вобщем неполучатся, хоть тресни :( , спутник ам22
запускаю VLC
vlc -vvv --color --ttl 12 --ts-es-id-pid --programs=14 dvb: \
--dvb-frequency=11044000 --dvb-srate=29800000 --dvb-voltage=13 \
--sout '#transcode{acodec=mp3,ab=128,channels=2}:duplicate{dst=std{access=http,mux=r
aw,url=192.168.0.2:8001},select="program=14"}'
получаю :
VLC media player 0.8.5 Janus
starting VLC root wrapper... using UID 0 (root)
* Running VLC as root is discouraged. *
It is potentially dangerous, and might not even work properly.
[00000001] main vlc debug: opening config file /root/.vlc/vlcrc
[00000001] main vlc warning: config file /root/.vlc/vlcrc does not exist yet
[00000001] main vlc debug: checking builtin modules
[00000001] main vlc debug: checking plugin modules
[00000001] main vlc debug: loading plugins cache file /root/.vlc/cache/plugins-04041e.dat
[00000001] main vlc debug: recursively browsing `modules'
[00000001] main vlc debug: recursively browsing `/usr/local/vlc-0.8.5/lib/vlc'
[00000001] main vlc debug: recursively browsing `plugins'
[00000001] main vlc debug: module bank initialized, found 209 modules
[00000001] main vlc debug: CPU has capabilities 486 586 MMX 3DNow! MMXEXT FPU
[00000001] main vlc debug: looking for memcpy module: 4 candidates
[00000001] main vlc debug: using memcpy module "memcpymmxext"
[00000268] main playlist debug: waiting for thread completion
[00000268] main playlist debug: thread 3072134064 (playlist) created at priority 0 (playlist/playlist.c:184)
[00000269] main private debug: waiting for thread completion
[00000269] main private debug: thread 3063745456 (preparser) created at priority 0 (playlist/playlist.c:210)
[00000270] main interface debug: looking for interface module: 1 candidate
[00000270] main interface debug: using interface module "hotkeys"
[00000270] main interface debug: thread 3055356848 (interface) created at priority 0 (interface/interface.c:231)
[00000272] main interface debug: looking for interface module: 1 candidate
[00000272] main interface debug: using interface module "screensaver"
[00000272] main interface debug: thread 3046968240 (interface) created at priority 0 (interface/interface.c:231)
[00000268] main playlist debug: adding playlist item `dvb:' ( dvb: )
[00000274] main interface debug: looking for interface module: 2 candidates
[00000274] skins2 interface error: Cannot open display
[00000274] skins2 interface error: cannot initialize OSFactory
Remote control interface initialized. Type `help' for help.
[00000274] main interface debug: using interface module "rc"
[00000274] main interface debug: thread 3035810736 (manager) created at priority 0 (interface/interface.c:216)
[00000268] main playlist debug: creating new input thread
[00000278] main input debug: waiting for thread completion
[00000278] main input debug: creating statistics handler
[00000280] main stream output debug: stream=`transcode'
[00000281] main private debug: looking for sout stream module: 1 candidate
[00000280] main stream output debug: stream=`duplicate'
[00000284] main private debug: looking for sout stream module: 1 candidate
[00000284] stream_out_duplicate private debug: creating 'duplicate'
[00000284] stream_out_duplicate private debug: * adding `std{access=http,mux=raw,url=192.168.0.2:8000}'
[00000280] main stream output debug: stream=`std'
[00000286] main private debug: looking for sout stream module: 1 candidate
[00000286] main private debug: set sout option: sout-standard-access to http
[00000278] main input debug: thread 3027422128 (input) created at priority 0 (input/input.c:261)
[00000286] main private debug: set sout option: sout-standard-mux to raw
[00000286] main private warning: Option sout-standard-url is deprecated. You should use sout-standard-dst instead.
