P4 c em0 + Freebsd 5.4 + mpd 3.18 (с один патчем)
Вот он:
mru.patch
--- lcp.c.orig Wed Jul 14 18:02:12 2004
+++ lcp.c Wed Jul 14 18:02:13 2004
@@ -564,8 +564,10 @@
if (!LCP_PEER_REJECTED(lcp, TY_ACCMAP))
cp = FsmConfValue(cp, TY_ACCMAP, -4, &lcp->want_accmap);
if (!LCP_PEER_REJECTED(lcp, TY_MRU))
cp = FsmConfValue(cp, TY_MRU, -2, &lcp->want_mru);
if (lcp->want_magic && !LCP_PEER_REJECTED(lcp, TY_MAGICNUM))
cp = FsmConfValue(cp, TY_MAGICNUM, -4, &lcp->want_magic);
if (lcp->want_callback && !LCP_PEER_REJECTED(lcp, TY_CALLBACK)) {
Привожу кусок mpd.conf
PPPoE639:
new PPPoE639 PPPoE639
load pppoe_def
pppoe_def:
set bundle disable multilink
set bundle disable round-robin
set bundle enable noretry
set ipcp dns xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
set ipcp ranges 10.0.0.200/32 10.200.200.254/32
set iface disable on-demand
set iface disable proxy-arp
set iface route default
set link keep-alive 30 90
# set link mtu 1300
# set link mru 1300
set pppoe disable originate
set pppoe enable incoming
set pppoe service "*"
set link enable chap
set link enable chap-md5
set link enable chap-msv1
set link enable chap-msv2
set iface enable tcpmssfix
set link disable passive callback no-orig-auth check-magic
set link enable chap magicnum
log -chat -bund -fsm -phys -pptp
set radius server xxx.xxx.xxx.xxx videomate 1812 1813
set radius timeout 10
set radius config /usr/local/etc/mpd/radius.conf
set radius retries 3
set bundle enable radius-auth
#set bundle enable radius-acct
set ipcp yes radius-ip
set iface up-script "/root/scripts/up-script.pl"
set iface down-script "/root/scripts/down-script.pl"
set ipcp enable vjcomp
Привожу кусок ifconfig
ng100: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> mtu 1480
inet 10.0.0.200 --> 10.111.6.220 netmask 0xffffffff
ng101: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> mtu 1492
inet 10.0.0.200 --> 10.111.4.111 netmask 0xffffffff
ng102: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> mtu 1492
inet 10.0.0.200 --> 10.111.7.149 netmask 0xffffffff
ng103: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> mtu 1480
inet 10.0.0.200 --> 10.111.6.192 netmask 0xffffffff
ng104: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> mtu 1480
Скорость у абонентов, кот подлючаются через mpd – очень хорошая - до 10 мегабайт/c
(по протоколу ftp)
Баги:
1) Замечено, что при работе http (открытие сайтов) – сайты открываются с некоторой задержкой. Скажем yandex.ru – может открываться от 2-х до 5 секунд
БЕЗ pppoe – через тот же комп - yandex.ru и другие сайты открывается за 1 секунду!!
Когда стоял set link mtu 1300 – при поднятии ng mtu cтавился 1300, при это некоторые сайты открывались еще большей задержкой (вплоть до 20-30 секунд)
Подскажите где грабли?
2)
пингуем абонента без pppoe (IP)
--- 10.0.0.192 ping statistics ---
1035 packets transmitted, 1035 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.273/1.048/10.113/0.748 ms
avg = 1.048 ms
пингуем абонента через pppoe (IP)
--- 10.111.6.192 ping statistics ---
1062 packets transmitted, 1061 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.844/2.409/9.286/0.961 ms
avg = 2.409 ms
это нормально ?
3) нормальный ли приведенный конфиг, может какие нить другие патчи нужно доставить ?
Jab, ты как то говорил про tcpmss patch для mpd - нужно ли его ставить ?
Celeron + em0 + FreeBSD 5.4 + MPD 3.18 без патчей. Хожу с винды через ЭТО в контору, где стоит PIII + fxp (остальное то же) и потом в и-нет. Хожу через провайдерское радио, потом через оптику в контору. Пинг до конторы:
64 bytes from 10.1.1.5: icmp_seq=0 ttl=64 time=5.381 ms
64 bytes from 10.1.1.5: icmp_seq=1 ttl=64 time=5.282 ms
64 bytes from 10.1.1.5: icmp_seq=2 ttl=64 time=5.250 ms
64 bytes from 10.1.1.5: icmp_seq=3 ttl=64 time=5.645 ms
64 bytes from 10.1.1.5: icmp_seq=4 ttl=64 time=28.425 ms
64 bytes from 10.1.1.5: icmp_seq=5 ttl=64 time=5.442 ms
Полоса до конторы мне зарезана примерно до 256кБит. Всё в и-нете открывается мгновенно.
