borys Posted March 14, 2007 Posted March 14, 2007 (edited) Есть такая связка mpd4+freenibs mpd.conf client_standard: set bundle no multilink set bundle enable compression set ccp yes mppc set ecp yes dese-bis set bundle enable encryption # set bundle enable crypt-reqd set bundle no ipv6cp set iface idle 0 set iface disable on-demand set iface disable proxy-arp set iface enable tcpmssfix set iface mtu 1500 set link no pap chap set link enable chap set link keep-alive 60 180 set ipcp yes vjcomp set ipcp no vjcomp set ipcp dns x.x.x.x set ipcp dns x.x.x.x set ipcp nbns 192.168.1.100 set link max-redial -1 set link mtu 1492 set ccp yes mpp-e40 set ccp yes mpp-e128 set ccp yes mpp-stateless set pppoe iface rl0 set pppoe disable originate set pppoe enable incoming set radius me localhost set radius config /etc/radius.conf set radius timeout 10 set radius retries 3 set auth enable radius-auth set auth enable radius-acct # set ipcp yes radius-ip ____________________ В таком варианте все проходит на ура но весь трафик виден tcpdump-ом в открытом виде. Как только я убираю комент в строчке set bundle enable crypt-reqd получаю такую бяку Mar 14 10:03:49 spider mpd: [pppoe0] CCP: encryption required, but MPPE was not negotiated in both directions Mar 14 10:03:49 spider mpd: [pppoe0] CCP: failed to negotiate required encryption Mar 14 10:03:49 spider mpd: [pppoe0] IPCP: failed to negotiate required encryption Mar 14 10:03:49 spider mpd: [pppoe0] IPV6CP: failed to negotiate required encryption Mar 14 10:03:49 spider mpd: [pppoe0] RADIUS: Termination cause: Protocol error:PPP layer IPCP failed: failed to negotiate required encryption, RADIUS: 15 Может кто сталкивался с таким ? Edited March 14, 2007 by borys Вставить ник Quote
vpnet Posted March 20, 2007 Posted March 20, 2007 попробуй прямо его отключить. а в радиусе ты шифрование вырубил? Вставить ник Quote
GateKeeper Posted March 20, 2007 Posted March 20, 2007 Если мне не изменяет память, то в случае с радиусом требуется только ccp accept *, а enable ставится за счёт соответствующего ответа радиуса на этапе auth-req. В общем, поиграться с accept/enable в ccp-параметрах тоже стоит. Вставить ник Quote