[00000286] main private debug: set sout option: sout-standard-dst to 192.168.0.2:8000
[00000286] stream_out_standard private debug: creating `http/raw://192.168.0.2:8000'
[00000286] stream_out_standard private debug: extension is 2:8000
[00000286] stream_out_standard private debug: extension -> mux=(null)
[00000286] stream_out_standard private debug: using `http/raw://192.168.0.2:8000'
[00000288] main private debug: looking for sout access module: 1 candidate
[00000288] main private: creating httpd
[00000288] main private debug: net: listening to 192.168.0.2 port 8000
[00000291] main http server debug: thread 3019033520 (httpd host thread) created at priority 0 (network/httpd.c:1076)
[00000288] main private debug: using sout access module "access_output_http"
[00000286] stream_out_standard private debug: access opened
[00000292] main private debug: looking for sout mux module: 1 candidate
[00000292] mux_dummy private debug: Dummy/Raw muxer opened
[00000292] mux_dummy private: Open
[00000292] main private debug: using sout mux module "mux_dummy"
[00000280] main stream output debug: muxer support adding stream at any time
[00000286] stream_out_standard private debug: mux opened
[00000286] main private debug: using sout stream module "stream_out_standard"
[00000284] stream_out_duplicate private debug: * apply selection program=14
[00000284] main private debug: using sout stream module "stream_out_duplicate"
[00000281] main private debug: set sout option: sout-transcode-acodec to mp3
[00000281] main private debug: set sout option: sout-transcode-ab to 128
[00000281] main private debug: set sout option: sout-transcode-channels to 2
[00000281] stream_out_transcode private debug: codec audio=mp3 0Hz 2 channels 128Kb/s
[00000281] stream_out_transcode private warning: bad aspect ratio
[00000281] main private debug: using sout stream module "stream_out_transcode"
[00000278] main input debug: `dvb:' gives access `dvb' demux `' path `'
[00000278] main input debug: creating demux: access='dvb' demux='' path=''
[00000294] main demuxer debug: looking for access_demux module: 0 candidates
[00000294] main demuxer warning: no access_demux module matched "dvb"
[00000278] main input debug: creating access 'dvb' path=''
[00000295] main access debug: looking for access2 module: 6 candidates
[00000295] dvb access debug: Opening device /dev/dvb/adapter0/frontend0
status change: ( new input: dvb: )
status change: ( audio volume: 256 )
status change: ( play state: 1 )
[00000295] dvb access debug: Frontend Info:
[00000295] dvb access debug: name = ST STV0299 DVB-S
[00000295] dvb access debug: type = QPSK (DVB-S)
[00000295] dvb access debug: frequency_min = 950000 (kHz)
[00000295] dvb access debug: frequency_max = 2150000 (kHz)
[00000295] dvb access debug: frequency_stepsize = 125
[00000295] dvb access debug: frequency_tolerance = 0
[00000295] dvb access debug: symbol_rate_min = 1000000 (kHz)
[00000295] dvb access debug: symbol_rate_max = 45000000 (kHz)
[00000295] dvb access debug: symbol_rate_tolerance (ppm) = 500
[00000295] dvb access debug: notifier_delay (ms) = 0
[00000295] dvb access debug: Frontend Info capability list:
[00000295] dvb access debug: inversion auto
[00000295] dvb access debug: forward error correction 1/2
[00000295] dvb access debug: forward error correction 2/3
[00000295] dvb access debug: forward error correction 3/4
[00000295] dvb access debug: forward error correction 5/6
[00000295] dvb access debug: forward error correction 7/8
[00000295] dvb access debug: forward error correction auto
[00000295] dvb access debug: card can do QPSK
[00000295] dvb access debug: End of capability list
[00000295] dvb access debug: trying to tune the frontend...
[00000295] dvb access debug: frequency 11044000 is in Ku-band
[00000295] dvb access debug: using inversion=2
[00000295] dvb access debug: using fec=9
[00000295] dvb access debug: using voltage=13
[00000295] dvb access debug: using tone=0
[00000295] dvb access debug: Opening device /dev/dvb/adapter0/dvr0
[00000295] dvb access debug: setting filter on PAT
[00000295] dvb access debug: Opening device /dev/dvb/adapter0/demux0
[00000295] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 0
[00000295] dvb access debug: Opening device /dev/dvb/adapter0/ca0
[00000295] dvb access warning: CAMInit: opening CAM device failed (No such device)
[00000295] main access debug: using access2 module "dvb"
[00000297] main private debug: pre buffering
[00000295] dvb access debug: frontend has acquired signal
[00000295] dvb access debug: frontend has acquired carrier
[00000295] dvb access debug: frontend has acquired stable FEC
[00000295] dvb access debug: frontend has acquired sync
[00000295] dvb access debug: frontend has acquired lock
[00000295] dvb access debug: - Bit error rate: 10986
[00000295] dvb access debug: - Signal strength: 47356
[00000295] dvb access debug: - SNR: 54720
[00000297] main private debug: received first data for our buffer
[00000297] main private debug: prebuffering done 376 bytes in 0s - 1 kbytes/s
[00000298] main demuxer debug: looking for demux2 module: 43 candidates
[00000295] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 17
[00000295] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 18
