Доброго времени суток!
Дело такое : на сервере (FreeBSD 4.8 RELEASE) Запущен pppoed -p pppoe rl0
На клиенте (FreeBSD 4.7 RELEASE) ppp -ddial pppoe
Если на сервере убить ppp (killall ppp) клиент пытается реконнектится и не может, в логах пишет:
Jul 29 13:30:26 smirnoff ppp[216]: tun0: Phase: deflink: Enter pause (3) for redialing.
Jul 29 13:30:26 smirnoff ppp[216]: tun0: Chat: deflink: Reconnect try 1 of 0
Jul 29 13:30:29 smirnoff ppp[216]: tun0: Chat: deflink: Redial timer expired.
Jul 29 13:30:29 smirnoff ppp[216]: tun0: Phase: deflink: Connected!
Jul 29 13:30:29 smirnoff ppp[216]: tun0: Phase: deflink: opening -> dial
Jul 29 13:30:29 smirnoff ppp[216]: tun0: Phase: deflink: dial -> carrier
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: Received NGM_PPPOE_ACNAME (hook "115-energo-host")
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: Received NGM_PPPOE_SESSIONID
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: Received NGM_PPPOE_SUCCESS
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: deflink: carrier -> login
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: deflink: login -> lcp
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: FSM: Using "deflink" as a transport
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: State change Initial --> Closed
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: State change Closed --> Stopped
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: RecvConfigReq(1) state = Stopped
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: MRU[4] 1492
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: MAGICNUM[6] 0x9d89195e
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: AUTHPROTO[4] 0xc023 (PAP)
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: SendConfigReq(4) state = Stopped
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: ACFCOMP[2]
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: PROTOCOMP[2]
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: ACCMAP[6] 0x00000000
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: MAGICNUM[6] 0x43f10cf4
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: QUALPROTO[8] proto c025, interval 5000ms
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: SendConfigAck(1) state = Stopped
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: LayerStart
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: State change Stopped --> Ack-Sent
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: RecvConfigAck(4) state = Ack-Sent
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: State change Ack-Sent --> Opened
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: LayerUp
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: SendIdent(4) state = Opened
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: MAGICNUM 43f10cf4
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: TEXT user-ppp 3.1 (built Oct 9 2002)
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: deflink: his = PAP, mine = none
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: Pap Output: alex ********
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: RecvIdent(0) state = Opened
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: MAGICNUM 9d89195e
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: Pap Input: SUCCESS (Greetings!!)
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: deflink: Already in NETWORK phase
Jul 29 13:30:30 smirnoff ppp[216]: tun0: Phase: deflink: lcp -> open
Jul 29 13:30:30 smirnoff ppp[216]: tun0: CCP: deflink: RecvConfigReq(1) state = Initial
Jul 29 13:30:30 smirnoff ppp[216]: tun0: CCP: DEFLATE[4] win 15
Jul 29 13:30:30 smirnoff ppp[216]: tun0: CCP: PRED1[2]
Jul 29 13:30:30 smirnoff ppp[216]: tun0: LCP: deflink: SendProtocolRej(5) state = Opened
Jul 29 13:30:30 smirnoff ppp[216]: tun0: IPCP: deflink: RecvConfigReq(1) state = Initial
Jul 29 13:30:30 smirnoff ppp[216]: tun0: IPCP: IPADDR[6] 192.168.200.1
Jul 29 13:30:30 smirnoff ppp[216]: tun0: IPCP: COMPPROTO[6] 16 VJ slots with slot compression
Jul 29 13:30:30 smirnoff ppp[216]: tun0: IPCP: PRIDNS[6] 192.168.0.8
Jul 29 13:30:30 smirnoff ppp[216]: tun0: IPCP: SECDNS[6] 255.255.255.255
Jul 29 13:30:30 smirnoff ppp[216]: tun0: IPCP: deflink: Oops, RCR in Initial.
Jul 29 13:30:33 smirnoff ppp[216]: tun0: IPCP: deflink: RecvConfigReq(1) state = Initial
Jul 29 13:30:33 smirnoff ppp[216]: tun0: IPCP: IPADDR[6] 192.168.200.1
Jul 29 13:30:33 smirnoff ppp[216]: tun0: IPCP: COMPPROTO[6] 16 VJ slots with slot compression
Jul 29 13:30:33 smirnoff ppp[216]: tun0: IPCP: PRIDNS[6] 192.168.0.8
Jul 29 13:30:33 smirnoff ppp[216]: tun0: IPCP: SECDNS[6] 255.255.255.255
Jul 29 13:30:33 smirnoff ppp[216]: tun0: IPCP: deflink: Oops, RCR in Initial.
Jul 29 13:30:36 smirnoff ppp[216]: tun0: IPCP: deflink: RecvConfigReq(1) state = Initial
Jul 29 13:30:36 smirnoff ppp[216]: tun0: IPCP: IPADDR[6] 192.168.200.1
Jul 29 13:30:36 smirnoff ppp[216]: tun0: IPCP: COMPPROTO[6] 16 VJ slots with slot compression
Jul 29 13:30:36 smirnoff ppp[216]: tun0: IPCP: PRIDNS[6] 192.168.0.8
Jul 29 13:30:36 smirnoff ppp[216]: tun0: IPCP: SECDNS[6] 255.255.255.255
Jul 29 13:30:36 smirnoff ppp[216]: tun0: IPCP: deflink: Oops, RCR in Initial.
