Из моего конфига chrony
pool pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool 0.pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool 1.pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool 2.pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool 3.pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool europe.pool.ntp.org 	maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ru.pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool md.pool.ntp.org 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp.ubuntu.com 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool 0.freebsd.pool.ntp.org 	maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp1.vniiftri.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp2.vniiftri.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp3.vniiftri.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp4.vniiftri.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp5.vniiftri.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp21.vniiftri.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp1.niiftri.irkutsk.ru 	maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp2.niiftri.irkutsk.ru 	maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp.sstf.nsk.ru 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool timesstf.sstf.nsk.ru	maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool ntp.kam.vniiftri.net	maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool time.nist.gov 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool time-a.nist.gov 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool time-b.nist.gov 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
pool time-nw.nist.gov 		maxsources 8 iburst minpoll 12 maxpoll 16 polltarget 14
На почитать: https://habr.com/ru/articles/860828/
  • Replies 85
  • Created
  • Last Reply
Top Posters In This Topic
@Ivan_83 Катастрофы читали и наблюдали, понять бы, как по-правильному, стало что-то скакать на устройствах время. Настроено 2 сервера времени локальных в контейнерах, может не удивительно?
Надо учитывать что pool.ntp.org это сообщество энтузиастов + корпоративные серваки. Поэтому иногда в пуле могут попадаться сервера энтузиастов, у которых время сильно уехало. Если используются ntp-демоны реализующие ntp-алегоритм (ntp,chrony,ntpsec) или systemd-timesyncd то они при загрузке могут скачком скорректироваться на несколько часов (что отключается). При дальнейшей работе и наличии выбора из нескольких серверов, как правило они такого не позволят.
Рекомендуемые - серваки ВНИИФТРИ и MSK-IX
@Ivan_83,
1) возможно вместо pool.ntp.org лучше использовать ru.pool.ntp.org чтобы сразу синхронизироваться с региональным сегментом. Хотя пул и сам будет стремиться отдавать из нужного региона. И если регион вдруг будет умирать то выбор будет невелик (вспомним инцидент с Алисами Яндекса https://habr.com/ru/articles/860828/ https://habr.com/ru/companies/yandex/articles/861538/).
2) у тебя половина мёртвых, некоторые даже не ресолвятся.  ВНИИФТРИ оставили 4 адреса ntp1-ntp4, все остальные их доменные адреса (иркутск и др) либо ресолвятся в них-же либо тоже не ресолвятся.
Можно ещё попробовать (если доступны)
time.google.com
time.facebook.com
time.cloudflare.com
но с ними надо быть аккуратным т.к. они могут использовать разные методики коррекции високосных секунд. Например, фейсбук не добавляет её традиционно "скачком", а "растягивает" её добавление на 18 часов что к концу суток приведёт к расхождению с другими ntp почти на секунду. На своём ntp держу их в конфиге как noselect
Edited by umike
7 минут назад, umike сказал:
Само собой.
Я обычно синхронизирую время с серверами vniiftri.ru, но добавляю к ним anycast-сервер ntp.msk-ix.ru и несколько серверов из пула pool.ntp.org.
Обычно использую либо региональный пул (ru.pool.ntp.org), либо пул дистрибутива (debian.pool.ntp.org).
11 минут назад, umike сказал:
FB и CF я бы не использовал, их часто блокируют просто на уровне доменов второго уровня.
А вот за time.google.com спасибо, думаю есть смысл его тоже добавлять.
Я раньше наугад проверял ntp.google.com, но он не ресолвился.
1 час назад, umike сказал:
Но они же не объявляют себя stratum 1, потому они в статусе "не синхронизирововано", stratum 16 и ntpd просто не будет синхронизироваться с ними. Потому можно спокойно добавить в конфиг и что-то похуже, чем stratum 1, чем ждать когда основные будут отдавать синхронизированное время. Потом всё равно переедет на более корневые.
Вообще говоря администратор сервера может прописать "статически" любой стратум и при этом отдавать кривое время. В https://community.ntppool.org/ были сообщения о том, что у кого-то по логам встречались сервера пула отдающие кривое время, а при повторной ручной проверке они уже отдают нормальное. Но такие ситуация всё-таки редкость. Сам пул имеет мониторинг, который регулярно из нескольких разных локаций проверяет все добавленные в пул сервера и присваивает им рейтинг/score. Если с сервером неполадки, он не отвечает, отдаёт плохой стратум или кривое время то рейтинг падает и сервер удаляется из пула. Когда сервер восстановит нормальную работу и примерно с час будет мониториться нормально, он набирает нормальный score и возвращается в выдачу.
