Здравствуте, если кто сталкивался с настройкой UTM5 + MPD поможите плиз, всё почти работает, но при конекте юзера на этапе регистрация компьютера в сети происходит следующая ошибка:
Ошибка: 734 Протокол управления РРР-связью был прерван.
В логах мпд следующее:
Jul 11 11:29:02 mail mpd: [link0] RADIUS: RadiusAccount for: test
Jul 11 11:29:02 mail mpd: [link0] RADIUS: using /etc/radius.conf
Jul 11 11:29:02 mail mpd: [link0] RADIUS: RadiusAddServer Adding 127.0.0.1
Jul 11 11:29:02 mail mpd: [link0] RADIUS: Termination cause: Protocol error:PPP layer IPCP failed: parameter negotiation failed, RADIUS: 15
Jul 11 11:29:02 mail mpd: [link0] RADIUS: RadiusAccount: Sending accounting data (Type: 2)
Jul 11 11:29:02 mail mpd: [link0] RADIUS: RadiusSendRequest: RAD_ACCOUNTING_RESPONSE for user test
Jul 11 11:29:02 mail mpd: [pptp0] setting interface ng0 MTU to 1500 bytes
Jul 11 11:29:02 mail mpd: [pptp0] up: 0 links, total bandwidth 9600 bps
Jul 11 11:29:02 mail mpd: [link0] RADIUS: Down Event
Jul 11 11:29:02 mail mpd: [pptp0] IPCP: Down event
Jul 11 11:29:02 mail mpd: [pptp0] IPCP: state change Stopped --> Starting
Jul 11 11:29:02 mail mpd: [pptp0] IPCP: LayerStart
Jul 11 11:29:02 mail mpd: [pptp0] CCP: Down event
Jul 11 11:29:02 mail mpd: [pptp0] CCP: state change Req-Sent --> Starting
Jul 11 11:29:02 mail mpd: [pptp0] CCP: Close event
Jul 11 11:29:02 mail mpd: [pptp0] CCP: state change Starting --> Initial
Jul 11 11:29:02 mail mpd: [pptp0] CCP: LayerFinish
Jul 11 11:29:02 mail mpd: [pptp0] closing link "link0"...
Jul 11 11:29:02 mail mpd: [link0] LCP: SendTerminateReq #60
Jul 11 11:29:02 mail mpd: [link0] LCP: LayerDown
Jul 11 11:29:02 mail mpd: [link0] rec'd proto IPCP during terminate phase
Jul 11 11:29:02 mail mpd: [pptp0] bundle: OPEN event in state CLOSED
Jul 11 11:29:02 mail mpd: [pptp0] opening link "link0"...
Jul 11 11:29:02 mail mpd: [link0] link: CLOSE event
Jul 11 11:29:02 mail mpd: [link0] LCP: Close event
Jul 11 11:29:02 mail mpd: [link0] rec'd proto CCP during terminate phase
Jul 11 11:29:02 mail mpd: [link0] link: OPEN event
Jul 11 11:29:02 mail mpd: [link0] LCP: Open event
Jul 11 11:29:02 mail mpd: [link0] LCP: state change Closing --> Stopping
Jul 11 11:29:03 mail mpd: [link0] rec'd proto CCP during terminate phase
Jul 11 11:29:04 mail mpd: [link0] LCP: SendTerminateReq #61
Jul 11 11:29:04 mail mpd: [link0] LCP: rec'd Terminate Ack #61 link 0 (Stopping)
Jul 11 11:29:04 mail mpd: [link0] LCP: state change Stopping --> Stopped
Jul 11 11:29:04 mail mpd: [link0] LCP: phase shift TERMINATE --> ESTABLISH
Jul 11 11:29:04 mail mpd: [link0] LCP: LayerFinish
Jul 11 11:29:04 mail mpd: [link0] device: CLOSE event in state UP
Jul 11 11:29:04 mail mpd: pptp0-0: clearing call
Jul 11 11:29:04 mail mpd: pptp0-0: killing channel
Jul 11 11:29:04 mail mpd: [link0] PPTP call terminated
Jul 11 11:29:04 mail mpd: [pptp0] IFACE: Close event
Jul 11 11:29:04 mail mpd: [pptp0] IPCP: Close event
Jul 11 11:29:04 mail mpd: [pptp0] IPCP: state change Starting --> Initial
Jul 11 11:29:04 mail mpd: [pptp0] IPCP: LayerFinish
Jul 11 11:29:04 mail mpd: pptp0: closing connection with 10.0.10.4:2507
Jul 11 11:29:04 mail mpd: [link0] device is now in state CLOSING
Jul 11 11:29:04 mail mpd: pptp0: CID 0xb4ec in SetLinkInfo not found
Jul 11 11:29:04 mail mpd: [pptp0] bundle: CLOSE event in state OPENED
Jul 11 11:29:04 mail mpd: [pptp0] closing link "link0"...
