD configuration file (rename it to # 'proftpd.conf' for actual use. It establishes a single server # and a single anonymous login. It assumes that you have a user/group # "nobody" and "ftp" for normal operation and anon. ServerName "ftp" #ServerType standalone ServerType inetd DefaultServer on RootLogin on # Port 21 is the standard FTP port. Port 21 # Umask 022 is a good standard umask to prevent new dirs and files # from being group and world writable. Umask 022 # To prevent DoS attacks, set the maximum number of child processes # to 30. If you need to allow more than 30 concurrent connections # at once, simply increase this value. Note that this ONLY works # in standalone mode, in inetd mode you should use an inetd server # that allows you to limit maximum number of processes per service # (such as xinetd). MaxInstances 30 # Set the user and group under which the server will run. User nobody Group nogroup # To cause every FTP user to be "jailed" (chrooted) into their home # directory, uncomment this line. #DefaultRoot ~ # Normally, we want files to be overwriteable. AllowOverwrite on # Bar use of SITE CHMOD by default <Limit SITE_CHMOD> DenyAll </Limit> # A basic anonymous configuration, no upload directories. If you do not # want anonymous users, simply delete this entire <Anonymous> section. <Anonymous ~ftp> User ftp Group ftp # We want clients to be able to login with "anonymous" as well as "ftp" UserAlias anonymous ftp # Limit the maximum number of anonymous logins MaxClients 10 # We want 'welcome.msg' displayed at login, and '.message' displayed # in each newly chdired directory. DisplayLogin welcome.msg DisplayFirstChdir .message # Limit WRITE everywhere in the anonymous chroot <Limit WRITE> DenyAll </Limit> </Anonymous> Вставить ник Quote
csa Posted April 17, 2007 Posted April 17, 2007 все ж написано: unable to determine IP address of 'frya.kiev.oa' хотя и frya.kiev.ua тоже не существует.. но его можно хотябы в hosts забить Вставить ник Quote
