Yaten Posted September 22, 2006 Posted September 22, 2006 А всетаки они (правила) и правда не работают на icmp.... вот конфиг. и с компа подключающегося через VPN пингуется все что за Virtual-temlate 1 eth 0/0 смотрит на клиентов eth 1/0 смотрит на NAT 192.168.1.1 , а НАТ в интернет. конфиг: Building configuration... Current configuration : 2366 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! enable secret 5 enable password ! aaa new-model ! ! aaa authentication ppp default group radius aaa authorization exec default local aaa authorization network default group radius aaa accounting network default start-stop group radius aaa session-id common ip subnet-zero no ip rcmd domain-lookup ip rcmd rsh-enable ip rcmd remote-host admin 172.16.0.2 admin enable ! ! ip cef ! ip audit po max-events 1000 vpdn enable ! vpdn-group 1 ! Default PPTP VPDN group accept-dialin protocol pptp virtual-template 1 ! ! ! ! ! ! ! ! ! ! ! ! ! username admin privilege 8 password 0 ! ! ! ! ! ! interface Ethernet0/0 ip address 172.16.0.1 255.255.0.0 half-duplex no cdp enable ! interface Ethernet1/0 ip address 192.168.1.3 255.255.255.0 ip route-cache flow half-duplex no cdp enable ! interface Virtual-Template1 ip address 172.17.0.1 255.255.0.0 ip access-group 109 in ip access-group 110 out ip route-cache flow ip tcp header-compression ip mroute-cache no peer default ip address ppp authentication ms-chap-v2 ! no ip http server no ip http secure-server ip classless ip route 0.0.0.0 0.0.0.0 192.168.1.1 ! ! ip radius source-interface Ethernet0/0 access-list 105 dynamic test1 permit ip any any access-list 106 dynamic test2 permit ip any any access-list 107 permit icmp any host 172.16.0.1 access-list 107 permit tcp any any eq domain access-list 107 permit udp any any eq domain access-list 107 permit ip host 172.16.0.2 host 172.16.0.1 access-list 107 permit tcp any host 172.16.0.1 eq 1723 access-list 107 permit gre any any access-list 107 deny ip any any access-list 108 permit icmp host 172.16.0.1 any access-list 108 permit tcp any eq domain any access-list 108 permit tcp any eq domain any access-list 108 permit ip host 172.16.0.1 host 172.16.0.2 access-list 108 permit tcp host 172.16.0.1 eq 1723 any access-list 108 permit gre any any access-list 108 deny ip any any access-list 109 deny ip any any access-list 110 deny ip any any no cdp run ! radius-server host 172.16.0.2 auth-port 1812 acct-port 1813 radius-server key ! ! ! ! ! line con 0 line aux 0 line vty 0 4 password ! ! end Вставить ник Quote
Nailer Posted September 22, 2006 Posted September 22, 2006 А всетаки они (правила) и правда не работают на icmp.... вот конфиг. и с компа подключающегося через VPN пингуется все что за Virtual-temlate 1 eth 0/0 смотрит на клиентов eth 1/0 смотрит на NAT 192.168.1.1 , а НАТ в интернет. конфиг: Building configuration... Current configuration : 2366 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! enable secret 5 enable password ! aaa new-model ! ! aaa authentication ppp default group radius aaa authorization exec default local aaa authorization network default group radius aaa accounting network default start-stop group radius aaa session-id common ip subnet-zero no ip rcmd domain-lookup ip rcmd rsh-enable ip rcmd remote-host admin 172.16.0.2 admin enable ! ! ip cef ! ip audit po max-events 1000 vpdn enable ! vpdn-group 1 ! Default PPTP VPDN group accept-dialin protocol pptp virtual-template 1 ! ! ! ! ! ! ! ! ! ! ! ! ! username admin privilege 8 password 0 ! ! ! ! ! ! interface Ethernet0/0 ip address 172.16.0.1 255.255.0.0 half-duplex no cdp enable ! interface Ethernet1/0 ip address 192.168.1.3 255.255.255.0 ip route-cache flow half-duplex no cdp enable ! interface Virtual-Template1 ip address 172.17.0.1 255.255.0.0 ip access-group 109 in ip access-group 110 out ip route-cache flow ip tcp header-compression ip mroute-cache no peer default ip address ppp authentication ms-chap-v2 ! no ip http server no ip http secure-server ip classless ip route 0.0.0.0 0.0.0.0 192.168.1.1 ! ! ip radius source-interface Ethernet0/0 access-list 105 dynamic test1 permit ip any any access-list 106 dynamic test2 permit ip any any access-list 107 permit icmp any host 172.16.0.1 access-list 107 permit tcp any any eq domain access-list 107 permit udp any any eq domain access-list 107 permit ip host 172.16.0.2 host 172.16.0.1 access-list 107 permit tcp any host 172.16.0.1 eq 1723 access-list 107 permit gre any any access-list 107 deny ip any any access-list 108 permit icmp host 172.16.0.1 any access-list 108 permit tcp any eq domain any access-list 108 permit tcp any eq domain any access-list 108 permit ip host 172.16.0.1 host 172.16.0.2 access-list 108 permit tcp host 172.16.0.1 eq 1723 any access-list 108 permit gre any any access-list 108 deny ip any any access-list 109 deny ip any any access-list 110 deny ip any any no cdp run ! radius-server host 172.16.0.2 auth-port 1812 acct-port 1813 radius-server key ! ! ! ! ! line con 0 line aux 0 line vty 0 4 password ! ! end А при чем тут icmp? Вставить ник Quote
Yaten Posted September 25, 2006 Author Posted September 25, 2006 А при чем тут icmp? а при том что interface Virtual-Template1ip address 172.17.0.1 255.255.0.0 ip access-group 109 in ip access-group 110 out и access-list 109 deny ip any anyaccess-list 110 deny ip any any т.е. запрещены все, а пинги бегают. кроме пигнов, ничего не бегает. tcp, udp и все остальные (надеюсь что остальные, не проверял) заблокированны. Вставить ник Quote
zander Posted September 28, 2006 Posted September 28, 2006 cisco(config)#access-list 199 deny ? <0-255> An IP protocol number ahp Authentication Header Protocol eigrp Cisco's EIGRP routing protocol esp Encapsulation Security Payload gre Cisco's GRE tunneling icmp Internet Control Message Protocol igmp Internet Gateway Message Protocol igrp Cisco's IGRP routing protocol ip Any Internet Protocol ipinip IP in IP tunneling nos KA9Q NOS compatible IP over IP tunneling ospf OSPF routing protocol pcp Payload Compression Protocol pim Protocol Independent Multicast tcp Transmission Control Protocol udp User Datagram Protocol ------ cat /etc/protocols | grep icmp icmp 1 ICMP # internet control message protocol cat /etc/protocols | grep ip ip 0 IP # internet protocol, pseudo protocol number ---- наверно надо дописать access-list 109 deny icmp any any access-list 110 deny icmp any any Вставить ник Quote
