Собственно конфиг:
class-map match-all VOICE-CLASS
   match access-group 101
policy-map VOICE-POLICY
   class VOICE-CLASS
       priority 128
   class class-default
       fair-queue
       random-detect
policy-map PARENT-POLICY
    class class-default
        shape average 512000
        service-policy VOICE-POLICY
! MY-IP - мой голосовой шлюз
! ALIEN-IP - голосовой шлюз VoIP провайдера
access-list 101 permit ip host MY-IP host ALIEN-IP
interface FastEthernet 0/0
   description Trunk
interface FastEthernet 0/0.10
   description Provider
   encapsulation dot1Q 10
   bandwidth 512
   ip address 10.10.10.10 255.255.255.0
   service-policy output PARENT-POLICY
interface FastEthernet 0/0.5
   description Clients
   encapsulation dot1Q 5
   bandwidth 512
   ip address 192.168.129.254 255.255.255.0
Почему трафик попадающий под 101 аксес лист не бежит вперёд планеты всей ? Вместо
priority 128
ставил
bandwidth 128
эффекта 0
Где рыть ?
BORDER-GW#sh ver
Cisco Internetwork Operating System Software
IOS ™ 3600 Software (C3620-IS-M), Version 12.2(32), RELEASE SOFTWARE (fc1)
Copyright © 1986-2005 by cisco Systems, Inc.
Compiled Fri 02-Dec-05 15:48 by
Image text-base: 0x60008930, data-base: 0x6112A000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
BORDER-GW uptime is 1 week, 5 days, 6 hours, 16 minutes
System returned to ROM by power-on
System image file is "flash:c3620-is-mz.122-32.bin"
cisco 3620 (R4700) processor (revision 0x81) with 60416K/5120K bytes of memory.
Processor board ID 20613182
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
4 Channelized E1/PRI port(s)
2 Voice FXO interface(s)
2 Voice FXS interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x3922
Спасибо!
Edited by zander
Мне не ограничить нужно, а пустить вперёд всего остального, тоесть гарантировать ему полосу
вперёд нельзя пустить, пока канал незагружен (не возникают очереди). FastEthernet - это 100 мегабит, пока он незагружен (на 36хх - ГЫ :)) ничего приоретизироваться не будет.
И как же тогда реализовать приоритет трафика между двумя сабинтерфейсами (допустим если совпадает с ACL 141)
Спасибо!