40 минут назад, umike сказал:
Это либо на локальные датчики эталонного времени, либо о максимальном значении после синхронизации даже с корневым. Те что в пуле 1-2 стратума отдают неправильное время, если исключить дурацкую диверсию, просто - неисправность конфигурации самого компа, а не ntpd, когда ntpd считает что он синхронизирован, но получает неправильные значения о задержках своего выполнения или неожиданные корректировки монотонного времени.
5 часов назад, umike сказал:
time.google.com
Шарили адреса с account.google.com, который часто попадает под раздачу бана YouTube.
3 часа назад, umike сказал:
Просто есть долбанутый софт, например, Mikrotik RouterOS 7, который хочет прямо суперстратум, и народ его подкручивает вручную. Synology той же болезнью страдали в DSM 7.2X периодически, да и еще с чем-то напарывался. Так что вероятность ненулевая.
У меня другой региональный сегмент, не все находятся внутри великой империи в дефолтсити 🙂
На то конфиг и расвесистый чтобы туда заглядывать раз в 10-15 лет: хоть что то живое да останется за такой период 🙂
Чёт этим я совсем не доверяю даже такое :)))
Это проблемы хрони, мне лишь бы дату да часы нормально выставило, +-5 секунд вообще ниачом. Был бы эстетом - давно бы GPS прикрутил и стал стратум1 сам для себя. Более того у меня даже валяется минимум 1 гпс приёмник купленный примерно для такого применения уже лет 5 назад.
9 минут назад, Ivan_83 сказал:
я так и сделал, на двух микротах-радиомостах прикрутил ublox и имел свои сервера независимые от интернет... но потом началось... и стационарные мосты в 25ом стали барражировать на 1.5 километрах и время плюс минус 6 часов... пришлось спешно спрыгивать на инет-сервера ntp
У нас свои сервера времени, зачем использовать чужие? Когда можно свои поставить, и на них уже брать время со спутника или с любых сторонних серверов через интернет. В случае чего время легко корректировать и все устройства примут настройки.
https://www.kommersant.ru/doc/8846903
Цитата
Финская энергетическая компания Fingrid объявила российским операторам связи, что с 2027 года прекратит обслуживание опор ЛЭП, на которых подвешены волоконно-оптические линии связи (ВОЛС), рассказал “Ъ” источник на телеком-рынке и подтвердили еще четыре собеседника на рынке. По словам источника, планируется, что «кабель будет обрезан, а опоры — разобраны».
Ну что, С-З приготовиться к говнофекации выхода зарубеж.
Интересно, кого это затронет?
По идее частников, у кого собственные трансграничные линии, много не будет.
А у крупных национальных операторов скорее всего подземные или подводные линии.
53 минуты назад, jffulcrum сказал:
История старая, с 22 года. Заданет ретн, глобалнет, арелион. Но они, скорее всего, с 22 года уже сделали резерв.
В 27.07.2026 в 14:22, Ivan_83 сказал:
куда так много?
на серверах в рф у меня вот так:
Цитата
pool 0.ru.pool.ntp.org iburst
pool 2.ru.pool.ntp.org iburst
server ntp.msk-ix.ru
server ntp2.vniiftri.ru
два пула чтобы серверов было побольше. явно указана страна потому что geodns не всегда правильно работает в текущих трёхюуквенных реалиях 😉
по факту, после стабилизации основным всегда выбирается msk-ix или vniiftri
на зарубежных — просто что-то вроде
pool 2.debian.pool.ntp.org iburst
pool nl.pool.ntp.org
В 28.07.2026 в 11:09, umike сказал:
google тоже. но из хороших новостей: високосную секунду, похоже, в обозримом будущем вводить не будут.
ну а даже если введут, chrony достаточно умный, чтобы отбросить единичный сервер
 а смысл тогда вообще добавлять?
time.cloudflare.com
cf в пуле ntp.org вполне себе есть, так что добавлять его отдельно особого смысла нет. и да, он корректирует високосную секунду вполне стандартно
13 hours ago, edo said:
куда так много?
