alibek Posted October 15 Posted October 15 Есть Cisco ASR 1001-X: #sh ver Cisco IOS XE Software, Version 16.09.08 Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.8, RELEASE SOFTWARE (fc4) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2021 by Cisco Systems, Inc. Compiled Wed 01-Sep-21 01:43 by mcpre ROM: IOS-XE ROMMON BRAS13-ASR1001X uptime is 1 day, 12 hours, 38 minutes Uptime for this control processor is 1 day, 12 hours, 39 minutes System returned to ROM by Reload Command at 04:00:00 MSK Wed Oct 14 2026 System restarted at 04:03:10 MSK Wed Oct 14 2026 System image file is "bootflash:asr1001x-universalk9.16.09.08.SPA.bin" Last reload reason: Reload Command License Type: Permanent License Level: adventerprise Next reload license Level: adventerprise The current throughput level is 20000000 kbps Smart Licensing Status: Smart Licensing is DISABLED cisco ASR1001-X (1NG) processor (revision 1NG) with 3852984K/6147K bytes of memory. Processor board ID *** 6 Gigabit Ethernet interfaces 2 Ten Gigabit Ethernet interfaces 32768K bytes of non-volatile configuration memory. 8388608K bytes of physical memory. 6688767K bytes of eUSB flash at bootflash:. 0K bytes of WebUI ODM Files at webui:. Configuration register is 0x2102 Есть еще одна, такая же: #sh ver Cisco IOS XE Software, Version 16.09.08 Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.8, RELEASE SOFTWARE (fc4) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2021 by Cisco Systems, Inc. Compiled Wed 01-Sep-21 01:43 by mcpre ROM: IOS-XE ROMMON BRAS14-ASR1001X uptime is 10 minutes Uptime for this control processor is 11 minutes System returned to ROM by Reload Command at 16:17:03 MSK Thu Oct 15 2026 System image file is "bootflash:asr1001x-universalk9.16.09.08.SPA.bin" Last reload reason: Reload Command License Type: EvalRightToUse License Level: adventerprise Next reload license Level: adventerprise The current throughput level is 20000000 kbps Smart Licensing Status: Smart Licensing is DISABLED cisco ASR1001-X (1NG) processor (revision 1NG) with 3852984K/6147K bytes of memory. Processor board ID *** 6 Gigabit Ethernet interfaces 2 Ten Gigabit Ethernet interfaces 32768K bytes of non-volatile configuration memory. 8388608K bytes of physical memory. 6594559K bytes of eUSB flash at bootflash:. 0K bytes of WebUI ODM Files at webui:. Configuration register is 0x2102 Но при этом на фичах стоит срок действия: #sh lic Index 1 Feature: adventerprise Period left: 8 weeks 3 days Period Used: 20 minutes 58 seconds License Type: EvalRightToUse License State: Active, In Use License Count: Non-Counted License Priority: Low Index 2 Feature: advipservices Period left: Life time License Type: RightToUse License State: Active, Not in Use, EULA accepted License Count: Non-Counted License Priority: Low ... И лицензия interface_10g (если смотреть sh license feature) числится выключенной. Не напомните, как их включить? А то ни найти, ни вспомнить не получается. Вставить ник Quote
vurd Posted October 15 Posted October 15 license boot level adventerprise platform hardware throughput level 5000000 license accept end user agreement wr mem reload Вставить ник Quote
alibek Posted October 15 Author Posted October 15 Эти команды я вводил, видно же по выводу. Активирован adventerprise (20 минут назад) и 20000000 kbps (в выводе show version). Фичи активированы, но у них срок действия не permanent. Вставить ник Quote
fractal Posted October 16 Posted October 16 надо просто обновиться до актуальной версии (а так asr всю жизнь был RTU) sh license usage License Authorization: Status: Not Applicable throughput_20g (ASR_1001X_Throughput_2.5G-20G): Description: throughput_20g Count: 1 Version: 1.0 Status: IN USE Export status: NOT RESTRICTED Feature Name: throughput_20g Feature Description: throughput_20g Enforcement type: NOT ENFORCED License type: Perpetual ipbase (ASR_1000_Ipbase): Description: ipbase Count: 1 Version: 1.0 Status: IN USE Export status: NOT RESTRICTED Feature Name: ipbase Feature Description: ipbase Enforcement type: NOT ENFORCED License type: Perpetual interface_10g (ASR_1001X_10GE): Description: interface_10g Count: 2 Version: 1.0 Status: IN USE Export status: NOT RESTRICTED Feature Name: interface_10g Feature Description: interface_10g Enforcement type: NOT ENFORCED License type: Perpetual Вставить ник Quote
alibek Posted October 16 Author Posted October 16 47 минут назад, fractal сказал: надо просто обновиться до актуальной версии Мне в ТП Нага когда-то сказали, что 16.09.08 — это последняя версия, где есть RTU. Вставить ник Quote
No_name Posted October 16 Posted October 16 Цитата На старых прошивках (включая 16.09) у Cisco ASR была особенность: даже если ознакомительный таймер EvalRightToUse истекает (доходит до 0), маршрутизатор не блокирует порты и не отключает трафик. Он продолжит работать в режиме "Honor-Based", просто при каждой загрузке и в логах будет появляться предупреждение (Syslog Alert) о том, что период оценки истек. Роутер активировал временную лицензию верхнего уровня (adventerprise) в режиме EvalRightToUse (ознакомительная, на 60 дней / 8 недель). При этом у вас есть бессрочная постоянная лицензия на уровень ниже — advipservices (Period left: Life time), которая сейчас не используется. Переключение на постоянный уровень (advipservices) Переведите базовый пакет на ваш бессрочный уровень: Router# configure terminal Router(config)# license boot level advipservices Может так? Вставить ник Quote
alibek Posted October 16 Author Posted October 16 advipservices у меня была активирована изначально, без ограничений по сроку действия. Не знаю, требуются ли для работы BRAS PPPoE фичи adventerprise, но хочу настроить полностью идентично другим железкам, чтобы был горячий резерв. Вставить ник Quote
fractal Posted October 16 Posted October 16 3 часа назад, alibek сказал: Мне в ТП Нага когда-то сказали, что 16.09.08 — это последняя версия, где есть RTU. Не слушайте их, сама логика asr всегда была rtu, на любом софте после этой версии просто новая политика лицензирования, и это все описано на Cisco, включая и то, что asr или их преемник c8500 rtu с дефолтным hsec на борту 2 часа назад, No_name сказал: Переключение на постоянный уровень (advipservices) Переведите базовый пакет на ваш бессрочный уровень: Router# configure terminal Router(config)# license boot level advipservices Может так? Это бага, после истечения она должна переходить на perpetual, в любом случае обновляться надо, эта версия с критическими уязвимостями 1 час назад, alibek сказал: advipservices у меня была активирована изначально, без ограничений по сроку действия. Не знаю, требуются ли для работы BRAS PPPoE фичи adventerprise, но хочу настроить полностью идентично другим железкам, чтобы был горячий резерв. Cisco feature navigator подскажет Вставить ник Quote