[00000298] main demuxer debug: using demux2 module "ts"
[00000278] main input debug: looking for a subtitle file in /var/icecast/
[00000298] ts demuxer debug: DEMUX_SET_GROUP -1 0x82d4228
[00000278] main input debug: starting in synch mode
[00000295] dvb access warning: unimplemented query in control
[00000278] main input debug: `dvb:' successfully opened
libdvbpsi error (PSI decoder): TS discontinuity (received 9, expected 0) for PID 0
[00000298] ts demuxer debug: PATCallBack called
[00000298] ts demuxer debug: new PAT ts_id=1 version=6 current_next=1
[00000298] ts demuxer debug: * number=0 pid=16
[00000298] ts demuxer debug: * number=1 pid=34
[00000298] ts demuxer debug: * number=2 pid=37
[00000298] ts demuxer debug: * number=3 pid=40
[00000298] ts demuxer debug: * number=4 pid=43
[00000298] ts demuxer debug: * number=5 pid=46
[00000298] ts demuxer debug: * number=6 pid=60
[00000298] ts demuxer debug: * number=7 pid=50
[00000298] ts demuxer debug: * number=8 pid=54
[00000298] ts demuxer debug: * number=14 pid=56
[00000295] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 56
[00000298] ts demuxer debug: * number=15 pid=259
[00000298] ts demuxer debug: * number=98 pid=99
[00000298] ts demuxer debug: * number=99 pid=261
libdvbpsi error (PSI decoder): TS discontinuity (received 6, expected 0) for PID 56
[00000298] ts demuxer debug: PMTCallBack called
[00000298] ts demuxer debug: new PMT program number=14 version=6 pid_pcr=58
[00000295] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 58
[00000298] ts demuxer debug: * descriptor : unknown (0xe)
[00000298] ts demuxer debug: * es pid=58 type=4 fcc=mpga
[00000278] main input debug: selecting program id=14
[00000326] main packetizer debug: looking for packetizer module: 17 candidates
[00000326] main packetizer debug: using packetizer module "mpeg_audio"
[00000326] main packetizer debug: thread 3003964336 (decoder) created at priority 0 (input/decoder.c:159)
libdvbpsi error (PSI decoder): TS discontinuity (received 8, expected 0) for PID 17
[00000298] ts demuxer debug: PSINewTableCallBack: table 0x42(66) ext=0x1(1)
[00000298] ts demuxer debug: SDTCallBack called
[00000298] ts demuxer debug: new SDT ts_id=1 version=11 current_next=1 network_id=1
[00000298] ts demuxer debug: * service id=1 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=1-Muz BY
[00000278] main input debug: EsOutProgramMeta: number=1
[00000278] main input debug: - Name = 1-Muz BY
[00000278] main input debug: - Provider = RSCC
[00000278] main input debug: - Type = Digital television service
[00000278] main input debug: - Status = Running
[00000298] ts demuxer debug: * service id=2 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=World Music Channel
[00000278] main input debug: EsOutProgramMeta: number=2
[00000278] main input debug: - Name = World Music Channel
[00000298] ts demuxer debug: * service id=3 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=CTC+2
[00000278] main input debug: EsOutProgramMeta: number=3
[00000278] main input debug: - Name = CTC+2
[00000298] ts demuxer debug: * service id=4 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=CTC+0
[00000278] main input debug: EsOutProgramMeta: number=4
[00000278] main input debug: - Name = CTC+0
[00000298] ts demuxer debug: * service id=5 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=MuzTV Love RV
[00000278] main input debug: EsOutProgramMeta: number=5
[00000278] main input debug: - Name = MuzTV Love RV
[00000298] ts demuxer debug: * service id=6 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=Z+0
[00000278] main input debug: EsOutProgramMeta: number=6
[00000278] main input debug: - Name = Z+0
[00000298] ts demuxer debug: * service id=7 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=FNS
[00000278] main input debug: EsOutProgramMeta: number=7
[00000278] main input debug: - Name = FNS
[00000298] ts demuxer debug: * service id=8 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=Z+2
[00000278] main input debug: EsOutProgramMeta: number=8
[00000278] main input debug: - Name = Z+2
[00000298] ts demuxer debug: * service id=14 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=Radio Max
[00000278] main input debug: EsOutProgramMeta: number=14
[00000278] main input debug: - Name = Radio Max
[00000298] ts demuxer debug: * service id=15 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=Love Radio
[00000278] main input debug: EsOutProgramMeta: number=15
[00000278] main input debug: - Name = Love Radio
[00000298] ts demuxer debug: * service id=98 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=DATA KP
[00000278] main input debug: EsOutProgramMeta: number=98
[00000278] main input debug: - Name = DATA KP
[00000298] ts demuxer debug: * service id=99 eit schedule=0 present=0 running=4 free_ca=0
[00000298] ts demuxer debug: - type=1 provider=RSCC name=DATA CTC
[00000278] main input debug: EsOutProgramMeta: number=99
[00000278] main input debug: - Name = DATA CTC
[00000298] ts demuxer warning: first packet for pid=58 cc=0x8
при подключении выходит строка с моим айпи , в плеере тишина :(
[00000291] main http server debug: Connection from 10.1.0.12
научите , эсли кто уже делал это :(
Edited by Petr_N
запускаю VLC
А шо показывает "dmesg | grep b2c2"?
