есть циска и меланокс, соединённые оптикой, трансиверы snr 100GBASE-LR4
циска Nexus9000 C93180YC-EX
switch# sh interface eth 1/53
Ethernet1/53 is down (Link not connected)
admin state is up, Dedicated Interface
  Hardware: 1000/10000/25000/40000/50000/100000 Ethernet, address: f80b.cb1b.e3b8 (bia f80b.cb1b.e3b8)
  MTU 9216 bytes, BW 100000000 Kbit , DLY 10 usec
  reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  auto-duplex, 100 Gb/s, media type is 100G
  Beacon is turned off
  Auto-Negotiation is turned off  FEC mode is Off
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
    admin fec state is off, oper fec state is off
  Last link flapped never
  Last clearing of "show interface" counters never
  0 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 0 bits/sec, 0 packets/sec
    30 seconds output rate 0 bits/sec, 0 packets/sec
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 0 bits/sec, 0 packets/sec
    300 seconds output rate 0 bits/sec, 0 packets/sec
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
switch# sh interface eth 1/53 tra d
Ethernet1/53
    transceiver is present
    type is QSFP-100G-LR4
    name is OEM
    part number is QSFP-100G-LR4-S
    revision is 01
    serial number is 8QAA014395
    nominal bitrate is 25500 MBit/sec
    Link length supported for 9/125um fiber is 10 km
    cisco id is 17
    cisco extended id number is 220
Lane Number:1 Network Lane
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   39.82 C        75.00 C     -5.00 C     70.00 C        0.00 C
  Voltage        3.22 V         3.63 V      3.04 V      3.46 V        3.13 V
  Current       53.44 mA       65.00 mA    30.00 mA    60.00 mA      35.00 mA
  Tx Power       1.74 dBm       5.49 dBm   -5.30 dBm    4.49 dBm     -4.30 dBm
  Rx Power      -9.87 dBm       5.49 dBm  -11.61 dBm    4.49 dBm    -10.60 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
Lane Number:2 Network Lane
  Current       54.90 mA       65.00 mA    30.00 mA    60.00 mA      35.00 mA
  Tx Power       2.38 dBm       5.49 dBm   -5.30 dBm    4.49 dBm     -4.30 dBm
  Rx Power      -8.79 dBm       5.49 dBm  -11.61 dBm    4.49 dBm    -10.60 dBm
Lane Number:3 Network Lane
  Current       52.43 mA       65.00 mA    30.00 mA    60.00 mA      35.00 mA
  Tx Power       1.64 dBm       5.49 dBm   -5.30 dBm    4.49 dBm     -4.30 dBm
  Rx Power      -9.46 dBm       5.49 dBm  -11.61 dBm    4.49 dBm    -10.60 dBm
Lane Number:4 Network Lane
  Current       53.81 mA       65.00 mA    30.00 mA    60.00 mA      35.00 mA
  Tx Power       0.71 dBm       5.49 dBm   -5.30 dBm    4.49 dBm     -4.30 dBm
mellanox msn2010
Mellanox-MSN2010 [standalone: master] # sh int eth 1/22
Eth1/22:
  Admin state                      : Enabled
  Operational state                : Down
  Last change in operational status: 0:00:06 ago (9288 oper change)
  Boot delay time                  : 0 sec
  Description                      : N\A
  Mac address                      : 50:6b:4b:9b:08:4c
  MTU                              : 9200 bytes (Maximum packet size 9222 bytes)
  Fec                              : no-fec
  Flow-control                     : receive off send off
  Actual speed                     : 100 Gbps
  Auto-negotiation                 : Disabled
  Width reduction mode             : Unknown
  Switchport mode                  : access
  MAC learning mode                : Enabled
  Forwarding mode                  : inherited cut-through
  Telemetry sampling: Disabled   TCs: N\A
  Telemetry threshold: Disabled  TCs: N\A
  Telemetry threshold level: N\A
  Last clearing of "show interface" counters: 2D:0H
  60 seconds ingress rate                   : 0 bits/sec, 0 bytes/sec, 0 packets/sec
  60 seconds egress rate                    : 264 bits/sec, 33 bytes/sec, 1 packets/sec
  Rx:
    0                     packets
    0                     unicast packets
    0                     multicast packets
    0                     broadcast packets
    0                     bytes
    0                     discard packets
    1                     error packets
    0                     fcs errors
    0                     undersize packets
    0                     oversize packets
    0                     pause packets
    0                     unknown control opcode
    0                     symbol errors
    0                     discard packets by storm control
  Tx:
    79610                 packets
    47                    unicast packets
    78759                 multicast packets
    804                   broadcast packets