Для ntp пула важным может быть параметр maxsources который определяет сколько разных IP адресов хрони понадёргает с этого днс имени.
root@firewall:/usr/ports# chronyc -nN tracking -v
Reference ID    : 591C4AA1 (md.pool.ntp.org)
Stratum         : 2
Ref time (UTC)  : Fri Jul 31 20:46:35 2026
System time     : 0.000082647 seconds fast of NTP time
Last offset     : +0.000342377 seconds
RMS offset      : 0.000656693 seconds
Frequency       : 21.189 ppm slow
Residual freq   : +0.004 ppm
Skew            : 0.098 ppm
Root delay      : 0.003026511 seconds
Root dispersion : 0.003452784 seconds
Update interval : 4104.2 seconds
Leap status     : Normal
root@firewall:/usr/ports# chronyc -nN sources -v
  .-- Source mode  '^' = server, '=' = peer, '#' = local clock.
 / .- Source state '*' = current best, '+' = combined, '-' = not combined,
| /             'x' = may be in error, '~' = too variable, '?' = unusable.
||                                                 .- xxxx [ yyyy ] +/- zzzz
||      Reachability register (octal) -.           |  xxxx = adjusted offset,
||      Log2(Polling interval) --.      |          |  yyyy = measured offset,
||                                \     |          |  zzzz = estimated error.
MS Name/IP address         Stratum Poll Reach LastRx Last sample
^- pool.ntp.org                  2  12   377   29m   -527us[ -527us] +/-   88ms
^- pool.ntp.org                  2  12   377   38m  +1725us[+1725us] +/-   51ms
^- pool.ntp.org                  2  12   377   31m  +8630us[+8630us] +/-  108ms
^- pool.ntp.org                  2  12   377   39m  +2315us[+2315us] +/-  131ms
^- pool.ntp.org                  2  12   377   55m  +1226us[+1562us] +/-  112ms
^- pool.ntp.org                  3  12   357   41m  -1638us[-1638us] +/-   79ms
^- pool.ntp.org                  2  12   377   23m  -4694ns[-4694ns] +/-   18ms
^- pool.ntp.org                  2  12   377   55m  +1010us[+1346us] +/-   37ms
^- 0.pool.ntp.org                2  12   377   21m  +1613us[+1613us] +/-  126ms
^- 0.pool.ntp.org                3  12   377   33m  +7131us[+7131us] +/-  108ms
^- 0.pool.ntp.org                2  12   377   941  -3542us[-3542us] +/-  115ms
^- 0.pool.ntp.org                2  13   377   29m  -5056us[-5056us] +/-  118ms
^- 0.pool.ntp.org                2  12   377   42m  +1073us[+1073us] +/-  111ms
^- 0.pool.ntp.org                2  12   377   32m  +1878us[+1878us] +/-  173ms
^- 0.pool.ntp.org                2  12   377   53m   -270us[  +68us] +/-  100ms
^- 0.pool.ntp.org                2  12   377   45m  -1008us[-1008us] +/-  148ms
^- 1.pool.ntp.org                2  12   377   85m  -5095us[-4786us] +/-  134ms
^- 1.pool.ntp.org                2  12   377   24m  +6438us[+6438us] +/-   92ms
^- 1.pool.ntp.org                2  12   377   50m    +97us[ +438us] +/-   18ms
^- 1.pool.ntp.org                2  12   337   40m   +645us[ +645us] +/- 9867us
^- 1.pool.ntp.org                1  13   377  117m   -207us[  +74us] +/-   66ms
^- 1.pool.ntp.org                2  12   377   31m  -3601us[-3601us] +/-  133ms
^- 1.pool.ntp.org                2  12   377   32m  +2543us[+2543us] +/-   96ms
^- 1.pool.ntp.org                2  14   377  179m  +5923us[+6433us] +/-  113ms
^- 2.pool.ntp.org                2  12   357   43m   +407us[ +407us] +/- 3701us
^- 2.pool.ntp.org                2  12   377   26m  +1074us[+1074us] +/-   65ms
^- 2.pool.ntp.org                2  12   337   41m   -412us[ -412us] +/-   40ms
^- 2.pool.ntp.org                2  12   377   28m  +3621us[+3621us] +/-   89ms
^- 2.pool.ntp.org                2  12   377   58m   +301us[ +635us] +/-   57ms
^- 2.pool.ntp.org                2  12   377   51m  -1447us[-1107us] +/-   23ms
^- 2.pool.ntp.org                3  12   377   21m  +7024us[+7024us] +/-   26ms
