есть циска cisco AIR-BR1310G-A-K9-R в root режиме с конфигом
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname agatelap
enable secret 5 $1$PMsP$4hlvwcglPGNT6f3u94732/
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server tacacs+ tac_admin
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
dot11 ssid radiouser
authentication open
guest-mode
infrastructure-ssid
dot11 network-map
username crown privilege 15 password 7 lalala
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid radiouser
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2452
station-role root bridge wireless-clients
cca 75
concatenation
distance 30
antenna receive right
antenna transmit right
antenna gain 12
no cdp enable
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
no cdp enable
bridge-group 1
interface BVI1
ip address 192.168.10.3 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
ip http authentication aaa
no ip http secure-server
ip radius source-interface BVI1
no cdp run
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
terminal-type ansi
transport preferred all
transport output all
line vty 0 4
terminal-type ansi
transport input all
line vty 5 15
terminal-type ansi
transport input all
end
подружить эту точку доступа с творением компании D-link DWL-1000AP+
в длинке прописал SSID radiouser
и в дополнительных настройках пытался по разному выбирать
и Wireless Client
и Wireless Bridge
прописывать MAC адрес руками ничего не меняется
статус Dlink
Ethernet
Send Good Packets 63041
Dropped Packets 0
Recv Good Packets 2201
Dropped Packets 0
Wireless
Send Good Packets 61095
Dropped Packets 61086
Recv Good Packets 2515289
Dropped Packets 426
на циске вооще ничего не видно
как с этим поборотся?
  • 1 year later...
Кто знает какой у Сisco AIR-BR1310G-A-K9 дефолтный IP и кто вообще с ними сталкивался посоветуйте мануалы(линки на мануалы) на русском языке. Описание настройки может где есть. В гугле был, чтото там негусто...