Jul 11 11:29:04 mail mpd: [link0] device: DOWN event in state CLOSING
Jul 11 11:29:04 mail mpd: [link0] device is now in state DOWN
Jul 11 11:29:04 mail mpd: [link0] link: CLOSE event
Jul 11 11:29:04 mail mpd: [link0] LCP: Close event
Jul 11 11:29:04 mail mpd: [link0] LCP: state change Stopped --> Closed
Jul 11 11:29:04 mail mpd: [link0] device: DOWN event in state DOWN
Jul 11 11:29:04 mail mpd: pptp0: killing connection with 10.0.10.4:2507
Jul 11 11:29:04 mail mpd: [link0] link: DOWN event
Jul 11 11:29:04 mail mpd: [link0] LCP: Down event
Jul 11 11:29:04 mail mpd: [link0] LCP: state change Closed --> Initial
Jul 11 11:29:04 mail mpd: [link0] LCP: phase shift ESTABLISH --> DEAD
Судя по всему мпд не получает от радиуса ip адрес впн клиента, и рвёт соединенеие, вопрос де данный ип?
Лог радиуса:
?Debug : Jul 11 11:37:04 RADIUS Auth: Calculated maximum session time: 72000
?Debug : Jul 11 11:37:04 RADIUS Auth: IP from Named Pool second claimed: 0xa000a3c
?Debug : Jul 11 11:37:04 RADIUS DBA: dialup_link_update called for slink:5
?Debug : Jul 11 11:37:04 RADIUS DBA: soft dialup_link_update for slink:5 session_count:58
?Debug : Jul 11 11:37:04 RADIUS Auth: Calling fill radius attributes for NAS. Attr storage size <0>
?Debug : Jul 11 11:37:04 RADIUS Acct: Acct packet with session ID: 2596188-link0
?Debug : Jul 11 11:37:04 RADIUS Acct: Acct-Stop packet
?Debug : Jul 11 11:37:04 RADIUS Acct: No h323_disconnect_cause in packet!
Info : Jul 11 11:37:04 UT: session_addon <0>
Info : Jul 11 11:37:04 UT: tel tarification for slink 5, tr_id 1, mult 10.000000, next 1152596235
Info : Jul 11 11:37:04 UT: cost info:
Info : Jul 11 11:37:04 UT: type 0 deny 0 base_cost 1.000000 size 47 tr_id 1 mult 10.000000 added 0 sum 0.000000
?Debug : Jul 11 11:37:04 RADIUS DBA: Dialup Discount: TR ID 1: 0.131 for 47 sec
?Debug : Jul 11 11:37:04 RADIUS URFA[plugin]: Account <2> with balance <4168.856>
Вот конфиг мпд:
# cat mpd.conf
default:
load vpn0
vpn0:
new -i ng0 pptp0 link0
set ipcp ranges 172.16.0.1/32 172.16.0.16/32
load vpn_conf
vpn_conf:
set bundle enable multilink
set bundle yes crypt-reqd
set bundle no encryption multilink
set bundle enable compression
set link yes acfcomp protocomp
set link no pap chap
set link enable chap
set link keep-alive 1800 2600
set link mtu 1460
set link mru 1460
set link max-redial -1
set ipcp yes vjcomp
set iface enable proxy-arp
set iface disable on-demand
set iface idle 1800
set iface enable tcpmssfix
set ccp yes mppc
set ccp yes mpp-e40
set ccp yes mpp-e56
set ccp yes mpp-e128
set ccp yes mpp-compress
set ccp yes mpp-stateles
set pptp enable incoming
set pptp disable originate
set pptp enable delayed-ack
log +auth
set radius server 127.0.0.1 secret 1812 1813
set radius timeout 10
set radius config /etc/radius.conf
set radius retries 3
set radius acct-update 60
set bundle enable radius-auth
set bundle enable radius-acct
set ipcp enable radius-ip
#set ipcp nbns ххххх Винс.