^- 2.pool.ntp.org                2  12   377  121m   +564us[+1132us] +/-   85ms
^- 3.pool.ntp.org                2  12   377   50m   +837us[+1178us] +/-   37ms
^- 3.pool.ntp.org                2  12   377   50m  -1121us[ -779us] +/-   70ms
^- 3.pool.ntp.org                5  14   377   38m   +428us[ +428us] +/-  125ms
^- 3.pool.ntp.org                2  14   377   80m   +984us[+1298us] +/-   80ms
^- 3.pool.ntp.org                2  12   377   45m   -574us[ -574us] +/-  129ms
^- 3.pool.ntp.org                2  12   377   30m  +2730us[+2730us] +/-   72ms
^- 3.pool.ntp.org                2  12   377   37m   +981us[ +981us] +/-   98ms
^- 3.pool.ntp.org                2  12   377   45m   -348us[ -348us] +/-   85ms
^- europe.pool.ntp.org           2  12   377   48m   -639us[ -639us] +/-   41ms
^- europe.pool.ntp.org           2  12   377   45m   +162us[ +162us] +/-   49ms
^- europe.pool.ntp.org           2  12   377   31m   +456us[ +456us] +/-   25ms
^- europe.pool.ntp.org           1  16   247  419m    -22ms[  -21ms] +/-   73ms
^- europe.pool.ntp.org           1  12   377   53m  -1967us[-1629us] +/-   32ms
^- europe.pool.ntp.org           2  12   377   44m  -1802us[-1802us] +/-   33ms
^- europe.pool.ntp.org           2  12   377   821  +5386us[+5386us] +/-   75ms
^- europe.pool.ntp.org           1  15   335  330m  -6251us[-6179us] +/-   25ms
^- ru.pool.ntp.org               2  12   377   50m  -2876us[-2535us] +/-   53ms
^- ru.pool.ntp.org               3  12   377   31m  +9585us[+9585us] +/-   31ms
^- ru.pool.ntp.org               2  12   377   38m   -229us[ -229us] +/-   23ms
^- ru.pool.ntp.org               3  12   377   39m  +4200us[+4200us] +/-   26ms
^- ru.pool.ntp.org               2  12   377   36m  +3209us[+3209us] +/-   53ms
^- ru.pool.ntp.org               2  12   377   35m  -1903us[-1903us] +/-   29ms
^- ru.pool.ntp.org               2  12   377   39m  -2905us[-2905us] +/-   33ms
^- ru.pool.ntp.org               2  12   377   39m  -1069us[-1069us] +/-   37ms
^* md.pool.ntp.org               1  12   377   48m   +335us[ +677us] +/- 1529us
^- ntp.ubuntu.com                2  12   377   20m    +63us[  +63us] +/-   29ms
^- ntp.ubuntu.com                2  12   377   28m   +808us[ +808us] +/-   29ms
^- ntp.ubuntu.com                2  12   377   45m   +736us[ +736us] +/-   30ms
^- ntp.ubuntu.com                2  12   377   43m  +2987us[+2987us] +/-   90ms
^- ntp.ubuntu.com                2  12   377   36m   +349us[ +349us] +/-   29ms
^- ntp.ubuntu.com                2  12   377   30m   -611us[ -611us] +/-   30ms
^- ntp.ubuntu.com                2  12   377   45m   -475us[ -475us] +/-   30ms
^- 0.freebsd.pool.ntp.org        2  12   377   47m   +187us[ +187us] +/-   89ms
^- 0.freebsd.pool.ntp.org        2  12   377   27m  +1299us[+1299us] +/-  121ms
^- 0.freebsd.pool.ntp.org        2  14   377  1063  -2522us[-2522us] +/-   63ms
^- 0.freebsd.pool.ntp.org        1  12   377   39m  +2836us[+2836us] +/-   85ms
^- 0.freebsd.pool.ntp.org        2  12   377   231  -4720us[-4720us] +/-  132ms
^- 0.freebsd.pool.ntp.org        2  12   373   65m  +1694us[+2022us] +/-  110ms
^- 0.freebsd.pool.ntp.org        2  12   377   61m  +1591us[+1922us] +/-   93ms
^- 0.freebsd.pool.ntp.org        2  14   377  120m   +808us[+1376us] +/-   99ms
^- ntp1.vniiftri.ru              1  12   377   49m   -600us[ -258us] +/-   36ms
^- ntp2.vniiftri.ru              1  12   377   53m  -1054us[ -716us] +/-   35ms
^- ntp3.vniiftri.ru              1  12   337   35m  -4889us[-4889us] +/-   40ms
^- ntp4.vniiftri.ru              1  12   377   41m  -2188us[-2188us] +/-   36ms
^- ntp21.vniiftri.ru             2  12   377   57m  -1923us[-1589us] +/-   40ms
^- ntp1.niiftri.irkutsk.ru       1  13   377   24m  -5971us[-5971us] +/-   65ms
^- ntp2.niiftri.irkutsk.ru       1  13   377   78m   +744us[+1060us] +/-   73ms
