Muller7777 Posted August 27, 2025 Posted August 27, 2025 день добрый как прошить телефон прошивкой типа spa50x-30x-7-6-2a-recovery при утеряном пароле или сбросить по инструкции с пришивальщика This SPA requires a password in order to be upgraded. If you do not have administrator's privileges for this unit, please contact your Service Provider or network administrator, before proceeding. You must provide the SPA administrator's password to upgrade. If you are the administrator and forgot the password, you may perform a factory reset by entering * * * *, option 73738#, and value 1 from a telephone connected to the unit to be upgraded. * * * * * * * * * * * Warning * * * * * * * * * * * All settings will revert to default values after factory reset! You may not be able to reestablish service after completing this upgrade without first reentering service configuration information. спасибо. Вставить ник Quote
