Доброго времени суток.
Прошил коммутатор S5700-24ET6x, через WEB. Прошивку брал отсюда https://data.nag.wiki/BDCOM switches/Firmware/BDCOM S5700-24ET6X/ версия прошивки BD_S5700-24ET6X_2.2.0F_118775.
После процедуры оборудование перестало загружаться.
Через консоль видно, есть ошибки при загрузке.
U-Boot 2011.12.(3.6.11.55242) (Sep 27 2024 - 16:50:53)
Board: RTL9310 CPU:1000MHz LX:200MHz DDR:800MHz
DRAM:  512 MB
SPI-F: WINBOND/EF4018/MMIO16-1/ModeC 1x16 MB (plr_flash_info @ 83f65740)
Loading 65536B env. variables from offset 0xe0000
Net:   Net Initialization Skipped
No ethernet found.
Hit Esc key to stop autoboot:  0
## Booting kernel from Legacy Image at b40f0000 ...
   Image Name:   bootrom
   Created:      2025-09-12   6:44:37 UTC
   Image Type:   MIPS Linux Kernel Image (gzip compressed)
   Data Size:    1373514 Bytes = 1.3 MB
   Load Address: a2100000
   Entry Point:  82100000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting kernel ...
System Bootstrap, Version 0.1.1, Serial No:0020088700638
Copyright (c) by Shanghai Baud Data Communication Co., Ltd.
Current time: 1970-1-1 0:00:01
SDRAM Fast Test...............................PASS!
Flash Fast Test...............................PASS!
Loading Switch.bin......
Start Decompress Switch.bin
Decompress 7201719 byte. Please wait system up...
old idle is 84c3bc40,new idle is 0
System startup OK
[2][init] !rtkErr: Hardware-profile probe fail.
*** [RT_ERR] rtcore_init.c:405: In function 'rtcore_init'
             Error Code: 0xFFFFFFFF
[2][init] !rtkErr: rtcore_init failed!!
*** [RT_ERR] usrAppStart.c:188: In function 'main'
ssp_rtk_init                                        fail
S3954_family_halphy_rtk_config_init 843 unknown switch type:11fc
S3954_family_halphy_rtk_config_init 1023 unknown switch type:11fc
Exception Type:2-TLB miss exception (load or instruction fetch)
TaskID=874939a0, TaskName=root
zero            at            v0            v1
00000000        fffffffe        00000000        00000000
a0            a1            a2            a3
822a0000        874938e8        00000000        83235468
t0            t1            t2            t3
0000ff00        ffff00ff        343a3035        3a313120
t4            t5            t6            t7
00002324        00000000        874938c8        00000000
s0            s1            s2            s3
00000010        81690000        86d73e58        822fb984
s4            s5            s6            s7
82300000        00000000        00000000        00000000
t8            t9            k0            k1
874938ce        874938ce        00000000        00000000
gp            sp            s8            ra
81d2ae20        87493890        00000000        8019509c
pc
801950b4
sr    = 1000ff01
cause = 00000008
BreakNum: 8, Offset: 0xafffe200
System is rebooting, flag=0xf0004
callback func[0] 0x8075c404 execute
callback func[1] 0x8109ab5c execute
Кто сталкивался с данной проблемой? Есть варианты как откатить или обновиться на рабочую версию прошивки?
  • 2 weeks later...
7 часов назад, KILyukhin сказал:
Вопрос решился через обращение в Тех.Поддержку
Откатились на старую, или заставили работать эту?
Пришлось снести конфигурацию и настроить с нуля?
