4 месяца назад взял партию DWL-3200 (продукт неплохой стабилнее чем 2100 тем более что последние 2100 поставляются в сильно урезанном варианте) конечно проблемы как у всех power 13.5 - тем не менее неделю назад взял ещё партию 3200 (уже предустановлена ипрошивка 2.20) и...
power ... 21
==============конфа старой точки
D-Link Access Point wlan1 -> get config
wlan1 revisions: mac 5.8 phy 4.4 analog 4.6
PCI Vendor ID: 0x168c, Device ID: 0x13
Sub Vendor ID: 0x168c, Sub Device ID: 0x13
chip is AR2312
Country Code: GB
Operation Mode: Access Point
Wlan State: Enabled
Radio Frequency: 2427 MHz (IEEE 4)
Wireless LAN Mode: 802.11g
Auto Channel Select: Disabled
Extended Channel Mode: Enabled
Data Rate: best
Antenna: best
Login Username: admin
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: SSZZ
SSID Suppress Mode: Disabled
System Name: D-Link Access Point
Beacon Interval: 100
DTIM: 1
Fragmentation Threshold: 2346
RTS/CTS Threshold: 2346
Short Preamble: Enabled
11g Only Allowed: Disabled
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
11g Overlapping BSS Protection: Disabled
11g Beacon Rate: 1 Mbps
11g Draft 5.0 compatibility: Disabled
Short Slot Time: Enabled
Basic 11g Rate Set: (1, 2, 5.5, 11)
11g Optimization Level: 1
Burst Time: 2
Burst Sequence Threshold: 3
IP Address: 192.168.1.77
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: 192.168.1.1
SNTP/NTP Server IP Address:
Time Zone: 27
HW Transmit Retry Limit: 4
SW Transmit Retry Limit: 3
TransmitPower: full
Current Transmit Output Power 13.5 dBm
SuperG :Disabled
Encryption: Disabled
Cipher selection: WEP
Authentication Type: Open-System
Default transmit key: 1
Shared Key 1, size 40, 0000000000
Access Check: Disabled
Key Entry Method: hexadecimal
Group Key Update Interval: 1800 seconds
Key Source: flash
Aging Interval: 300 seconds
Telnet Access: Enabled
Telnet Timeout: 180 seconds
Minimum rate: 1 Mbps
XR Poll interval: 100 msec
XR Frame Limit: 25
XR Poll Rate String is 0.25 1 1 3 3 6 6 20
XR Fragmentation Threshold: 540
==============конфа новой точки
D-Link Access Point login: admin
Password: *****
Wireless Driver Rev 4.0.0.167
chip is AR2312
Country Code: AU
Wlan State: Enabled
Data Rate: best
Antenna: best
RADIUS address:
SSID: SSZZ
DTIM: 1
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
Burst Time: 2
IP Address: 192.168.1.78
Time Zone: 27
TransmitPower: full
Current Transmit Output Power 21.0 dBm
SuperG :Disabled
Key Source: flash
XR Frame Limit: 25
Интересно можно-ли перетащить tyne прошивочку с новых точек в мои старые
что вы все как дети... 2100 от 3200 отличается только корпусом и модулем PoE и прошивкой. причем последнее лечится легко.
и мощность тоже
поиск то потыкай
и мощность тоже
поиск то потыкай
Ненадо - первые 2100 согласен 1 в 1 только бери выводи вторую антенну
а как сертификацию прошли - так урезали (на плате половина элементов отсутствует) - второй передатчик полностью сняли - виснут - горят (тоесть сделали дешёвый ширпотреб)
и насчёт инженерного доступа - сопротивляется - наверно в прошивке 2.20 - он другой - или входить надо иначе
......... так урезали .................. второй передатчик полностью сняли ...................
какой второй передатчик.... мы с разных планет?
а инженерное меню... да перешей ты ее в версию помладше и вот оно - меню
зачем шить в помладше ?
ap wlan1 -> get runtime
RUNTIME_VERSION: DWL-3200AP DWL3200AP.v220.r0476.t567us
ap wlan1 -> alpha
Password-> ********
Ok
ap wlan1 ->
значит даже и не надо.. просто были слухи про то что есть прошивка из новых, которая не жрет стандартный пароль.
и лечилась понижением версии
