После перехода клиента с другой сети - он мне отдал ненужную ему KN-50. Валяется уже пол года. Паролей не знаю, ничего не знаю. С ними не работал.
Тут дома решил заменить точку доступа - вспомнил об этой железяке.
Вопрос: Смогу заставить ее работать в режиме точки доступа ? Смогу сбросить настройки (как-то), дабы получить доступ по вебу (в принципе, я ее локатором нашел в сети, она пингуется. И на запрос вываливает окно авторизации. Но ни логина-ни пароля я не знаю).
KN50 Simple TurboCell Bridge
Upgrade Instructions
The following instructions are for Internet Explorer version 6.x. Customers using other browsers may see slightly
different options and terminology used. We strongly recommend that you use Internet Explorer for this procedure.
The licenses and upgrades are available from the license-it website at:
https://www.license-it.com/index.html
1. Log in with the user ID of 'guest' and the password of 'guest'.
2. Select the 'Download IP2K type Firmware Upgrade by MAC address' link.
3. Copy and paste the MAC addresses displayed on the Information screen of the product's web interface.
Note: Please be sure you actually have Version 1.00-xxxxxx of the TurboCell firmware and not standard 802.11b.
4. Enter in the MAC addresses with no separators within the MAC address themselves. Use a comma (,) as the
separator between MAC addresses, as in the example shown below.
0020F60500D7,0020F60500D2
Note: You can specify ranges of MAC addresses, but we recommend that you avoid this method because it can
cause problems when trying to obtain your upgrade licenses.
6. Select 'KNUB-3100-01-1-10-01-022418' for the KN-50 Simple TC Bridge with a Hermes I radio. Select the
'KNUB-3100-02-1-10-01-022418' for the Hermes II radio to upgrade to version 1.10-01. If you are unsure of what
version you have please refer to the Information screen of the product’s web interface.
CAUTION: DO NOT attempt to perform this upgrade unless you have confirmed your radio chipset.
7. Click the Search button. A dialog box will appear showing how many licenses have been found.
8. Click OK
9. Click the Download Key button. A File Download dialog box will appear asking you to save the file.
10. Click the save button. At this point, navigate to the location where you wish to save the zip file containing your
licenses, and click the Save button.
11. Click Logoff at the menu bar at the top of the window.
12. Use the following TFTP procedure to load the software to the unit.
Note: If for some reason no results are returned for the MAC addresses you have entered, please double check the
MAC addresses and correct as needed and search again, or contact the Distributor or OEM from which the units
were purchased.
KarlNet, Inc.
525 Metro Place N., Suite 100 Dublin, OH 43017
Phone: 614-822-5275 Fax: 614-822-0024 www.karlnet.com sales@karlnet.com support@karlnet.com
________________________________________
Page 2
KN50 Simple TurboCell Bridge Upgrade Instructions
KarlNet, the KarlNet logo are trademarks of KarlNet, Inc. All other trademarks mentioned in this document are the property of their respective owners. KarlNet does not take
responsibility for any damages incurred due to technical inaccuracies in this document. Contents are subject to change without notification. © 2004 KarlNet, Inc. All rights reserved.
TSS-04-0001 Rev 040407
Using TFTP from the Command Prompt
CAUTION: We highly recommend that you open the web interface for your TurboCell Ethernet Bridge
and set the IP Address Mode to “Static” on the IP Settings screen before attempting the TFTP procedure.
Note: If you have lost your IP Address, you can obtain the default IP address of 10.0.1.210 by pressing the Reset
button on your hardware device. This will clear existing configuration settings and return you to the default settings.
TFTP PROCEDURE
1. Select Start/Run, type the word “command” and click the OK button to open a command prompt. The command
prompt window opens.
2. Type cd followed by the path to the directory where you have stored your .bin files (for example, cd bin
tcethernetbridge).
3. Enter the following command:
tftp –i <IP_ADDRESS> PUT <FILENAME> /
where <IP_ADDRESS> is the IP Address of the hardware device you wish to upgrade, and <FILENAME> is the name
of the *app-upg.bin file you wish to load onto the hardware device.
For example: tftp –i 10.0.0.5 put KNUB-3100-0B-01-1-10-01-022418-0050BA47F510-app-upg.bin / <Enter>
Note: Make sure to include the forward slash ( / ) at the end of the Command line.
4. Enter the following command:
tftp -i <IP_ADDRESS> PUT <FILENAME>/
of the *-webpages-*.bin file you wish to load onto the hardware device.
U3100-0B-01-1-10-01-022418-webpages-karlnet.bin /<Enter>
Command line.
5. Repeat steps 3 and 4 for each hardware device you wish to update.
Note: If the units all have the default IP address at the command prompt, type arp -d <Enter> after completing the
upgrade of the web page.