^- ntp.sstf.nsk.ru               1  16   377  145m  -6880us[-6337us] +/-   49ms
^- time.nist.gov                 1  12   377   53m   -584us[ -245us] +/-   81ms
^- time.nist.gov                 1  12   377   58m   -539us[ -205us] +/-   81ms
^- time.nist.gov                 1  12   377   39m   -380us[ -380us] +/-   81ms
^- time.nist.gov                 1  12   377   37m   -266us[ -266us] +/-   81ms
^- time.nist.gov                 1  12   377   34m   -819us[ -819us] +/-   81ms
^- time.nist.gov                 1  12   377   21m   -679us[ -679us] +/-   81ms
^- time.nist.gov                 1  12   377   29m   -417us[ -417us] +/-   81ms
^- time.nist.gov                 1  12   377   58m   -655us[ -320us] +/-   81ms
^- time-a.nist.gov               1  12   377   21m  -1380us[-1380us] +/-   66ms
^- time-b.nist.gov               1  12   377   33m  -1345us[-1345us] +/-   66ms
^? time-nw.nist.gov              0  16     0     -     +0ns[   +0ns] +/-    0ns
root@firewall:/usr/ports# chronyc -nN sourcestats -v
                             .- Number of sample points in measurement set.
                            /    .- Number of residual runs with same sign.
                           |    /    .- Length of measurement set (time).
                           |   |    /      .- Est. clock freq error (ppm).
                           |   |   |      /           .- Est. error in freq.
                           |   |   |     |           /         .- Est. offset.
                           |   |   |     |          |          |   On the -.
                           |   |   |     |          |          |   samples. \
Name/IP Address            NP  NR  Span  Frequency  Freq Skew  Offset  Std Dev
pool.ntp.org                9   4  551m     -0.001      0.275  -1856us  1422us
pool.ntp.org                6   3  344m     +0.001      1.091   +615us  2210us
pool.ntp.org                6   3  344m     +0.344      0.986  +7934us  1811us
pool.ntp.org                6   5  342m     +0.163      1.218   -870us  2393us
pool.ntp.org                7   4  413m     +0.258      0.303  +2089us  1036us
pool.ntp.org               10   7   11h     +0.057      0.096  -1896us   818us
pool.ntp.org                7   3  413m     +0.006      0.150   -617us   437us
pool.ntp.org                8   4  481m     +0.010      0.101   +726us   408us
0.pool.ntp.org             12   8   12h     +0.001      0.072  -1435us   734us
0.pool.ntp.org             15  10   16h     +0.018      0.117  +2514us  1778us
0.pool.ntp.org              8   5  482m     -0.014      0.120  -3828us   573us
0.pool.ntp.org              6   3   20h     +0.056      0.346  -2966us  2413us
0.pool.ntp.org             10   6   10h     -0.009      0.088   +891us   670us
0.pool.ntp.org             12   7   16h     +0.059      0.155   -728us  1901us
0.pool.ntp.org             15  10   16h     -0.048      0.098  -1887us  1518us
0.pool.ntp.org             10   5   10h     +0.073      0.126   +261us  1023us
1.pool.ntp.org             20  11   21h     +0.082      0.058  -3761us  1689us
1.pool.ntp.org              9   4  551m     +0.047      0.200  +7025us  1145us
1.pool.ntp.org             14   7   14h     +0.001      0.027   -350us   403us
1.pool.ntp.org              6   4  413m     +0.090      0.149   +784us   242us
1.pool.ntp.org              6   4   11h     +0.030      0.249  +3564us   562us
1.pool.ntp.org             15   9   16h     +0.027      0.070  -8690us  1064us
1.pool.ntp.org             11   7   11h     -0.027      0.159  +2771us  1662us
1.pool.ntp.org              6   4   23h     +0.175      0.449  +6802us  3248us
2.pool.ntp.org              7   4  484m     +0.073      0.069   +502us   131us
2.pool.ntp.org             13   7   14h     +0.072      0.068  +2086us   864us
2.pool.ntp.org              6   5  482m     +0.040      0.157   -147us   469us
