Добрый день!
Есть оный сабж. Понимаю что старье, но мне хватает.
Если кто-нить сталкивался большая просьба помочь. Очень нужно организовать на нем игнор пакетов по МАКу.
Нашел в мануале то что мне нужно (как мне кажется):
http://www.cisco.com/univercd/cc/td/doc/pr...tm#xtocid967619
Написано:
Catalyst 1900 - Port 1 Addressing
Address : Static 00-00-00-00-00-1B
----------------------- Settings ---------------------------------------
[T] Address table size Unrestricted
Addressing security Disabled
Flood unknown unicasts Enabled
[M] Flood unregistered multicasts Enabled
----------------------- Actions ----------------------------------------
[A] Add a static address
[D] Define restricted static address
[L] List addresses
[E] Erase an address
[R] Remove all addresses
[C] Configure port [V] View port statistics
[N] Next port [G] Goto port
[P] Previous port [X] Exit to Main Menu
Enter Selection:
[D] Define a restricted static address---Enter the restricted static unicast or multicast address. Packets with static addresses are usually accepted from any source port. However, a restricted static address, which corresponds to IEEE 802.1d source port filtering, is accompanied by a list of ports that are allowed to send frames to this address and port.
You are then prompted to enter the port numbers allowed to send to this address. If there are any typing errors, the prompt is redisplayed.
Читал не один раз но принцип работы "ограничителя" так и не понял - т.е. что это за source port и зачем нужен list of ports. Короче, толи лыжы не едут, толи я ...
This topic is now closed to further replies.
