Добрый день!
Коммутатор SNR-S5210G-24TX-POE-R Ethernet Managed Switch
SoftWare Version 1.9.6
BootRom Version 1.4 (Sep 22 2023 - 11:01:19)
HardWare Version 1.0.0
Подключил SFP MAIPU SFP-GETBH010, порт поднимается, линк есть, но на порту нет MAC-адреса подключенного оборудования.
Порт перевел в 1g.
xe3 transceiver detail information:
Base information:
  SFP found in this port, manufactured by EOPTOLINK INC, on Nov 18 2022.
  Type is 1000BASE-T. Serial number is 965822A570107353.
  Link length is 100 m for copper and active cable.
  Nominal bit rate is 1300 Mb/s.
interface xe3
 description "trunk in Microtik"
 speed-duplex force1g-full
 switchport mode trunk
Interface xe3
  xe3 is up, line protocol is up
  Hardware is XG-SFP+  Current HW addr: 8c1f.6429.fe14
  Description: "trunk in Microtik"
  Port Mode is trunk
  Index 5027 metric 1 mtu 12270 duplex-full(auto) link-speed 1g(auto)
  Time since last status change:0w-0d-0h-25m-39s (1539 seconds)
  FlowControl is off
  Statistics:
  5 minute input rate: 2977 bits/sec (0.0 Mbits/sec)
  Unicast: 0 pps, broadcast: 0 pps, multicast: 0 pps
  5 minute output rate: 1625 bits/sec (0.0 Mbits/sec)
  Unicast: 0 pps, broadcast: 1 pps, multicast: 1 pps
  5 second input rate: 3115 bits/sec (0.0 Mbits/sec)
  5 second output rate: 1780 bits/sec (0.0 Mbits/sec)
  Unicast: 0 pps, broadcast: 0 pps, multicast: 1 pps
  Input packets statistics:
  0 input packets, 512246 bytes
  0 unicast packets, 0 multicast packets, 0 broadcast packets
  734 input error, 734 CRC, 734 drop, 0 IPG error
  0 framing error, 0 false carrier, 0 lenght error, 0 undersize
  0 RX pause frame
  Output packets statistics:
  3170 output packets, 268483 bytes
  2 unicast packets, 1855 multicast packets, 1313 broadcast packets
  0 output errors, 0 collision, 0 late collision, 0 deferred
  0 output discard, 0 TX pause frame
  Output queue drop statistics:
  Q0: 0, Q1: 0, Q2: 0, Q3: 0
  Q4: 0, Q5: 0, Q6: 0, Q7: 0
Подскажите, пожалуйста, куда копать ?
Здравствуйте.
Предлагаем с начала обновить прошивку на коммутаторе:
https://data.nag.wiki/SNR Switches/Firmware/SNR-S5210G-24TX-POE/recommended/
После обновления проверить работоспособность.
В случае, если ситуация не изменится, то оформить заявку на www.nag.support, т.к. у вас явно видны ошибки на порту:    734 input error, 734 CRC, 734 drop, 0 IPG error