Jul 29 13:30:39 smirnoff ppp[216]: tun0: IPCP: deflink: RecvConfigReq(1) state = Initial
Jul 29 13:30:39 smirnoff ppp[216]: tun0: IPCP: IPADDR[6] 192.168.200.1
Jul 29 13:30:39 smirnoff ppp[216]: tun0: IPCP: COMPPROTO[6] 16 VJ slots with slot compression
Jul 29 13:30:39 smirnoff ppp[216]: tun0: IPCP: PRIDNS[6] 192.168.0.8
Jul 29 13:30:39 smirnoff ppp[216]: tun0: IPCP: SECDNS[6] 255.255.255.255
Jul 29 13:30:39 smirnoff ppp[216]: tun0: IPCP: deflink: Oops, RCR in Initial.
Jul 29 13:30:42 smirnoff ppp[216]: tun0: IPCP: deflink: RecvConfigReq(1) state = Initial
Jul 29 13:30:42 smirnoff ppp[216]: tun0: IPCP: IPADDR[6] 192.168.200.1
Jul 29 13:30:42 smirnoff ppp[216]: tun0: IPCP: COMPPROTO[6] 16 VJ slots with slot compression
Jul 29 13:30:42 smirnoff ppp[216]: tun0: IPCP: PRIDNS[6] 192.168.0.8
Jul 29 13:30:42 smirnoff ppp[216]: tun0: IPCP: SECDNS[6] 255.255.255.255
Jul 29 13:30:42 smirnoff ppp[216]: tun0: IPCP: deflink: Oops, RCR in Initial.
после tun0 стоит как ни в чем ни бывало на клиенте и на сервере и айпишники на месте, но пингов нет. Как быть?!
Заранее благодарен.
  • 4 years later...
Что такое "VJ slots" ? У меня не работает PPPoE. В логах есть строки про "VJ slots"? только без компрессии.
ppp.conf:
default:
pppoe-out:
#    set device PPPoE:fxp0:inetsrv
    set device PPPoE:vr0:inetsrv
    set log Phase Chat IPCP tun command
    set cd 5
    set dial
    set login
    set authname malor
    set authkey moi_parol
    set redial 30 999
    set reconnect 30 999
    enable lqr
    accept lqr
    set timeout 0
    disable PAP deflate pred1 protocomp vjcomp dns
    deny PAP deflate pred1 protocomp vjcomp dns
ppp.log:
Aug 30 22:48:06 gangster ppp[1132]: Phase: Using interface: tun0
Aug 30 22:48:06 gangster ppp[1132]: Phase: deflink: Created in closed state
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set cd 5
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set dial
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set login
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set authname malor
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set authkey ********
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set redial 30 999
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set reconnect 30 999
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: enable lqr
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: accept lqr
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: set timeout 0
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: disable PAP deflate pred1 protocomp vjcomp dns
Aug 30 22:48:06 gangster ppp[1132]: tun0: Command: pppoe-out: deny PAP deflate pred1 protocomp vjcomp dns
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: PPP Started (ddial mode).
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: bundle: Establish
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: closed -> opening
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: Connected!
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: opening -> dial
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: dial -> carrier
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: Received NGM_PPPOE_ACNAME (hook "sttkgw.infy.ru")
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: Received NGM_PPPOE_SESSIONID
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: Received NGM_PPPOE_SUCCESS
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: carrier -> login
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: login -> lcp
Aug 30 22:48:06 gangster ppp[1134]: tun0: Warning: deflink: Reducing configured MRU from 1500 to 1492
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: bundle: Authenticate
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: his = CHAP 0x05, mine = none
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: Chap Input: CHALLENGE (42 bytes)
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: Chap Output: RESPONSE (malor)
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: Chap Input: SUCCESS (Welcome)
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: lcp -> open
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: bundle: Network
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: FSM: Using "deflink" as a transport
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: State change Initial --> Closed
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: LayerStart.
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: SendConfigReq(1) state = Closed
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP:  IPADDR[6] 127.0.0.1
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: State change Closed --> Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: RecvConfigReq(87) state = Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP:  IPADDR[6] 83.69.21.1
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP:  COMPPROTO[6] 16 VJ slots without slot compression
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: SendConfigRej(87) state = Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: RecvConfigNak(1) state = Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP:  IPADDR[6] 83.69.21.84
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP:  IPADDR[6] changing address: 127.0.0.1  --> 83.69.21.84
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: SendConfigReq(2) state = Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: Phase: deflink: IPV6CP protocol reject closes IPV6CP !
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: RecvConfigReq(88) state = Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: SendConfigAck(88) state = Req-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: State change Req-Sent --> Ack-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: RecvConfigAck(2) state = Ack-Sent
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: State change Ack-Sent --> Opened
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: deflink: LayerUp.
Aug 30 22:48:06 gangster ppp[1134]: tun0: IPCP: myaddr 83.69.21.84 hisaddr = 83.69.21.1
Aug 30 22:48:18 gangster last message repeated 4 times
Смущают всего больше строки :
#ifconfig
# ifconfig
rl0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
     options=8<VLAN_MTU>
     ether 00:e0:4c:00:26:72
     media: Ethernet autoselect (10baseT/UTP)
     status: no carrier
vr0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
     inet 192.168.1.160 netmask 0xffffff00 broadcast 192.168.1.255
     ether 00:30:18:55:11:2e
     media: Ethernet autoselect (100baseTX <full-duplex>)
     status: active
plip0: flags=108810<POINTOPOINT,SIMPLEX,MULTICAST,NEEDSGIANT> mtu 1500
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
     inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
     inet6 ::1 prefixlen 128
     inet 127.0.0.1 netmask 0xff000000
tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1460
Что делать?
FreeBSD 6.2
Edited by malor