2.pool.ntp.org             10   6   10h     +0.015      0.098    +68us   697us
2.pool.ntp.org             11   7   11h     +0.075      0.115  +1493us   949us
2.pool.ntp.org             10   5   10h     +0.081      0.100   +454us   735us
2.pool.ntp.org             14   9   14h     +0.045      0.070  +7444us  1002us
2.pool.ntp.org             13   7   13h     +0.058      0.047   +730us   536us
3.pool.ntp.org              8   3  483m     -0.023      0.190   +387us   810us
3.pool.ntp.org             12  11   16h     -0.047      0.069  -2390us   872us
3.pool.ntp.org              6   3   23h     +0.160      0.533  +4618us  4095us
3.pool.ntp.org              6   3   22h     +0.063      0.603  +2512us  3443us
3.pool.ntp.org              9   5  552m     -0.064      0.296  +3574us  1390us
3.pool.ntp.org             10   5   10h     -0.032      0.204   +391us  1429us
3.pool.ntp.org              9   5  553m     -0.047      0.142   -540us   929us
3.pool.ntp.org             15   7   16h     -0.000      0.062   +468us  1065us
europe.pool.ntp.org        10   5   10h     +0.055      0.063   -417us   403us
europe.pool.ntp.org         6   3  343m     -0.007      0.215   -360us   433us
europe.pool.ntp.org        13   9   13h     +0.002      0.103   -204us  1309us
europe.pool.ntp.org         7   5    6d     +0.429      0.128  +1999us  8925us
europe.pool.ntp.org         6   4  343m     +0.160      1.847  -1215us  3502us
europe.pool.ntp.org         8   5  480m     -0.067      0.137  -2506us   562us
europe.pool.ntp.org         6   3  344m     +0.537      0.783  +8020us  1692us
europe.pool.ntp.org         6   3   55h     +0.301      0.474  +4141us  9269us
ru.pool.ntp.org            10   5   10h     +0.034      0.443  -1874us  3084us
ru.pool.ntp.org             8   4   11h     -0.014      0.180  +1106us  1080us
ru.pool.ntp.org             8   5  482m     -0.047      0.137   -810us   539us
ru.pool.ntp.org             7   5   10h     -0.027      0.287   +912us  1019us
ru.pool.ntp.org             8   6  483m     +0.060      0.324  -1538us  1211us
ru.pool.ntp.org            13   9   14h     +0.005      0.040  -1871us   500us
ru.pool.ntp.org            11   6   12h     +0.016      0.041  -2969us   432us
ru.pool.ntp.org             7   4  414m     -0.032      0.266   -705us   782us
md.pool.ntp.org             7   3  413m     +0.004      0.087    +10us   278us
ntp.ubuntu.com             12   8   12h     +0.050      0.076   +143us   848us
ntp.ubuntu.com              7   6  482m     +0.039      0.159   +346us   475us
ntp.ubuntu.com              8   5  550m     +0.074      0.073   +491us   384us
ntp.ubuntu.com              8   3  483m     +0.028      0.331  -1877us  1410us
ntp.ubuntu.com             10   4   10h     +0.008      0.079  -1088us   557us
ntp.ubuntu.com             15  11   16h     +0.007      0.043   -905us   596us
ntp.ubuntu.com              9   4  551m     -0.004      0.107  -1580us   636us
0.freebsd.pool.ntp.org      6   3  344m     -0.004      0.277  -1668us   469us
0.freebsd.pool.ntp.org     12   7   12h     +0.004      0.034   +561us   443us
0.freebsd.pool.ntp.org      6   3   23h     +0.121      0.581   +665us  4596us
0.freebsd.pool.ntp.org     13   8   13h     -0.037      0.146   +355us  1880us
0.freebsd.pool.ntp.org      8   5  480m     +0.028      0.317  -6244us  1465us
0.freebsd.pool.ntp.org     10   6   11h     -0.015      0.146  +1522us  1240us
0.freebsd.pool.ntp.org      6   3  343m     +0.170      0.789   +880us  1590us
0.freebsd.pool.ntp.org      7   5   27h     +0.231      0.396  +7799us  4670us
ntp1.vniiftri.ru            8   5  484m     -0.026      0.397  -2236us  2159us
ntp2.vniiftri.ru           10   7   10h     +0.031      0.180   -722us  1531us
ntp3.vniiftri.ru           13   9   14h     -0.031      0.129  -2771us  1880us
