@Bulgaria Posted February 26, 2007 Posted February 26, 2007 (edited) Hi, First sorry for my English! I have a D-Link DWL-7100AP. It strange but somhow the flash memory was erased itself on power up. Now I have to flash the device. I tried to use the bootloader. I set up a TFTP server with TFP image file, renamed it to APIMG1. The following error appears every time when the booloader try to download the file: [boot]: @ Attached TCP/IP interface to ae0. Attaching network interface lo0... done. Loading... Error loading file: errno = 0x610001. My boot parametters are: [boot]: p boot device : ae unit number : 0 processor number : 0 file name : /fl/APIMG1 inet on ethernet (e) : 192.168.1.20:0xffffff00 host inet (h) : 192.168.1.21 flags (f) : 0x80 startup script (s) : factory other (o) : ae [boot]: I run a TFTP server on 192.168.1.21, and set the flag to 0x80. So, the bootloader restarts after the error mention up. The secont try so solve the problem was to make a APIMG file from TFP image by using tfp_unpacker2.exe. Still the same error appears. I think that tfp_unpacker2.exe in not usable for DWL-7100AP, maybe? So can you help me to flash the device, Thanks! Boris p.s: можно отвечат на руский, он не плахой - разбираю всьо, но я не могу писат хороше ... Edited February 26, 2007 by @Bulgaria Вставить ник Quote
builder Posted February 26, 2007 Posted February 26, 2007 It strange but somhow the flash memory was erased itself on power up. Не могу перевести, но что-то подсказывает, что у Вас флешь is dead. Вставить ник Quote
@Bulgaria Posted February 26, 2007 Author Posted February 26, 2007 It strange but somhow the flash memory was erased itself on power up.Не могу перевести, но что-то подсказывает, что у Вас флешь is dead. А ест ли такой начин загрузит флеш через JTAG? У меня два Д-линк-а 7100ап. Первьй без проблемен - я думаю прочитат флеш из первом потом напишу во втором. Вставить ник Quote
MaXToP Posted February 27, 2007 Posted February 27, 2007 boot device : ae First: DWL7100 have two interface ae1 and ae2. You can see this after command "?" file name : /fl/APIMG1 Sec.: You shure what you dowloading file is in /fl/ directory on you ftp server ? And you can't load APIMG1 file via TFTP !!! For you best --> make reset to factory default settings. After this correct in boot loader "file name : /fl/APIMG1" on "file name : /fl/backup" After this you DWL7100 loading on "crash" mode and you can restore firmware. Вставить ник Quote
@Bulgaria Posted February 27, 2007 Author Posted February 27, 2007 boot device : ae First: DWL7100 have two interface ae1 and ae2. You can see this after command "?" file name : /fl/APIMG1 Sec.: You shure what you dowloading file is in /fl/ directory on you ftp server ? And you can't load APIMG1 file via TFTP !!! For you best --> make reset to factory default settings. After this correct in boot loader "file name : /fl/APIMG1" on "file name : /fl/backup" After this you DWL7100 loading on "crash" mode and you can restore firmware. Thanks! Using ART tool and FTP for downloading file to the device the AP is running OK now :) Вставить ник Quote
