TheUser Posted September 7, 2006 Posted September 7, 2006 Не хочет заводиться PPPoE сервер. На ядре 2.4.32 все работает на ура. В логи пишет RADATTR plugin removed file /var/run/radattr.ppp0. Plugin rp-pppoe.so loaded. RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3 Plugin radius.so loaded. RADIUS plugin initialized. Plugin radattr.so loaded. RADATTR plugin initialized. Plugin radrealms.so loaded. RADIUS Realms plugin initialized. using channel 5 Using interface ppp0 Connect: ppp0 <--> /dev/pts/9 sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] rcvd [LCP ConfReq id=0x2 <mru 1480> <magic 0x2919343f> <callback CBCP>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] rcvd [LCP ConfReq id=0x4 <mru 1480> <magic 0x2919343f> <callback CBCP>] sent [LCP ConfRej id=0x4 <callback CBCP>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] rcvd [LCP ConfReq id=0x6 <mru 1480> <magic 0x2919343f> <callback CBCP>] sent [LCP ConfRej id=0x6 <callback CBCP>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] sent [LCP ConfReq id=0x1 <mru 1490> <auth chap MD5> <magic 0x3dffbc0b>] rcvd [LCP ConfReq id=0x8 <mru 1480> <magic 0x2919343f> <callback CBCP>] sent [LCP ConfRej id=0x8 <callback CBCP>] LCP: timeout sending Config-Requests Connection terminated. using channel 6 Using interface ppp0 Connect: ppp0 <--> /dev/pts/10 Waiting for 2 child processes... script /usr/sbin/pppoe -n -I eth0 -e 1:00:13:d3:a1:ca:66 -S 'GOLOS', pid 6623 script /usr/sbin/pppoe -n -I eth0 -e 1:00:13:d3:a1:ca:66 -S 'GOLOS', pid 6585 sent [LCP ConfReq id=0x2 <mru 1490> <auth chap MD5> <magic 0x54ef0ed7>] sent [LCP ConfReq id=0x2 <mru 1490> <auth chap MD5> <magic 0x54ef0ed7>] sending SIGTERM to process 6623 sending SIGTERM to process 6585 tcflush failed: Bad file descriptor RADATTR plugin removed file /var/run/radattr.ppp0. Подобная проблема встречалась ранее на ядре 2.4, но вылечилось сборкой ppp из исходников. Сейчас же пересборка ядра с PPPoE и без него, установка разных версий ppp и rp-pppoe не помогает. Пробовал перенести все ppp* бинарики с другой машины - не помогло. Пробовал убирать IP с карты - без толку. Что еще стоит пробовать именно для ядра 2.6 ??? Вставить ник Quote
TheUser Posted September 8, 2006 Author Posted September 8, 2006 Помогло полное удаление пакетов rp-pppoe, ppp, повторное скачивание последних версий и пересборка. После этого все замечательно завелось... В чем была проблема - не понимаю... Вроде ранее все так и делал... Невнимательность, блин. Вставить ник Quote
