За 1 минуту, с внутриноутбучной антенны
Шоб я так жил :-)))
А что у ваших горячих ливанских властей за несанкционированное включение в WiFi?)
Вышел на крышу с ноутом на centrino и kismet внутри:
Network 1: "tsunami" BSSID: "00:40:96:55:A4:82"
Type : infrastructure
Carrier : 802.11g
Info : "Main AP"
Channel : 08
Encryption : "None"
Maxrate : 11.0
Address found via ARP 10.190.0.0
Network 2: "poisk-system" BSSID: "00:11:95:B9:1C:A7"
Carrier : 802.11g
Info : "None"
Channel : 04
Encryption : "PPTP "
Maxrate : 11.0
Address found via ARP 192.168.0.0
Network 3: "Megalogw" BSSID: "00:0F:F7:EB:22:50"
Carrier : 802.11g
Info : "Megalog_Main_AP"
Channel : 05
Encryption : "WPA PPTP "
Maxrate : 11.0
Network 4: "S" BSSID: "00:11:95:E9:96:11"
Carrier : 802.11g
Info : "None"
Channel : 04
Encryption : "None"
Maxrate : 36.0
Address found via TCP 192.168.0.20
Network 5: "ELS_base" BSSID: "00:0D:65:27:AA:A5"
Carrier : 802.11g
Info : "vershina"
Channel : 05
Encryption : "None"
Maxrate : 11.0
Network 6: "<no ssid>" BSSID: "00:40:18:6F:D3:38"
Carrier : 802.11g
Info : "None"
Channel : 07
Encryption : "None"
Maxrate : 18.0
Network 7: "Megaloge" BSSID: "00:40:96:5B:AF:DD"
Carrier : 802.11g
Info : "Megalog East"
Channel : 06
Encryption : "WEP "
Maxrate : 11.0
Address found via TCP 43.167.141.239
Network 8: "<no ssid>" BSSID: "00:40:96:EE:78:11"
Carrier : 802.11g
Info : "None"
Channel : 07
Encryption : "None"
Maxrate : 18.0
Network 9: "<no ssid>" BSSID: "00:40:96:5C:16:68"
Carrier : 802.11g
Info : "UC_10"
Channel : 08
Encryption : "None"
Maxrate : 11.0
Network 10: "<no ssid>" BSSID: "00:12:17:70:DA:23"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 11: "<no ssid>" BSSID: "00:40:96:5C:16:AB"
Carrier : 802.11g
Info : "MegaOffice"
Channel : 05
Encryption : "None"
Maxrate : 11.0
Network 12: "karen" BSSID: "00:11:95:BC:7E:62"
Carrier : 802.11g
Info : "None"
Channel : 04
Encryption : "WPA "
Maxrate : 36.0
Network 13: "<no ssid>" BSSID: "00:12:17:70:DC:25"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 14: "<no ssid>" BSSID: "00:12:17:70:DA:4A"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 15: "<no ssid>" BSSID: "00:40:96:59:6E:03"
Carrier : 802.11g
Info : "GrazhdanProect"
Channel : 05
Encryption : "None"
Maxrate : 11.0
Network 16: "<no ssid>" BSSID: "00:13:46:98:1C:11"
Carrier : 802.11g
Info : "None"
Channel : 11
Encryption : "None"
Maxrate : 11.0
Network 17: "<no ssid>" BSSID: "00:15:2A:3D:18:EE"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 18: "WI-FI" BSSID: "00:40:05:26:E5:91"
Carrier : 802.11g
Info : "None"
Channel : 03
Maxrate : 11.0
Address found via TCP 192.168.1.0
Network 19: "tvk" BSSID: "00:11:95:FB:C0:7F"
Carrier : 802.11g
Info : "None"
Channel : 12
Encryption : "WEP WPA "
Maxrate : 36.0
Network 20: "default" BSSID: "00:0D:88:98:CA:C4"
Carrier : 802.11g
Info : "None"
Channel : 02
Encryption : "None"
Maxrate : 0.0
Address found via UDP 192.168.3.0
Network 21: "Tokyo" BSSID: "00:11:95:8E:C7:89"
Carrier : 802.11g
Info : "None"
Channel : 04
Encryption : "WPA "
Maxrate : 36.0
Address found via TCP 192.168.0.71
Network 22: "cisco46323" BSSID: "00:60:B3:22:71:95"
Carrier : 802.11g
Info : "None"
Channel : 10
Encryption : "None"
Maxrate : 11.0
Network 23: "Ministry" BSSID: "00:15:E9:3F:4C:4C"
Carrier : 802.11g
Info : "None"
Channel : 04
Encryption : "None"
Maxrate : 36.0
Network 24: "<no ssid>" BSSID: "00:15:E9:2B:F0:A8"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 25: "<no ssid>" BSSID: "00:0F:3D:61:5E:9E"
Carrier : 802.11g
Info : "None"
Channel : 01
Encryption : "None"
Maxrate : 18.0
Network 26: "BlackBird" BSSID: "02:0F:3D:61:5E:9F"
Carrier : 802.11g
Info : "None"
Channel : 01
Encryption : "None"
Maxrate : 18.0
Network 27: "_" BSSID: "00:60:B3:22:34:02"
Carrier : 802.11g
Info : "None"
Channel : 10
Encryption : "None"
Maxrate : 11.0
Network 28: "default" BSSID: "00:11:95:FF:FA:00"
Carrier : 802.11g
Info : "None"
Channel : 06
Encryption : "None"
Maxrate : 36.0
Address found via ARP 192.168.0.49
Network 29: "<no ssid>" BSSID: "00:12:17:70:DB:BE"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 30: "<no ssid>" BSSID: "00:12:17:70:DA:DD"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "None"
Maxrate : 0.0
Network 31: "<no ssid>" BSSID: "00:80:48:3C:C1:71"
Carrier : 802.11g
Info : "None"
Channel : 00
Encryption : "WEP "
Maxrate : 0.0
И это только managed здесь :) Всяких ad-hoc`ов еще штук 10 :) Edited by m1jgun
обожаю сразу всех, у кого сеть называется default, на 6 канале и без шифрования.
Весной катался по своему поселку с нотбуком, подъехал к одной проходной - "получение IP адреса, вход в сеть..."
Оказалась сетка техофиса mo47.ru , тоже 6 канал и сеть default. Диски С расшареные на запись, все как положено :)
Потом охрана меня засекла, типа попросили у ворот не стоять. На след. день включили WEP
А кстати, ни у кого не возникали паронаидальные потребности кроме WEP и фильтрации по MAC сделать
есще чего-то такого сверх? (авторизация там отдельная по radius и т.п.) Были у кого-то случаи ломания с подделкой MAC и воровством/подбором ключей?
Я сам проломом увлекаюсь. Наболее надежно WPA + туннель поверх.
WEP ломается за минуты. MAC вообще ребенок сменить может, я в винде жене менял, чтоб провайдера не дергать.
Edited by nuclearcat
Андрей, не знаю что ты имеешь в виду под "параноидально", но сеть с wpa + radius + mac + vpn сверху - это действительно надежно. Все остальное это так - детей пугать.
Физический доступ к сети ограничить. Не логический(VPN), а физический.
WPA+AES, тут и VPN не потребуется.
Так надо же еще логику организовать. Билинг, авторизацию... Для этого и есть VPN
Речь же шла про надежность, а не про биллинг. ;)
