Здраствуйте!
Возможно данная тема уже обсуждалось не однократно, но всётаки.
Я никак не могу понять как сделать proxy-arp на FreeBSD без использования всякого рода user-lang программ на подобии choparp. Если у кого то есть ссылка на документацию, дайте пожалуйста.
Спасибо.
man 4 arp:
     Proxy ARP is a feature whereby the local host will respond to requests
    for addresses other than itself, with its own address.  Normally, proxy
    ARP in FreeBSD is set up on a host-by-host basis using the arp(8) util-
    ity, by adding an entry for each host inside a given subnet for which
    proxying of ARP requests is desired.  However, the ``proxy all'' feature
    causes the local host to act as a proxy for all hosts reachable through
    some other network interface, different from the one the request came in
    from.  It may be enabled by setting the sysctl(8) MIB variable
    net.link.ether.inet.proxyall to 1.
man 8 arp:
-s hostname ether_addr
       Create an ARP entry for the host called hostname with the Ether-
       net address ether_addr.  The Ethernet address is given as six hex
       bytes separated by colons.  The entry will be permanent unless
       the word temp is given in the command.  If the word pub is given,
       the entry will be ``published''; i.e., this system will act as an
       ARP server, responding to requests for hostname even though the
       host address is not its own.  In this case the ether_addr can be
       given as auto in which case the interfaces on this host will be
       examined, and if one of them is found to occupy the same subnet,
       its Ethernet address will be used.  If the only keyword is also
       specified, this will create a ``published (proxy only)'' entry.
       This type of entry is created automatically if arp detects that a
       routing table entry for hostname already exists.
Чем не устраивает?
