Table 6. Performance Capabilities
AIR-BR1310G-x-K9 or AIR- LAP1310G-x-K9
AIR-BR1310G-x-K9-R or AIR-LAP1310G-x-K9R
Available Transmit Power Settings
802.11b:
· 100 mW (20 dBm)
· 50 mW (17 dBm)
· 30 mW (15 dBm)
· 20 mW (13 dBm)
· 10 mW (10 dBm)
· 5 mW (7 dBm)
· 1 mW (0 dBm)
802.11g:
· 30 mW (15 dBm)
· 20 mW (13 dBm)
· 10 mW (10 dBm)
· 5 mW (7 dBm)
· 1 mW (0 dBm) 802.11b:
· 100 mW (20 dBm)
· 50 mW (17 dBm)
· 30 mW (15 dBm)
· 20 mW (13 dBm)
· 10 mW (10 dBm)
· 5 mW (7 dBm)
· 1 mW (0 dBm)
802.11g:
· 30 mW (15 dBm)
· 20 mW (13 dBm)
· 10 mW (10 dBm)
· 5 mW (7 dBm)
· 1 mW (0 dBm)
Note: Maximum power setting will vary according to individual country regulations.
Maximum Operational Receive Level
-20 dBm
-20 dBm
Maximum Survivable Receive Level
10 dBm
10 dBm
Receive Sensitivity (10 Percent with 3200 Byte Packets)
· 1 Mbps: -94 dBm
· 2 Mbps: -91 dBm
· 5.5 Mbps: -89 dBm
· 11 Mbps: -85 dBm
· 6 Mbps: -90 dBm
· 9 Mbps: -89 dBm
· 12 Mbps: -86 dBm
· 18 Mbps: -84 dBm
· 24 Mbps: -81 dBm
· 36 Mbps: -77 dBm
· 48 Mbps: -73 dBm
· 54 Mbps: -72 dBm · 1 Mbps: -94 dBm
· 2 Mbps: -91 dBm
· 5.5 Mbps: -89 dBm
· 11 Mbps: -85 dBm
· 6 Mbps: -90 dBm
· 9 Mbps: -89 dBm
· 12 Mbps: -86 dBm
· 18 Mbps: -84 dBm
· 24 Mbps: -81 dBm
· 36 Mbps: -77 dBm
· 48 Mbps: -73 dBm
· 54 Mbps: -72 dBm
Maximum Bridge Relative Velocity (Autonomous-Mode Only)
Over 100 km per hour at 12 and 24 Mbps with 128-byte packets at 1 percent PER
Access Point Role: Outdoor Range
Americas
· 865 feet (260 meters) at 54 Mbps
· 3465 feet (1055 meters) at 11 Mbps
ETSI
· 150 feet (45 meters) at 54 Mbps
· 775 feet (235 meters) at 11 Mbps
TELEC
· 485 feet (145 meters) at 54 Mbps
· 1095 feet (330 meters) at 11 Mbps
Note: Access point with 13-dBi integrated antenna and Cisco clients
Americas
· 350 feet (105 meters) at 54 Mbps
· 1410 feet (430 meters) at 11 Mbps
ETSI
· 195 feet (60 meters) at 54 Mbps
· 630 feet (190 meters) at 11 Mbps
TELEC
· 445 feet (135 meters) at 11 Mbps
Note: Access point with 5.2-dBi patch antenna and Cisco clients
Bridge Role: Point-to-Point Range*
Americas
· 1.3 miles (2 km) at 54 Mbps
· 9 miles (15 km) at 11 Mbps
EMEA
· 0.2 miles (0.36 km) at 54 Mbps
· 2.3 miles (3.5 km) at 11 Mbps
TELEC
· 0.7 miles (1.1 km) at 54 Mbps
· 3.2 miles (5 km) at 11 Mbps
Note: 13-dBi integrated antenna at root and non-root bridge
Americas
· 4.5 miles (7 km) at 54 Mbps
· 14 miles (23 km) at 11 Mbps
EMEA
· 5.5 miles (9 km) at 11 Mbps
TELEC
· 12 miles (20 km) at 11 Mbps
Note: 21-dBi dish antenna at root and non-root bridge
Bridge Role: Point-to-Multipoint Range*
Americas
· 1.1 miles (1.8 km) at 54 Mbps
· 8 miles (13 km) at 11 Mbps
EMEA
· 0.25 miles (0.4 km) at 54 Mbps
· 1.1 miles (1.8 km) at 11 Mbps
TELEC
· 0.8 miles (1.3 km) at 54 Mbps
· 3.6 miles (5.8 km) at 11 Mbps
Note: 14-dBi sector antenna at root and 13-dBi integrated antenna at non-root
Americas
· 2.0 miles (3.3 km) at 54 Mbps
· 10 miles (16 km) at 11 Mbps
EMEA
· 2.5 miles (4 km) at 11 Mbps
TELEC
· 9.0 miles (14 km) at 11 Mbps
Note: 14-dBi sector at root and 21-dBi dish at non-root
* Bridge role is only available for autonomous deployments. The distances referenced here are approximations and should be used for estimation
purposes only.