    5630900               bytes
    1                     discard packets
    0                     error packets
    0                     hoq discard packets
Mellanox-MSN2010 [standalone: master] # sh int eth 1/22 tra d
Port 1/22 transceiver diagnostic data:
  Temperature (-127C to +127C):
    Temperature          : 33 C
    Hi Temp Alarm Thresh : 75 C
    Low Temp Alarm Thresh: -5 C
    Temperature Alarm    : None
  Voltage (0 to 6.5535 V):
    Voltage              : 3.28690 V
    Hi Volt Alarm Thresh : 3.63000 V
    Low Volt Alarm Thresh: 3.05000 V
    Voltage Alarm        : None
  Tx Bias Current (0 to 131 mA):
    Ch1 Tx Current          : 55.41400 mA
    Ch2 Tx Current          : 55.69800 mA
    Ch3 Tx Current          : 52.76600 mA
    Ch4 Tx Current          : 53.42800 mA
    Hi Tx Crnt Alarm Thresh : 65.00000 mA
    Low Tx Crnt Alarm Thresh: 30.00000 mA
    Ch1 Tx Current Alarm    : None
    Ch2 Tx Current Alarm    : None
    Ch3 Tx Current Alarm    : None
    Ch4 Tx Current Alarm    : None
  Tx Power (0 mW to 6.5535 mW / 8.1647 dBm):
    Ch1 Tx Power             : 1.34170 mW / 1.27655 dBm
    Ch2 Tx Power             : 1.79310 mW / 2.53605 dBm
    Ch3 Tx Power             : 1.40780 mW / 1.48541 dBm
    Ch4 Tx Power             : 1.50330 mW / 1.77046 dBm
    Hi Tx Power Alarm Thresh : 3.54810 mW / 5.49996 dBm
    Low Tx Power Alarm Thresh: 0.29510 mW / -5.30031 dBm
    Ch1 Tx Power Alarm       : None
    Ch2 Tx Power Alarm       : None
    Ch3 Tx Power Alarm       : None
    Ch4 Tx Power Alarm       : None
  Rx Power (0 mW to 6.5535 mW / 8.1647 dBm):
    Ch1 Rx Power             : 0.37060 mW / -4.31095 dBm
    Ch2 Rx Power             : 0.40260 mW / -3.95126 dBm
    Ch3 Rx Power             : 0.37720 mW / -4.23428 dBm
    Ch4 Rx Power             : 0.29390 mW / -5.31800 dBm
    Hi Rx Power Alarm Thresh : 3.54810 mW / 5.49996 dBm
    Low Rx Power Alarm Thresh: 0.06920 mW / -11.59894 dBm
    Ch1 Rx Power Alarm       : None
    Ch2 Rx Power Alarm       : None
    Ch3 Rx Power Alarm       : None
    Ch4 Rx Power Alarm       : None
  Vendor Date Code (dd-mm-yyyy): 19-06-2025
со стороны мелланокса линк флапается каждые несколько секунд. со стороны циски просто нет линка.
в какую сторону копать?
пробовал включать/выключать автоопределение скорости и fec с обеих сторон, результата не дало.
у вас при почти одинаковых TX уровнях с обоих сторон - RX сильно разнЯтся. я бы сразу грешил на физику - оптический канал между точками - что-то с ним не очень (в сторону от мелланокса к циске затухания сильно больше).
это вижу, но причиной отсутствия связи это же не должно быть.
забыл добавить, что mellanox-mellanox работало нормально, с одной стороны sn2700 (брендированный под hp), с другой — тот же 2010
9 часов назад, edo сказал:
  Port mode is access
  EtherType is 0x8100
  0 interface resets
  RX
    0 Rx pause
  TX
    0 jumbo packets
    0 Tx pause
Ethernet1/53
    name is OEM
    revision is 01
    cisco id is 17
mellanox msn2010
Eth1/22:
  Description                      : N\A
  Fec                              : no-fec
  Rx:
    0                     packets
    0                     unicast packets
    0                     multicast packets
    0                     broadcast packets
    0                     bytes
    0                     discard packets
    1                     error packets
    0                     fcs errors
    0                     undersize packets
    0                     oversize packets
    0                     pause packets
    0                     symbol errors
  Tx:
    79610                 packets
    47                    unicast packets
    5630900               bytes
    1                     discard packets
    0                     error packets
    Temperature          : 33 C
    Voltage              : 3.28690 V
И руками fec тоже ставили? Чтобы не авто был. Возможно ещё косяк с прошивкой модулей
33 минуты назад, fractal сказал:
да, в исходном посте как раз
и
  Fec                              : no-fec
36 минут назад, fractal сказал:
просил в наге прошить под циску. эти же трансиверы на той же линии между двумя мелланоксами работали
1 час назад, edo сказал:
и
  Fec                              : no-fec
Там ещё возможно есть fec под 100g,попробуйте выставить с двух сторон, по идее для таких модулей как раз fec обязателен, на на snr 100g у меня были проблемы с многомодом только, там fec руками выключаю, в авто ситуация как у Вас, сигнал есть, а линки не стартуют, подергаешь со стороны нексус и линк поднимается, через раз в общем.
