Всем привет!
Не хочет конфигурироваться, кто знает как правильно 4-х портовые конфижить откликнитесь
%GPON-ONUCONFIG: ONU config failure on port GPON0/3:34, reason: Flow-Mapping.
interface GPON0/3:34
 gpon onu model-id GP1702-4G
 gpon onu tcont-virtual-port-bind-profile tvbind-default
 gpon onu flow-mapping-profile flow-mapping-default
 gpon onu virtual-port 1 gem-port 289
 gpon onu virtual-port 1 dynamic maximum 2
 gpon onu tcont 1 alloc-id 289
 gpon onu uni 1 vlan-profile vlan_262
 gpon onu uni 1 uni-profile eth_port
 gpon onu uni 2 vlan-profile vlan_262
 gpon onu uni 2 uni-profile eth_port
 gpon onu uni 3 vlan-profile vlan_262
 gpon onu uni 3 uni-profile eth_port
 gpon onu uni 4 vlan-profile vlan_262
 gpon onu uni 4 uni-profile eth_port
gpon profile onu-rate-limit ratelimit-default id 1
 gpon-profile pir 1244160 cir 9472
gpon profile onu-uni eth_port id 2
 gpon-profile max-frame-size 1550
gpon profile onu-tcont tcont-default id 1
 gpon-profile tcont-type 3 pir 1244160 cir 9472
gpon profile onu-loopback-detection loopback_on_onu id 1
 gpon-profile message-frequency 60
 gpon-profile loop-recovery-interval 60
 gpon-profile port-vlan-table uni 1
gpon profile onu-virtual-port virtual-port-default id 1
 gpon-profile encryption disable
 gpon-profile upstream queue 8
 gpon-profile upstream rate-limit-profile ratelimit-default
 gpon-profile downstream queue 8
 gpon-profile downstream rate-limit-profile ratelimit-default
gpon profile onu-tcont-virtual-port-bind tvbind-default id 1
 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default
gpon profile onu-flow-mapping flow-mapping-default id 1
 gpon-profile entry 1 uni type eth-uni all
 gpon-profile entry 1 virtual-port 1
gpon profile onu-flow-mapping flow-mapping-default-hgu id 2
 gpon-profile entry 1 uni type veip all
gpon profile onu-vlan vlan_260 id 1
 gpon-profile vlan mode tag
 gpon-profile vlan pvid 260 0
gpon profile onu-vlan vlan_261 id 2
 gpon-profile vlan pvid 261 0
gpon profile onu-vlan vlan_262 id 3
 gpon-profile vlan pvid 262 0
gpon profile onu-vlan vlan_263 id 4
 gpon-profile vlan pvid 263 0
gpon profile onu-vlan vlan_264 id 5
 gpon-profile vlan pvid 264 0
gpon profile onu-vlan vlan_265 id 6
 gpon-profile vlan pvid 265 0
gpon profile onu-vlan vlan_266 id 7
 gpon-profile vlan pvid 266 0
gpon profile onu-vlan vlan_267 id 8
 gpon-profile vlan pvid 267 0
gpon profile onu-vlan vlan_268 id 9
 gpon-profile vlan pvid 268 0
gpon profile onu-vlan vlan_269 id 10
 gpon-profile vlan pvid 269 0
gpon profile onu-vlan vlan_270 id 11
 gpon-profile vlan pvid 270 0
gpon profile onu-vlan vlan_271 id 12
 gpon-profile vlan pvid 271 0
gpon profile onu-vlan vlan_272 id 13
 gpon-profile vlan pvid 272 0
gpon profile onu-vlan vlan_273 id 14
 gpon-profile vlan pvid 273 0
gpon profile onu-vlan vlan_274 id 15
 gpon-profile vlan pvid 274 0
gpon profile onu-vlan vlan_275 id 16
 gpon-profile vlan pvid 275 0
gpon onutype-template onutype-default-hgu
 gpon-onutype match ctc-onu-type HGU
 gpon-onutype config tcont-virtual-port-bind-profile tvbind-default
 gpon-onutype config flow-mapping-profile flow-mapping-default-hgu
gpon onu-config-template internet_access
 cmd-sequence 001 gpon onu tcont-virtual-port-bind-profile tvbind-default
 cmd-sequence 002 gpon onu flow-mapping-profile flow-mapping-default
 cmd-sequence 003 gpon onu uni 1 vlan-profile %1
 cmd-sequence 004 gpon onu uni 1 uni-profile eth_port
 cmd-sequence 005 gpon onu loopback-detection-profile loopback_on_onu
 cmd-sequence 006 gpon onu virtual-port 1 dynamic maximum 2