заранее спасибо.
Пришлите результат вывода
tcpdump -nvvi lo -s 0 port 1812
А также проверьте secret на сервере доступа и в радиусе
Edited by mevg
можно также попробовать поменять местами 1812 и 1813
вот здесь: set radius server 127.0.0.1 secret 1812 1813
Нет не помогло, наоборот, теперь он даже пароль не принимает, а отваливается по таймауту, в логах видно что мпд пытается зацепиться к радиусу, а ответа нет, если же всё оставать как есть то авторизация проходит на ура, а вот ип получить не могу :((
речь идет об УТМ радиусе ?
да, на сколько я понял подружить нетуп со сторонним радиусом незя. Edited by catalist
На мои наводящие вопросы так никто и не ответил
Прошу прощения, просто замордовался я тут с другими делами и на форум давно не заходил, теперь по делу:
Вот листинг:
13:49:44.099068 IP (tos 0x0, ttl 64, id 39047, offset 0, flags [none], length: 192) 127.0.0.1.46372 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
Access Request (1), id: 0x39, Authenticator: 66c1f0e1e71adf01ba3fbdb7f31f6d6e
NAS ID Attribute (32), length: 17, Value: xxxxxxxxx
0x0000: 6d61 696c 2e6e 7572 6775 7368 2e72 75
NAS Port Attribute (5), length: 6, Value: 0
0x0000: 0000 0000
NAS Port Type Attribute (61), length: 6, Value: Virtual
0x0000: 0000 0005
Service Type Attribute (6), length: 6, Value: Framed
0x0000: 0000 0002
Framed Protocol Attribute (7), length: 6, Value: PPP
0x0000: 0000 0001
Calling Station Attribute (31), length: 15, Value: xxxxxxxxx
0x0000: 3830 2e38 352e 3134 342e 3130 34
Username Attribute (1), length: 6, Value: test
0x0000: 7465 7374
Vendor Specific Attribute (26), length: 24, Value: Vendor: Microsoft (311)
Vendor Attribute: 11, Length: 18, Value: ..hs.2...S....P..:
0x0000: 0000 0137 0b12 bb1e 6873 0d32 15b6 ea53
0x0010: f5a3 e1df 50c7
Vendor Specific Attribute (26), length: 58, Value: Vendor: Microsoft (311)
0x0000: 0000 0137 1934 0100 230a 8f6e 4a95 6ad6
0x0010: 4269 c3b0 5c58 d268 0000 0000 0000 0000
0x0020: 270d 1d1e c5e0 0b0d b33e fe91 708e 9b0a
0x0030: fb73 eeb4 2753 ccad
13:49:44.112539 IP (tos 0x0, ttl 64, id 39072, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.46372: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0x39, Authenticator: 85868249118c50e705bd0cd1feffee3a
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.39
0x0000: 0a00 0a27
Framed IP Network Attribute (9), length: 6, Value: 255.255.255.255
0x0000: ffff ffff
Framed Routing Attribute (10), length: 6, Value: None
0x0000: 0000 0000
Framed Compression Attribute (13), length: 6, Value: None
0x0000: 0000 0000
Session Timeout Attribute (27), length: 6, Value: 20:00:00 hours
0x0000: 0001 1940
Vendor Specific Attribute (26), length: 12, Value: Vendor: Microsoft (311)
Vendor Attribute: 7, Length: 6, Value: ......