моя показывает
b2c2-flexcop: B2C2 FlexcopII/II(b)/III digital TV receiver chip loaded successfully
b2c2-flexcop: MAC address = 00:d0:d7:06:6f:02
b2c2-flexcop: i2c master_xfer failed
b2c2-flexcop: found the vp310 (aka mt312) at i2c address: 0x0e
b2c2-flexcop: initialization of 'Sky2PC/SkyStar 2 DVB-S (old version)' at the 'PCI' bus controlled by a 'FlexCopIIb' complete
а тот компьютер, который этого не показывает в указанной тобой строке запуска влц играет на ура.
Вывод: шо то с модулями. Ставил ли их с linuxtv.org?
проблема в другом помоему , потому что карта видит радио станции и тв каналы ...
забавно, в строке запуска указан порт 8001, а в логе фигурирует порт 8000
опять же по логам, вся часть которая заведует приемом сигнала работает, так что возможна проблема с фаерволом
ну и пища для мозгов, у меня вот такая строка запуска -
vlc --daemon -vvv --dvb-adapter=1 --ts-es-id-pid --programs=14,5 dvb: \
--dvb-frequency=3525000 --dvb-srate=7957000 --dvb-voltage=13 \
--sout '#duplicate{ dst="standard{access=http,mux=ts,url=:8012}",select="es=524,es=770", dst="transcode{acodec=mp3,ab=224,channels=2}:standard{access=http,mux=raw,url=:9
001}",select="program=14",dst="transcode{acodec=mp3,ab=224,channels=2}:standard{access=http,mux=raw,url=:9
002}",select="es=771"}'
netstat -l в студию, и посмотри загрузку проца, лог вывода у тебя вполне рабочий. и еще как вариант проблемы. у меня по некоторым каналам радио действительно тишина идет.
  • 2 weeks later...
вобщем , попробовал вещать в сеть видео , с теми же параметрами , просто поменял канал ,
все работает
а вот радио нехочет :(
когда ради в дебаг пишет:
[00000294] ts demuxer warning: first packet for pid=58 cc=0x3
когда видео:
[00000294] ts demuxer warning: first packet for pid=35 cc=0x6
[00000294] ts demuxer warning: first packet for pid=33 cc=0x9
[00000344] mpeg_audio packetizer debug: MPGA channels:2 samplerate:48000 bitrate:256
[00000280] main stream output debug: adding a new input
[00000281] stream_out_duplicate private debug: duplicated a new stream codec=mpga (es=33 group=1)
[00000289] main private debug: adding a new input
[00000289] mux_ts private debug: adding input codec=mpga pid=68
[00000289] mux_ts private debug: new PCR PID is 68
[00000281] stream_out_duplicate private debug: - added for output 0
[00000322] packetizer_mpegvideo packetizer debug: size 720x576 fps=25.000
[00000281] stream_out_duplicate private debug: duplicated a new stream codec=mpgv (es=35 group=1)
[00000289] mux_ts private debug: adding input codec=mpgv pid=69
[00000289] mux_ts private debug: new PCR PID is 69
кто что скаже???
Edited by Petr_N
и еще , если запускать без дебага , то ругается на libdvbpsi
[00000285] main private: creating httpd
[00000289] mux_dummy private: Open
[00000294] mux_dummy private: Open
libdvbpsi error (PSI decoder): TS discontinuity (received 7, expected 0) for PID 0
libdvbpsi error (PSI decoder): TS discontinuity (received 6, expected 0) for PID 17
libdvbpsi error (PSI decoder): TS discontinuity (received 15, expected 0) for PID 56
Я еще проще сделал ss2 сперва прокрутил на винде чтобы ознакомится и принципами настройки и быть уверенным в качестве сигнала, потом на лунуксе это все поднял.
