Below are the technical specifications of Regional BGAN satellite IP modem. This lightweight piece of kit is both robust and portable and can be connected to your computer using USB, Ethernet or Bluetooth interfaces.
Weight:
1.6 - 1.8 Kg (3.3lbs - 3.9lbs)
Size:
300mm x 240mm x 40mm (11.8" x 9.4" x 1.6")
SIM card:
Yes
Operating temperature:
-10°C to +55°C (14°F to 131°F)
Operating humidity:
95% RH at 40°C
Input Voltage:
7.2 to 8.4 Vdc
Mechanical Vibration:
200-2000 Hz, 0.3 m2/s3
Un-packaged drop:
0.5m on concrete
Solar radiation:
1120W/m2; MIL-SPEC 810E 505.3
Water and dust proofing:
IP-54 as standard, dust and spray proof in all directions
Air pressure for transport altitude:
4500 m AMSL; MIL-SPEC 810E METHOD 500.3
Battery Life:
24 hours standby time and 1 hour of continuous transmission at highest rate
Battery type:
Lithium-Ion
External Power:
Mains power supply adapter
Connectors:
USB, Ethernet, Bluetooth
User Interface:
Web page based graphical user interface accessible via standard web browser. Wizard set-up guide for sample start-up and set-up operations
External Antenna
Weight:
Antenna, including common mounting hardware:
3.4kg
Floor mount kit:
3.2kg
Wall mount kit:
2.2kg
Size:
Antenna:
670 x 380 x 62mm including mounting brackets.
Floor mount kit (assembled - overall dimensions):
810 x 870 x 630(h)mm
Wall mount kit (overall dimensions):
350 x 200 x 330mm
Operating: -50 to +55 degrees Celsius.
Storage: -50 to +80 degrees Celsius.
Humidity:
<95% relative humidity, non-condensing.
Altitude:
Operational range: 0 - 5000m above mean sea level.
Storage / transport range: 0 - 15000m above mean sea level.
Wind Loading:
Performance to specification: 80km/h in any direction;
No damage: 160km/h in any direction;
when securely mounted using the supplied mounting kit.