0x0000: 0000 0137 0706 0000 0001
Vendor Attribute: 8, Length: 6, Value: .....*
0x0000: 0000 0137 0806 0000 0006
Vendor Specific Attribute (26), length: 42, Value: Vendor: Microsoft (311)
Vendor Attribute: 16, Length: 36, Value: .Q.{...6.1.q..h.".a......&...0.JoW.*
0x0000: 0000 0137 1024 8b51 b37b 9baf 1536 b431
0x0010: 0d71 c9f0 6895 2287 610d eda3 e8a5 de26
0x0020: 0212 a430 084a 6f57
Vendor Attribute: 17, Length: 36, Value: .....t.>YR..O....Y.Ho>.nXXfvy6X.Z3.3
0x0000: 0000 0137 1124 8385 c49e 9174 923e 5952
0x0010: b7cf 4f04 9799 d859 0448 6f3e ca6e 5858
0x0020: 6676 7936 58bf 5a33
Vendor Specific Attribute (26), length: 51, Value: Vendor: Microsoft (311)
0x0000: 0000 0137 1a2d 8153 3d32 3441 3731 3130
0x0010: 4236 3846 4242 3046 4544 3735 3631 3435
0x0020: 4236 4232 3431 4135 4634 4435 3444 4138
0x0030: 31
13:49:56.500458 IP (tos 0x0, ttl 64, id 39161, offset 0, flags [none], length: 192) 127.0.0.1.48647 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
Access Request (1), id: 0xec, Authenticator: b5f7a4972b7f7ff3ce3fd1a5a5e2b28b
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
Vendor Attribute: 11, Length: 18, Value: ..h.$.R.....Z....:
0x0000: 0000 0137 0b12 bb1e 68ea 24bc 521a d6ce
0x0010: cb01 5a97 b51b
0x0000: 0000 0137 1934 0100 fd0c fe2b 6887 993b
0x0010: 51e3 8ab0 8e2b fbc7 0000 0000 0000 0000
0x0020: f302 92d0 d4d2 4ea1 0e48 ef26 4c01 2629
0x0030: a125 f7d3 41c8 a035
13:49:56.515470 IP (tos 0x0, ttl 64, id 39186, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.48647: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0xec, Authenticator: bf1d14328db0ae1a11a4b8f56ba69354
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.23
0x0000: 0a00 0a17
0x0000: ffff ffff
0x0000: 0000 0000
0x0000: 0000 0000
0x0000: 0001 1940
Vendor Attribute: 16, Length: 36, Value: ..iu..w,..'...3%...+...U....HI+....*
0x0000: 0000 0137 1024 8e8c 6975 a9ff 772c cdfd
0x0010: 27ee b5e2 3325 9cc3 cb2b baa3 af55 f6ab
0x0020: 1791 4849 2bfd 0b14
Vendor Attribute: 17, Length: 36, Value: ....f.vO.B!...]M.....S...OwO..!%y..3
0x0000: 0000 0137 1124 8edb eea7 6696 764f 0442
0x0010: 21e8 88e1 5d4d a8e0 b4f4 9053 1599 0f4f
0x0020: 774f b3e5 2125 79fa
0x0000: 0000 0137 1a2d 8153 3d38 3142 4235 3439
0x0010: 3631 3732 3645 3031 3043 4536 4345 4542
0x0020: 4136 3137 3335 3542 3144 3636 4541 4546
0x0030: 36
13:49:56.515703 IP (tos 0x0, ttl 64, id 39187, offset 0, flags [none], length: 192) 127.0.0.1.48647 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
13:49:56.520824 IP (tos 0x0, ttl 64, id 39211, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.48647: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0xec, Authenticator: d5156db80cbd7cd3078cc2cc2f82bb42
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.40
0x0000: 0a00 0a28
0x0000: ffff ffff
0x0000: 0000 0000
0x0000: 0000 0000
0x0000: 0001 1940
Vendor Attribute: 16, Length: 36, Value: ...^..+3d─.c.....K`...zx!../.......*
0x0000: 0000 0137 1024 81f0 8c5e bda5 2b33 6480
0x0010: 0d63 ca82 06c8 fc4b 60f5 97a2 7a78 21bd
0x0020: 812f 9ea8 b518 1710
Vendor Attribute: 17, Length: 36, Value: .{..`..$t....w..{..:..J.......^.gQ.3
0x0000: 0000 0137 1124 8e7b a00f 60cd 1924 74e4
0x0010: aaf8 b077 e899 7bd4 f43a 1203 4a0b d2d1
0x0020: 90aa af8d 5e86 6751
0x0030: 36
13:49:56.521094 IP (tos 0x0, ttl 64, id 39212, offset 0, flags [none], length: 192) 127.0.0.1.48647 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
13:49:56.524871 IP (tos 0x0, ttl 64, id 39236, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.48647: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0xec, Authenticator: 76744b72b2dcabf7b5717530e61ae181
