пропало соединение между 3Com 4226T и 3Com 5500G-EI, после перезагрузки 5500 заработало, но:
5500G-EI %%10LAGG/3/PartnerNoLacp(l):- 1 -LACP is not enabled on the remote end of port GigabitEthernet1/0/25.
5500G-EI %%10LAGG/3/PartnerNoLacp(l):- 1 -LACP is not enabled on the remote end of port GigabitEthernet1/0/26
в логах
хотя на 3Com 4226T:
bridge linkAggregation summary
LACP ActorID: 8000,00-16-e0-82-a5-00
Aggregated Active Inactive Disabled LACP PartnerID
Link Ports Ports Ports
1 2 0 0 8000,00-16-e0-16-65-00
2 0 0 0 Not known
3 0 0 0 Not known
4 0 0 0 Not known
на 3Com 5500G-EI:
display lacp system-id
Actor System ID: 0x8000, 0016-e016-6500
