maniackiller Posted March 13, 2007 Posted March 13, 2007 привет всем. Есть необходимость в организации VPN 3 layer(IPSEC). Допустим есть два офиса, между ними нужно настроить VPN. Конфиг такой Building configuration... Current configuration : 2265 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname vpn2611 ! !--- Enable AAA for user authentication !--- and group authorization. aaa new-model ! ! !--- In order to enable X-Auth for user authentication, !--- enable the aaa authentication commands. aaa authentication login userauthen local !--- In order to enable group authorization, enable !--- the aaa authorization commands. aaa authorization network groupauthor local aaa session-id common ! !--- For local authentication of the IPSec user, !--- create the user with a password. username cisco password 0 cisco ip subnet-zero ! ! ! ip audit notify log ip audit po max-events 100 ! !--- Create an Internet Security Association and !--- Key Management Protocol (ISAKMP) !--- policy for Phase 1 negotiations for the VPN 3.x Clients. crypto isakmp policy 3 encr 3des authentication pre-share group 2 ! !--- Create an ISAKMP policy for Phase 1 !--- negotiations for the LAN-to-LAN tunnels. crypto isakmp policy 10 hash md5 authentication pre-share !--- Specify the PreShared key for the LAN-to-LAN tunnel. !--- Make sure that you use the !--- no-xauth parameter with your ISAKMP key. crypto isakmp key cisco123 address 172.18.124.199 no-xauth ! !--- Create a group that is used to !--- specify the WINS, DNS servers' address !--- to the client, along with the pre-shared !--- key for authentication. crypto isakmp client configuration group 3000client key cisco123 dns 10.10.10.10 wins 10.10.10.20 domain cisco.com pool ippool ! ! !--- Create the Phase 2 Policy for actual data encryption. crypto ipsec transform-set myset esp-3des esp-md5-hmac ! !--- Create a dynamic map and apply !--- the transform set that was created earlier. crypto dynamic-map dynmap 10 set transform-set myset ! ! !--- Create the actual crypto map, and !--- apply the AAA lists that were created !--- earlier. Also create a new instance for your !--- LAN-to-LAN tunnel. Specify the peer IP address, !--- transform set, and an Access Control List (ACL) for this !--- instance. crypto map clientmap client authentication list userauthen crypto map clientmap isakmp authorization list groupauthor crypto map clientmap client configuration address respond crypto map clientmap 1 ipsec-isakmp set peer 172.18.124.199 set transform-set myset match address 100 crypto map clientmap 10 ipsec-isakmp dynamic dynmap ! ! fax interface-type fax-mail mta receive maximum-recipients 0 ! ! !--- Apply the crypto map on the outside interface. interface Ethernet0/0 ip address 172.18.124.159 255.255.255.0 half-duplex crypto map clientmap ! interface Serial0/0 no ip address shutdown ! interface Ethernet0/1 ip address 10.10.10.1 255.255.255.0 no keepalive half-duplex ! ! !--- Create a pool of addresses to be !--- assigned to the VPN Clients. ip local pool ippool 14.1.1.100 14.1.1.200 ip classless ip route 0.0.0.0 0.0.0.0 172.18.124.1 ip http server ip pim bidir-enable ! ! !--- Create an ACL for the traffic !--- to be encrypted. In this example, !--- the traffic from 10.10.10.0/24 to 10.10.20.0/24 !--- is encrypted. access-list 100 permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255 ! ! snmp-server community foobar RO call rsvp-sync ! ! mgcp profile default ! dial-peer cor custom ! ! line con 0 exec-timeout 0 0 line aux 0 line vty 0 4 ! ! end Коннекцюсь Cisco VPN Client выдает такою ошибку Mar 1 00:41:03.192: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at 172.18.124.199ъ А вообще нужно сделать так чтобы оба офиса поключались Cisco МЗТ Client к циске и между ними образовывался бы туннель. Вставить ник Quote