ntp4.vniiftri.ru           15   8   16h     +0.006      0.083  -1665us  1464us
ntp21.vniiftri.ru          12  11   12h     +0.000      0.133  -1924us  1514us
ntp1.niiftri.irkutsk.ru     7   5   20h     +0.144      1.001  +3594us  8965us
ntp2.niiftri.irkutsk.ru     9   7   18h     +0.087      0.271  +1636us  2874us
ntp.sstf.nsk.ru             6   3   92h     +0.373      0.301  +3344us  9748us
time.nist.gov              10   5   10h     +0.013      0.075   -381us   543us
time.nist.gov              10   6   11h     +0.007      0.043   -796us   318us
time.nist.gov              12   4   12h     -0.000      0.059  -1139us   597us
time.nist.gov               6   4  345m     +0.067      0.487   +127us   967us
time.nist.gov              10   4   10h     +0.000      0.037   -978us   276us
time.nist.gov              12   7   12h     +0.016      0.048   -463us   503us
time.nist.gov               7   3  413m     -0.001      0.101   -845us   274us
time.nist.gov               8   3  482m     +0.008      0.156   -695us   742us
time-a.nist.gov            11   9   11h     +0.019      0.059  -1481us   537us
time-b.nist.gov            13  11   13h     +0.003      0.034  -1736us   379us
time-nw.nist.gov            0   0     0     +0.000   2000.000     +0ns  4000ms
Как видно на практике там огромный запас по прочности конфига, даже если ntp.org помрёт целиком.
Надо бы наверное каких китайцев добавить и ещё что то, не через ntp.org а напрямую.
Если кто то уже надыбал сервера за пределами корпов и ntp.org - делитесь! 🙂
Порылся ещё сам, нашёл доку "A list of the Simple Network Time Protocol (SNTP) time servers that are available on the Internet" от 2007 года, проверил что там живого:
# Stratum 1
# Europe
time1.stupi.se
time2.stupi.se
ntps1-0.cs.tu-berlin.de
ntps1-1.cs.tu-berlin.de
ntp0.fau.de
ntp1.fau.de
ntp2.fau.de
ntps1-0.uni-erlangen.de
ntps1-1.uni-erlangen.de
ntps1-2.uni-erlangen.de
swisstime.ethz.ch
time.ien.it
vega.cbk.poznan.pl
ntp.metas.ch
ntp11.metas.ch
ntp12.metas.ch
ntp13.metas.ch
# North America
otc1.psu.edu
ntp-cup.external.hp.com
ncnoc.ncren.net
navobs1.wustl.edu
navobs1.usnogps.navy.mil
navobs2.usnogps.navy.mil
clock.via.net
clock.isc.org
bonehed.lcs.mit.edu
bitsy.mit.edu
time.chu.nrc.ca
tock.usno.navy.mil
tick.usno.navy.mil
ntp2.usno.navy.mil
timekeeper.isi.edu
nist1.sjc.certifiedtime.com
nist1.nyc.certifiedtime.com
nist1.dc.certifiedtime.com
utcnist.colorado.edu
time-c.timefreq.bldrdoc.gov
time-b.timefreq.bldrdoc.gov
time-a.timefreq.bldrdoc.gov
time-b.nist.gov
time-a.nist.gov
# Stratum 2
# Australia
ntp.adelaide.edu.au
augean.eleceng.adelaide.edu.au
# Africa
ntp.cs.unp.ac.za
# British
ntp2a.mcc.ac.uk
ntp2b.mcc.ac.uk
ntp2c.mcc.ac.uk
ntp2d.mcc.ac.uk
ntp0.uk.uu.net
ntp1.uk.uu.net
ntp2.uk.uu.net
ntp.cs.tcd.ie
ntp.maths.tcd.ie
ntp.tcd.ie
# Europe
time.ijs.si
ntp1.arnes.si
ntp2.arnes.si
biofiz.mf.uni-lj.si
ntp.lth.se
info.cyf-kr.edu.pl
time.kfki.hu
ntp.univ-lyon1.fr
ntp.obspm.fr
slug.ctv.es
bernina.ethz.ch
# South America
ntp.cais.rnp.br
time.sinectis.com.ar
# North America
ntp1.cs.wisc.edu
ntp2.cs.wisc.edu
ntp3.cs.wisc.edu
ntp-1.vt.edu
ntp-2.vt.edu
tick.greyware.com
tock.greyware.com
ntp1.tamu.edu
ntp2.tamu.edu
ntp3.tamu.edu
ntp4.tamu.edu
ntp5.tamu.edu
ntp-1.ece.cmu.edu
ntp-2.ece.cmu.edu
fuzz.psc.edu
clock.psu.edu
timex.cs.columbia.edu
sundial.columbia.edu
ntp0.cornell.edu
tick.cs.unlv.edu
tock.cs.unlv.edu
allison.radiks.net
ns.nts.umn.edu
nss.nts.umn.edu
ntp1.kansas.net
ntp2.kansas.net
gilbreth.ecn.purdue.edu
harbor.ecn.purdue.edu
molecule.ecn.purdue.edu
ntp-1.mcs.anl.gov
ntp-2.mcs.anl.gov
ntp-0.cso.uiuc.edu
ntp-1.cso.uiuc.edu
ntp-2.cso.uiuc.edu
rolex.peachnet.edu
timex.peachnet.edu
louie.udel.edu
ntp.ucsd.edu
tick.utoronto.ca
tock.utoronto.ca
timelord.uregina.ca
time.chu.nrc.ca
time.nrc.ca
От оригинала померло где 10-20%.
