Доброго дня всем!
Прошу помощи (чяднт?).
Имеется железка BDCOM(tm) GP3600-08B Software, Version 10.3.0D Build 127913 и тестовая ОНУ (XPON) CDATA Ver: F690.1B ModelID:FD511G-X
Создал профайлы/тимплейты, привязал на пон порт:
gpon profile onu-rate-limit ratelimit-default id 1
 gpon-profile pir 1244160 cir 1244160
gpon profile onu-tcont tcont-default id 1
 gpon-profile tcont-type 3 pir 1024000 cir 512
gpon profile onu-virtual-port virtual-port-default id 1
 gpon-profile encryption disable
 gpon-profile upstream queue 8
 gpon-profile downstream queue 8
gpon profile onu-tcont-virtual-port-bind tvbind-default id 1
 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default
gpon profile onu-flow-mapping flow-mapping-default id 1
 gpon-profile entry 1 uni type eth-uni all
 gpon-profile entry 1 virtual-port 1
gpon profile onu-flow-mapping flow-mapping-default-hgu id 2
 gpon-profile entry 1 uni type veip all
gpon profile onu-vlan ONU-VLAN-441 id 1
 gpon-profile vlan mode tag
 gpon-profile vlan pvid 441 0
gpon onu-config-template ONU-TMPL-441
 cmd-sequence 001 gpon onu tcont-virtual-port-bind-profile tvbind-default
 cmd-sequence 002 gpon onu flow-mapping-profile flow-mapping-default
 cmd-sequence 003 gpon onu uni 1 vlan-profile ONU-VLAN-441
interface GPON0/1
 gpon onu-authen-method sn
 gpon pre-config-template ONU-TMPL-441 bind-onuid 1-128
 gpon bind-onutype onutype-default-hgu precedence 127
 gpon bind-onutype onutype-default precedence 128
 gpon bind-onu sn HWTC:AF564A61 1
 filter dhcp
 switchport trunk vlan-allowed 441
 switchport trunk vlan-untagged none
 switchport mode trunk
 switchport protected 1
 storm-control broadcast threshold 5
 storm-control multicast threshold 5
 storm-control unicast threshold 5
interface GPON0/1:1
 gpon onu model-id FD511G-X
 gpon onu virtual-port 1 gem-port 256
 gpon onu tcont 1 alloc-id 256
Онушка регистрируется, визуально все ок:
Interface GPON0/1 has bound 1 ONUs:
IntfName       VendorID  ModelID      SN               LOID                     Status   Config Status Active Time
GPON0/1:1      HWTC      FD511G-X     HWTC:AF564A61    N/A                      active   success       2026-01-03 16:07:04
Но мак роутера на порту не появляется:
GPON-CHG-01#sh mac address-table interface gpon0/1:1
        Mac Address Table (Total 0)
Vlan    Mac Address       Type       Ports
И в статистике на этом интерфейсе только отправленные, входящие по нулям
  • 4 weeks later...
