В сети vlan60 - видеокамеры и регистраторы.
Не могу добиться, чтобы ноутбук который подключен к EPON0/4:2 видел камеры с EPON0/2
Камеры подключены в управляемый POE свич после EPON0/2:4
На ноуте видны только камеры, которые приходят на GigaEthernet0/5
Switch_config#show running-config
Building configuration...
Current configuration:
!version 10.1.0F build 144727
service timestamps log date
service timestamps debug date
logging buffered 4096
port-protected 1
epon local-mac forward
ip default-gateway 192.168.10.254
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 0
epon oam-version 1 0x30
epon oam-version 2 0x21
epon oam-version 3 0x20
!!slot 0 89 unknow CARD
interface GigaEthernet0/1
 switchport trunk vlan-allowed 3
 switchport trunk vlan-untagged 1
 switchport mode dot1q-tunnel-uplink
 switchport pvid 3
 storm-control broadcast threshold 500
 no storm-control multicast threshold
 storm-control unicast threshold 500
interface GigaEthernet0/2
 switchport trunk vlan-allowed 214
 switchport trunk vlan-untagged 214
 switchport mode access
 switchport pvid 214
interface GigaEthernet0/3
interface GigaEthernet0/4
interface GigaEthernet0/5
 switchport trunk vlan-allowed 1,60,93,100,172,216
 switchport trunk vlan-untagged none
interface GigaEthernet0/6
 switchport trunk vlan-allowed 100,200-202,205,208-212,214-215,221-222
interface EPON0/1
 epon bind-onu mac f8f0.8224.a842 1
 epon bind-onu mac f8f0.8223.8f46 2
 epon bind-onu mac f8f0.8262.afe6 3
 epon bind-onu mac f8f0.8211.f229 4
 switchport trunk vlan-allowed 3,93,205,209,215
 switchport mode trunk
 storm-control multicast threshold 500
 switchport protected 1
interface EPON0/1:1
 description Lentaprom
  epon onu description Lentaprom
  epon onu port 1 ctc vlan mode tag 93 priority 0
  epon onu port 2 ctc vlan mode tag 3 priority 0
interface EPON0/1:2
 description SystemPUK
  epon onu description SystemPUK
  epon onu port 1 ctc vlan mode tag 209 priority 0
interface EPON0/1:3
 description ATM
  epon onu description ATM
  epon onu port 1 ctc vlan mode tag 205 priority 0
interface EPON0/1:4
 description ATM1
  epon onu description ATM1
  epon onu port 1 ctc vlan mode tag 215 priority 0
interface EPON0/2
 epon bind-onu mac f8f0.8211.f22d 1
 epon bind-onu mac f8f0.8211.f223 2
 epon bind-onu mac f8f0.8211.f24b 3
 epon bind-onu mac f8f0.8262.afee 4
 epon bind-onu mac f8f0.8211.f253 7
 epon bind-onu mac f8f0.8222.547c 8
 epon bind-onu mac f8f0.8223.8f3e 10
 epon bind-onu mac f8f0.8223.8f5c 11
 epon bind-onu mac f8f0.8223.8f30 12
 switchport trunk vlan-allowed 60,100,172,201-202,208,210-212,214,216
 switchport pvid 214
interface EPON0/2:1
 description Prosanteh2
  epon onu description Prosanteh2
  epon onu port 1 ctc vlan mode tag 212 priority 0
interface EPON0/2:2
 description Avtotehnix
interface EPON0/2:3
 description Salix
  epon onu description Salix
  epon onu port 1 ctc vlan mode tag 202 priority 0
interface EPON0/2:4
 description Kotelnaya
  epon onu description Kotelnaya
  epon onu port 1 ctc vlan mode trunk 1 60,100,201,211
interface EPON0/2:7
 description Koemz
interface EPON0/2:8
 description Moxa
  epon onu description Moxa
  epon onu port 1 ctc vlan mode tag 216 priority 0
interface EPON0/2:10
 description Kamera
  epon onu description Kamera
  epon onu port 1 ctc vlan mode tag 60 priority 0
interface EPON0/2:11
 description Vinty
  epon onu description Vinty
  epon onu port 1 ctc vlan mode tag 172 priority 0
interface EPON0/2:12
 description Plitka2etazh
  epon onu description Plitka2etazh
  epon onu port 1 ctc vlan mode tag 214 priority 0
  epon onu port 1 ctc loopback detect
  epon onu port 1 ctc notify loopback
interface EPON0/3
 epon bind-onu mac f8f0.8223.8f6a 1
 epon bind-onu mac f8f0.8224.ac3f 2
 epon onu-blacklist mac f8f0.8211.f24d id 1
 switchport trunk vlan-allowed 60,100,214,221-222
interface EPON0/3:1
  epon onu port 1 ctc vlan mode tag 222 priority 0
interface EPON0/3:2
interface EPON0/4
 epon bind-onu mac f8f0.8224.ac3d 1
 epon bind-onu mac f8f0.8222.548a 2
 switchport trunk vlan-allowed 60,221-222
interface EPON0/4:1
interface EPON0/4:2
!!slot end
interface VLAN100
 ip address 192.168.10.253 255.255.255.0
vlan 1,3,60,93,100,172,201-202,205,208-212,214-216,221-222
ip http language english
ip http server
no ip http web first-login-reset-password
time-zone tz 3 0
ntp server 192.168.10.6
!Pending configurations for absent linecards:
!No configurations pending global
Добрый день
На xPON по умолчанию включена изоляция между ОНУ, чтобы отключить:
1. изоляция между ONU на разных PON портах:
Switch_config#interface epON 0/2
Switch_config_epon0/2#no switchport protected
Switch_config#interface epON 0/3
Switch_config_epon0/3#no switchport protected
2. изоляция между ONU на одном PON порту
Switch_config#interface epON 0/1
Switch_config_epon0/1#epon inner-onu-switch