Хотя в даташиты у Cisco модуля указано что fec на этом типе не нужен, скорее всего есть ошибка в прошивке, можно попросить их тп перешить, в городе есть офис или склад наг? Нам прям там перешивали модули где был косяк с прошивкой
46 минут назад, edo сказал:
циска не даёт включить fec для модуля
Логично, эта фича модуля если он умеет, то предлагает выбор, на 100g под mpo к примеру pam4 включается
пока решил обновить mellanox, достаточно старая прошивка.
руки чешутся обновить и циску тоже, непонятно почему наг отгрузил её с nxos.9.3.14, когда доступен nxos.10.1.2
есть какие-либо причины не шить 10.1.2?
Скрытый текст
окирпичу свитчи и проблема решится сама собой 🤣
3 часа назад, fractal сказал:
нет. так что перешивка трансиверов — не самая быстрая история. и на линк мелланокс-мелланокс эта пара трансиверов работала, и сейчас циска в логах на трансивер не ругается, лишь линк не поднимает )
57 минут назад, edo сказал:
Вполне ситуация похожа на мою, также было, в логах чисто, но линк не up
10.3.6 актуальная рекомендованная, поставщик обычно сгружает с фактической прошивкой
https://cloud.mail.ru/public/LRzg/gb3K3RP2b
4 часа назад, fractal сказал:
А нексус - нексус?
проверить можно, но геморно (на втором конце пока нормальной стойки нет,  sn2010 достаточно компактный, а тащить туда некус и пробовать разместить — так себе удовольствие)
у меня сейчас мысль, что мелланоксы включали между собой fec, а канал так себе, без fec линк не поднимается.
не уверен, что до понедельника получится проверить
10.3.6
спасибо
кстати, а почему не 10.3.8, который рядом лежит?
Можно, рекомендованный 10.3.6 у меня стоит такой, стабильно, 10.3.8 не тестировал
Вариант, модули не оригинал, возможно в них как раз fec имеется, у huawei на таком же модуле точно есть, это в основном проблема не оригинала(если шить прям дамп с оригинала, такого же, то все работает хорошо) , правда я юзал модули в основном между cisco, проблемы были только со 100g многомод (основная проблема прошивка), ниже проблем не было, одномод 100g одноглазый на 40 км тоже стабильно
4 часа назад, straus сказал:
честно говоря, не понял к чему это, тут рассматриваются всякие gearbox'ы и 10×10G, у меня ничего такого нет. два одинаковых трансивера, которые умеют только 4×25G, соединённые пассивной оптикой.
Users sometimes wonder why the FEC requirement does not also extend to 100GBASE-LR4 and 100GBASE-ER4.
ИМХО скользкая формулировочка, не «мы не поддерживаем fec на lr4», а «требования по поддержке fec не распространяются на lr4». но, судя по всему, имеется в виду таки первое.
3 часа назад, edo сказал:
Это только для оригинала актуально, на аналоге может быть fec, или наоборот не быть
В 22.11.2025 в 19:16, fractal сказал:
вопрос немного «на поговорить», а какое отношение имеет трансивер к fec?
как я представляю, дело трансивера — передавать поток битов, а какая кодировка там внутри — ему и не важно
FEC может выполняться трансивером (встроенная функция) либо снаружи. Причём если снаружи, и линк четырёхканальный LR4 - возможны варианты с FEC (на общий поток либо четыре отдельных потока). Потому и...
В 24.11.2025 в 15:07, straus сказал:
а такое точно бывает?
в факе мелланокса явно сказано:
In Nvidia products the FEC processing takes place in the switches and network cards. Cables and transceivers are not part of FEC processing.
и в любом случае это не причина запрещать включать fec на lr4, в чём смысл этого запрета?
теперь возвращаясь к моим баранам проблемам:
сделал опять линк mellanox-mellanox, линк поднялся с rs-fec.
проверил, 10000 пингов по 9к (jumbo frames включены) прошли без потерь.
попробовал отключить fec, линк всё равно поднялся, пинг прошёл уже с потерями, 13%
включил fc-fec, тоже потери, 11%.
напомню, ассиметрия между волокнами на 4-5дБ (на одном волокне затухание больше, чем на другом)
волокно арендуемое, попробуем заставить исправить 😉
и тогда сделаю ещё один подход с циской, посмотрим поможет ли
ну и ещё из «интересного»: трансивер по спекам потребляет до 4.5Вт. вычитал в доке мелланокса, что в sn2700 почти все порты рассчитаны на 3.5Вт, а 1, 2, 31 и 32 порт — на 5Вт.
изначально я этого не знал, и вставлял трансивер в порты 15-16.
воткнул в 1 порт, линка нет. воткнул в 2 порт — линка нет. перепроверил настройки портов — всё идентично.
воткнул обратно в 16 порт — линк есть.
wtf?!? это мелланокс кривой? или snr кривые трансиверы оемит?
это хорошо, что я изначально доку не читал 🤣, а то убил бы ещё кучу времени в поисках причин, по которым линк не поднимается
