Коллеги, кто как борется с тем что абоненты хватают вирусню и забивают пулы трансялциями?
На ASR1001x я настроил примерно так
ip nat settings gatekeeper-size 2048
ip nat settings pap limit 60
ip nat translation timeout 180
ip nat translation tcp-timeout 180
ip nat translation udp-timeout 90
ip nat translation finrst-timeout 20
ip nat translation syn-timeout 20
ip nat translation dns-timeout 20
ip nat translation icmp-timeout 6
ip nat translation max-entries 1048576
ip nat translation max-entries all-host 3000
Подрезаю тем кто привышает
event manager applet NAT_HOST_LIMIT
 event syslog pattern ".*NAT-4-ALL_HOST_MAX_ENTRIES.*"
 action 001.0 regexp "reached for ([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)" "$_syslog_msg" MATCH ADDR
 action 002.0 syslog msg "EEM: NAT all-host limit reached for $ADDR, applying host limit 512"
 action 003.0 cli command "enable"
 action 003.1 cli command "configure terminal"
 action 003.2 cli command "ip nat translation max-entries host $ADDR 512"
 action 003.3 cli command "end"
ну и очищаю время от времени
event manager directory user policy "flash:/eem"
event manager policy nat_lim_res_cron.tcl type user
more flash:/eem/nat_lim_res_cron.tcl
::cisco::eem::event_register_timer cron tag cron_reset name nat_limit_reset cron_entry "*/5 * * * *"  maxrun 200
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
action_syslog msg "TCL NAT LIMIT CLEANUP started"
if {[catch {cli_open} result]} {
    action_syslog msg "TCL NAT LIMIT CLEANUP: cli_open failed"
    exit 1
array set cli $result
cli_exec $cli(fd) "enable"
set max_translations "512"
set output [cli_exec $cli(fd) "show running-config | include ^ip nat translation max-entries host .* $max_translations"]
set found 0
set re "ip nat translation max-entries host (\\d+\\.\\d+\\.\\d+\\.\\d+) $max_translations"
foreach line [split $output "\n"] {
    if {[regexp $re $line match ip]} {
        set found 1
        action_syslog msg "TCL NAT LIMIT CLEANUP: would remove: no ip nat translation max-entries host $ip $max_translations"
        cli_exec $cli(fd) "configure terminal"
        cli_exec $cli(fd) "no ip nat translation max-entries host $ip $max_translations"
        cli_exec $cli(fd) "end"
if {$found == 0} {
    action_syslog msg "TCL NAT LIMIT CLEANUP: no temporary NAT host limits found"
cli_close $cli(fd) $cli(tty_id)
Оно как-то не очень красиво, и стрелять начало буквально последние неделю-две
Кто-то еще замечал аномалии?
Мы сталкиваемся с завирусованными китайскими TV приставками (на которых (в РФ) работает Youtube,Netflix, etc), причём у некоторых уже с завода, т.е. сброс не спасает.
К сожалению, приходится тратить время на таких абонентов (анализ netflow):
Блокируем абонента с уведомлением что у него вирус, просим сбросить роутер к заводским, сбросить/отключить ТВ приставку от сети
Зарезаем рецидивистам исходящий трафик до 10 Мбит/с или меньше
Посылаем мастера особо нервным (он пытается найти источник и показать это абоненту)
5 часов назад, Urs_ak сказал:
Есть такие планшеты NOMI Corsa (украинская торговая марка NOMI, а так чистый китай). Так вот там вшиты несколько вирусов, которые активируются ровно на следующий день после окончания года работы.
15 часов назад, Urs_ak сказал:
и что дальше? советуете абоненту поменять железку?
6 часов назад, Andrei сказал:
Ну да, а что ещё остаётся. Абоненту же тоже не нравится что ему интернет блокируют и ему надо звонить и просить включить.
Последнему мы сказали, чтобы поменял на какой-нибудь SberBox. Он был не против.
Quote
А другой провайдер не блокирует. У которого нет NAT, или которому просто пофиг.
23 часа назад, rm_ сказал:
А вот это чревато улететь пулом в блек холл или того хуже - всей автономнкой.
Edited by witch
В 09.05.2026 в 18:49, sirmax сказал:
У нас используется микротик, на нем такой проблемы нет. Точнее много микротиков, которые распределяют нагрузку между собой.
На ASR сколько доступных НАТ трансляций? 1.5 миллиона?
13 часов назад, witch сказал:
Это зависит от аплинка/аплинков
10 часов назад, Saab95 сказал:
Точнее вы про нее не знаете так как не мониторите число трансляций
В 10.05.2026 в 09:31, disappointed сказал:
Так наверное tcp скан, сделать так ip nat translation syn-timeout 5
Да, так жалоб стало меньше (даже у тех кто залетел в лимиты)
Основная суть проблемы - что  хомяки воют "инет плохо работает"
В 12.05.2026 в 13:23, sirmax сказал:
Ну так у них роутер дома ласты склеивает + вайфай ложится от синфлуда. Вот тут честно говоря лучше наглухо выключать сразу, чтобы не переходило в хроническое течение. И уже на обратной связи объяснять... И не звонить самим, не заходит такая забота, думают, что их пытаются нагреть на платный выезд.
Стреляет уже давно.
На платформе ASR глобально помог только переход на
ip nat settings mode cgn
В версии 17.09 завезли
ip nat settings log-destination
4 часа назад, sdy_moscow сказал:
если CGNAT - то рекомендую тазик с АНАТ - надежно, удобно, + есть средства борьбы со спамерами.
Все хорошо, но к линуксу нужно сильно больше внимания.
ну и у меня на том же asr еще шейпер и бгп.
плюс я не видел серверов с бп на 48в
(хотя я сам за линукс, но 😞 )
5 минут назад, sirmax сказал:
БП бывают разные, ну а так-то да....
1 час назад, sirmax сказал:
добавлю про линух - разработчики ядра нередко на ровном месте решают, что "эта функция нам больше не нужна" и сносят ее в какой-то минорной версии. или меняют синтаксис вызова.
и секс со сборкой сторонних модулей возникает на ровном месте, когда, казалось бы, его не должно было быть в принципе.
привет ipt_netflow передает последнее ядро дебиана 11го - 5.10.251. на 5.10.197 собирается, а на этой - уже нет.
ну и далеко не первый раз такое. с драйверами от мелланокса подобное ловил на 4м ядре тоже.
  • 4 months later...
3 часа назад, rdmitrich сказал:
Добрый вечер, по итогу ТС - как справился с проблемой ??
Нет глобально не справился, абоны ловят что то, из режет на циске по числу сессий, они воют, техподдержка им сообщает «лечите» иногда идет наш человек лечить.
Можно ли это считать решением? Ну частично да, но ставить dpi- подобное и пробовать понять что создает сессии я конечно не буду. Каждому хомяку жопу не подотрешь.
11 часов назад, straus сказал:
А что у тебя в договоре с абонентом написано по этому поводу?
А что там можно написать? Я не в курсе - но для демонстрации приносим чистый ноут, отключаем все абонентское, показываем - проблемы нет. Дальше претензии не к нам.
8 часов назад, straus сказал:
Я к тому, что право провайдера резать сессии в таких случаях лучше прописать в договоре. Воизбежание, так сказать.
Юридические вопросы лежат за пределами моей компетенции, но размышления технически, если число трансляций не указано в договоре оно может быть любым?
