Помогите плз новичку побороть циску, при попытке конфигурирования
yourname#
yourname#conf t
Enter configuration commands, one per line. End with CNTL/Z.
yourname(config)#int fa0
yourname(config-if)#ip address 10.1.3.1 255.255.255.0
% IP addresses may not be configured on L2 links.
модель циски 871, 4 порта ЛАН и 1 Влан
yourname#show interface
FastEthernet0 is up, line protocol is up
Hardware is Fast Ethernet, address is 001a.a13b.4e1a (bia 001a.a13b.4e1a)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3000 bits/sec, 4 packets/sec
5 minute output rate 0 bits/sec, 1 packets/sec
9919 packets input, 1024255 bytes, 0 no buffer
Received 5769 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 input packets with dribble condition detected
1440 packets output, 112236 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
FastEthernet1 is up, line protocol is down
Hardware is Fast Ethernet, address is 001a.a13b.4e1b (bia 001a.a13b.4e1b)
Auto-duplex, Auto-speed
Last input never, output never, output hang never
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
FastEthernet2 is up, line protocol is down
Hardware is Fast Ethernet, address is 001a.a13b.4e1c (bia 001a.a13b.4e1c)
FastEthernet3 is up, line protocol is down
Hardware is Fast Ethernet, address is 001a.a13b.4e1d (bia 001a.a13b.4e1d)
FastEthernet4 is administratively down, line protocol is down
Hardware is PQUICC_FEC, address is 001a.a13b.4e24 (bia 001a.a13b.4e24)
Auto-duplex, Auto Speed, 100BaseTX/FX
0 watchdog
0 output errors, 0 collisions, 1 interface resets
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 001a.a13b.4e1a (bia 001a.a13b.4e1a)
Description: $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
Internet address is 10.1.2.7/24
5 minute input rate 1000 bits/sec, 2 packets/sec
7845 packets input, 824570 bytes, 0 no buffer
Received 6445 broadcasts, 0 runts, 0 giants, 0 throttles
1525 packets output, 112696 bytes, 0 underruns
0 output errors, 1 interface resets
Vlan2 is up, line protocol is down
Internet address is 10.1.9.9/24
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
там не 4 порта LAN, там 4-х портовый коммутатор, на портах которого как раз и нельзя задать никаких IP.
IP надо задавать на интерфейсах маршрутизатора...
У нее есть Web-интерфейс, который новичку поможет.
Она умеет до 4-х вланов но этом коммутаторе, и может отдавать их как тегированными в один порт, там отдельный порт-отдельный влан. Но IP надо ставить на интерфейсе vlan1, в данном случае.
вопрос такой, помогите плз
можно ли сделать так?
yourname(config-if)#switchport access vlan 1
yourname(config)#int fa1
yourname(config-if)#switchport access vlan 2
и потом сделать маршрутизацию между вланами?
когда я делаю
результат
%Access VLAN 2 does not exist. Please add it to vlan database
Можно сделать маршрутизацию между вланами. Но не очень быстро. Очень быстро будет L3 свич.
Сделать так:
conf t
int vlan 2
ip address xxx.xxx.xxx.xxx mmm.mmm.mmm.mmm
int fas1
Прочитать про "это" можно в Интернете.
Если интересует Cisco - то www.cisco.com
Например по Вашему продукту - вот.
http://www.cisco.com/en/US/products/hw/rou..._configure.html
Сделать так:
conf t
int vlan 2
int fas1
Дык я так и делаю...
не хотит добавляться
>yourname#vlan database
>yourname(vlan)#vlan 2
>Vlan can not be added. Maximum number of 1 vlan(s) in the
>database.
Сделать так:
conf t
int vlan 2
int fas1
>database.
В advanced ip services, если не ошибаюсь, до 4-х.
еще один вопрос
есть этаже циска 871
как настроить НАТ, чтоб комп подключен в фа0 с сетью 192,168,0,0 видел компы в сети 10,1,2,0 на порту фа4?