Те можно их считать долгоживущими, а не просто энтузиасты типа меня 🙂
Ещё списки:
https://gist.github.com/mutin-sa/eea1c396b1e610a2da1e5550d94b0453
https://github.com/greyhat-academy/lists.d/blob/main/ntp.servers.list.tsv
http://md.pool.ntp.org/
Я бы с удовольствием себе забил вообще все в конфиг, но я уже как то раз заметил что у меня ntp трафика слишком много бегает, кажется оно 128+ килобит утилизировало - больше чем мой первый безлимит 🙂
С тех пор пришлось накрутить в конфиге задержки по больше между синхронизациями и раздувать список тоже чревато...
5 hours ago, jffulcrum said:
Summary of commonly used domestic NTP time source synchronization servers - Tencent Cloud Developer Community - Tencent Cloud
Маловато у них серверов, даже меньше чем в РФ.
У меня почти ничего не отрезолвилось - видимо я перестарался с блокировками китайских сетей на фаере %)
В 28.07.2026 в 14:44, vodz сказал:
Я когда еду по МКАДу в районе съезда на Волоколамку (от Новой риги и почти до Химок) то навигатор начинает наворачивать круги вокруг Шереметьево, со скоростью 100км/ч на высоте около 1000м. но положение это не всё, там еще и время врёт минут на 5. тоесть если ваш GPS датчик времени стоит в районе такой аномалии (а их у нас нонче куча) то он честно будет отдавать честный стратум с совершенно левым временем.
23 часа назад, straus сказал:
128.102.18.31:37
Однако, раритет, класс B.
И интернет говорит, что это скорее почтовик, чем сервер времени.
В 28.07.2026 в 21:49, Ivan_83 сказал:
ну вот на pool.ntp.org основная надежда. во всяком случае, если они лягут, то шумиха будет, так что не пропустишь
поэтому моя логика — этот самый пул, плюс в первую очередь для улучшения точности несколько серверов от властей/жирных корпоратов/etc, до которых пинг поменьше
В 02.08.2026 в 02:25, Ivan_83 сказал:
меня больше беспокоит, что это тратит ресурсы неких добрых самаритян, если все будут как вы использовать под сотню серверов, нагрузка на сервера вырастет на порядок.
я вон даже iburst стараюсь не ко всем источникам применять
Моя идея в том, чтобы такие катастрофы переживать с улыбкой и словами: "а мне пофик, опять мимо!" 🙂
Отсюда же и всякие сервисы в chroot RO и прочие не дефолтные настройки
А от пула я оставил две записи, и остальные у меня по принципу чтобы в разных локациях и в разных доменах были. Те технически оно имеет хорошие шансы пережить чебурнет/отвалы множества сегментов инета.
Так вы бы почитали конфиг, у меня минимальный интервал 2^12 секунд = 4096 сек = ~68 минут. И возможно я ещё увеличу и докину серверов.
Это вам не дефолтные 2^8 = ~4 минуты.
Всех здравствуйте.
5й день возникают вопросы с DNS серверами.
Работало-работало и в начале месяца резко - DNS_PROBE_FINISHED_NXDOMAIN
Причем это все с разными публичными ДНС серверами (8888, 1111, 9999, 208.67.222.222)
Регионально Хабаровский край, Вымпелком.
Как только меняю настройки на НСДИ - работает, кроме зарубежных нежелательных.
Знакомо кому?