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.41
0x0000: 0a00 0a29
0x0000: ffff ffff
0x0000: 0000 0000
0x0000: 0000 0000
0x0000: 0001 1940
Vendor Attribute: 16, Length: 36, Value: .....F .'.l.\..I.ui.. .c.V....'....*
0x0000: 0000 0137 1024 8dea 9e1a 9546 20a2 27f8
0x0010: 6cd6 5c9e 1049 e875 691e b320 8b63 f856
0x0020: e3f4 0f14 27b6 b097
Vendor Attribute: 17, Length: 36, Value: .|=...o....N...F....."m......&~..C.3
0x0000: 0000 0137 1124 8c7c 3ded d7cf 6fa1 da13
0x0010: bf4e 98cc 8446 b4e8 9ea3 f522 6d84 f5c8
0x0020: b0d9 8726 7ee1 9b43
0x0030: 36
13:50:05.527792 IP (tos 0x0, ttl 64, id 39320, offset 0, flags [none], length: 192) 127.0.0.1.48647 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
13:50:05.541260 IP (tos 0x0, ttl 64, id 39345, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.48647: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0xec, Authenticator: 1196ff88ef04b4621266d6a8f0c6bcaa
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.42
0x0000: 0a00 0a2a
0x0000: ffff ffff
0x0000: 0000 0000
0x0000: 0000 0000
0x0000: 0001 1940
Vendor Attribute: 16, Length: 36, Value: .65.'..c.B..+.ob....Eg.^R...─.PSL:.*
0x0000: 0000 0137 1024 8936 3506 27e9 9563 d542
0x0010: e9d1 2bd1 6f62 cca5 f9f6 4567 e65e 529c
0x0020: cd84 80d4 5053 4c3a
Vendor Attribute: 17, Length: 36, Value: ...-k.x|}..`Kj...J."....g..........3
0x0000: 0000 0137 1124 81f7 c62d 6b16 787c 7d1e
0x0010: e760 4b6a 8dae 0d4a 8522 dcad cd8a 67e7
0x0020: ad91 8509 b89a 15c9
0x0030: 36
13:50:05.649283 IP (tos 0x0, ttl 64, id 39381, offset 0, flags [none], length: 192) 127.0.0.1.42417 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
Access Request (1), id: 0x01, Authenticator: ef4d79cdd912b46723488abfebba2f05
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
13:50:05.663148 IP (tos 0x0, ttl 64, id 39405, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.42417: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0x01, Authenticator: ff477f88ea0c32bc3848795d1d2a5f71
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.43
0x0000: 0a00 0a2b
0x0000: ffff ffff
0x0000: 0000 0000
0x0000: 0000 0000
0x0000: 0001 1940
Vendor Attribute: 16, Length: 36, Value: .^Ff............Z.s>.Pzk..%..<._.*
0x0000: 0000 0137 1024 865e 4666 b9da cf1e f1a2
0x0010: fc0f 8aeb dbe2 5ad0 733e c050 7a6b 84ef
0x0020: 7fba 25fd f23c a35f
Vendor Attribute: 17, Length: 36, Value: .^e.....X.|.............W>...vU..=.3
0x0000: 0000 0137 1124 835e 6504 c8de fb01 58c7
0x0010: 7c0c bbc7 ba12 a2ac de8b 99ee eca4 573e
0x0020: ef92 c276 55e9 cc3d
0x0030: 36
13:50:05.663772 IP (tos 0x0, ttl 64, id 39406, offset 0, flags [none], length: 192) 127.0.0.1.42417 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
13:50:05.668901 IP (tos 0x0, ttl 64, id 39430, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.42417: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0x01, Authenticator: 0499d48d5ca19fbdf75e1ea76a5b15ad
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.44
0x0000: 0a00 0a2c
0x0000: ffff ffff
0x0000: 0000 0000
0x0000: 0000 0000
0x0000: 0001 1940
Vendor Attribute: 16, Length: 36, Value: .e&X..Gk.7x)...../w.Y─/p'>5C..S..*
0x0000: 0000 0137 1024 8e65 2658 a5a5 476b bb37
0x0010: 7829 95eb dc82 c52f 77fd 9d7f 5980 2f70
0x0020: 273e 3543 1b9e 53a1
Vendor Attribute: 17, Length: 36, Value: .!....@_....@..l_.....U..C.2d......3
0x0000: 0000 0137 1124 8521 18df 0ee8 405f c591
0x0010: e3fa 401d b66c 5fec be9d d013 55c3 8343
0x0020: f632 64e9 84ca 8fef
0x0030: 36
13:50:05.669013 IP (tos 0x0, ttl 64, id 39431, offset 0, flags [none], length: 192) 127.0.0.1.42417 > 127.0.0.1.1812: [udp sum ok] RADIUS, length: 164
0x0000: 0000 0000
0x0000: 0000 0005
0x0000: 0000 0002
0x0000: 0000 0001
0x0000: 7465 7374
13:50:05.674908 IP (tos 0x0, ttl 64, id 39455, offset 0, flags [none], length: 249) 127.0.0.1.1812 > 127.0.0.1.42417: [udp sum ok] RADIUS, length: 221
Access Accept (2), id: 0x01, Authenticator: 1ddf831cbd504c6273626ebaa1a81bc8
0x0000: 0000 0002
0x0000: 0000 0001
Framed IP Address Attribute (8), length: 6, Value: 10.0.10.45
0x0000: 0a00 0a2d
0x0000: ffff ffff
Приведите вывод команды:
tcpdump -nvvi lo -s 0 port 1813
(порт для аккаунтинга)
23:26:32.291489 IP (tos 0x0, ttl  64, id 42536, offset 0, flags [none], length: 192) 127.0.0.1.38399 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
        Access Request (1), id: 0x92, Authenticator: 5de1feca67eb94f384bbd6c3b4264b68
          NAS ID Attribute (32), length: 17, Value: xxxxxxxxxxxx
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
          Calling Station Attribute (31), length: 15, Value: xxxxxxxxxxxx
            0x0000:  7465 7374
            Vendor Attribute: 11, Length: 18, Value: ..h...)s.4.U.V(..:
            0x0000:  0000 0137 0b12 bb1e 68cb f21c 2973 0134
            0x0010:  9255 d356 2891
            0x0000:  0000 0137 1934 0100 35ff 7376 1368 69ef
            0x0010:  13ab 44ee e3e2 084e 0000 0000 0000 0000
            0x0020:  ecbd 5970 c1a8 9790 c65a 70f9 f463 48fa
            0x0030:  4995 1757 952f 4a6e
23:26:35.292020 IP (tos 0x0, ttl  64, id 42540, offset 0, flags [none], length: 192) 127.0.0.1.38399 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:38.292559 IP (tos 0x0, ttl  64, id 42545, offset 0, flags [none], length: 192) 127.0.0.1.38399 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:41.311624 IP (tos 0x0, ttl  64, id 42578, offset 0, flags [none], length: 164) 127.0.0.1.34763 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 136
        Accounting Request (4), id: 0x8e, Authenticator: 156b6bdd1f58d7800b14912ce3159535
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
          Framed IP Address Attribute (8), length: 6, Value: 10.0.10.28
            0x0000:  0a00 0a1c
          Accounting Status Attribute (40), length: 6, Value: Start
            0x0000:  0000 0001
          Accounting Session ID Attribute (44), length: 15, Value: 3416401-link0
            0x0000:  3334 3136 3430 312d 6c69 6e6b 30
          Accounting Multilink Session ID Attribute (50), length: 15, Value: 3416401-pptp0
            0x0000:  3334 3136 3430 312d 7070 7470 30
          Accounting Link Count Attribute (51), length: 6, Value: 1
            0x0000:  0000 0001
          Accounting Authentication Attribute (45), length: 6, Value: RADIUS
            0x0000:  0000 0001
23:26:41.432893 IP (tos 0x0, ttl  64, id 42611, offset 0, flags [none], length: 48) 127.0.0.1.1813 > 127.0.0.1.34763: [udp sum ok] RADIUS, length: 20
        Accounting Response (5), id: 0x8e, Authenticator: b2f230220f05652c2aa0cd69f7567660
23:26:41.460674 IP (tos 0x0, ttl  64, id 42690, offset 0, flags [none], length: 192) 127.0.0.1.43287 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
        Access Request (1), id: 0x69, Authenticator: ec5d996d97fec9083b782af38f3d9977
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:44.462617 IP (tos 0x0, ttl  64, id 42694, offset 0, flags [none], length: 192) 127.0.0.1.43287 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:47.463210 IP (tos 0x0, ttl  64, id 42699, offset 0, flags [none], length: 192) 127.0.0.1.43287 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:50.495830 IP (tos 0x0, ttl  64, id 42808, offset 0, flags [none], length: 192) 127.0.0.1.33204 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
        Access Request (1), id: 0x5d, Authenticator: 65a29f06fee288920a117a7ce0be3979
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:53.496245 IP (tos 0x0, ttl  64, id 42814, offset 0, flags [none], length: 192) 127.0.0.1.33204 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:56.496790 IP (tos 0x0, ttl  64, id 42819, offset 0, flags [none], length: 192) 127.0.0.1.33204 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:26:59.530348 IP (tos 0x0, ttl  64, id 42927, offset 0, flags [none], length: 192) 127.0.0.1.42104 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
        Access Request (1), id: 0xdf, Authenticator: 1857162997b161b21df58f704ae5a105
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:27:02.530887 IP (tos 0x0, ttl  64, id 42932, offset 0, flags [none], length: 192) 127.0.0.1.42104 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:27:05.532406 IP (tos 0x0, ttl  64, id 42937, offset 0, flags [none], length: 192) 127.0.0.1.42104 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:27:08.565173 IP (tos 0x0, ttl  64, id 43046, offset 0, flags [none], length: 192) 127.0.0.1.32183 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
        Access Request (1), id: 0xfa, Authenticator: 4e0673176670f56f26b781d87b51843d
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:27:11.565494 IP (tos 0x0, ttl  64, id 43052, offset 0, flags [none], length: 192) 127.0.0.1.32183 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:27:14.566135 IP (tos 0x0, ttl  64, id 43056, offset 0, flags [none], length: 192) 127.0.0.1.32183 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 164
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
23:27:17.592210 IP (tos 0x0, ttl  64, id 43089, offset 0, flags [none], length: 199) 127.0.0.1.44567 > 127.0.0.1.1813: [udp sum ok] RADIUS, length: 171
        Accounting Request (4), id: 0xcb, Authenticator: 05a4d3e7d1ad2132f8b1ad1521e4aa9d
            0x0000:  0000 0000
            0x0000:  0000 0005
            0x0000:  0000 0002
            0x0000:  0000 0001
            0x0000:  7465 7374
            0x0000:  0a00 0a1c
          Accounting Status Attribute (40), length: 6, Value: Stop
            0x0000:  0000 0002
          Accounting Multilink Session ID Attribute (50), length: 2, Value:
            0x0000:  0000 0001
            0x0000:  0000 0001
          Accounting Termination Cause Attribute (49), length: 6, Value: Service Unavailable
            0x0000:  0000 000f
          Accounting Session Time Attribute (46), length: 6, Value: 47 secs
            0x0000:  0000 002f
          Accounting Input Octets Attribute (42), length: 6, Value: 955
            0x0000:  0000 03bb
          Accounting Input Packets Attribute (47), length: 6, Value: 36
            0x0000:  0000 0024
          Accounting Output Octets Attribute (43), length: 6, Value: 530
            0x0000:  0000 0212
          Accounting Output Packets Attribute (48), length: 6, Value: 22
            0x0000:  0000 0016
          Accounting Input Giga Attribute (52), length: 6, Value: 0
            0x0000:  0000 0000
          Accounting Output Giga Attribute (53), length: 6, Value: 0
            0x0000:  0000 0000
23:27:17.596826 IP (tos 0x0, ttl  64, id 43137, offset 0, flags [none], length: 48) 127.0.0.1.1813 > 127.0.0.1.44567: [udp sum ok] RADIUS, length: 20
        Accounting Response (5), id: 0xcb, Authenticator: 4119d4280f0cdaf7addf0e577dfb2a4c
Всё решил проблему, огромное спасибо, виной была моя не внимательность, баг был в файле /etc/radius.conf
в нём было написано
auth 127.0.0.0.1:1812 secret
auth 127.0.0.0.1:1213 secret
а должно быть:
acct 127.0.0.0.1:1213 secret
наверное по запарке ошибся :).
