Vital_G Posted April 15, 2025 Posted April 15, 2025 (edited) Добрый день, свитч SNR-S2995G-24TX-POE POE отключен глобально no power inline enable при включении term mon сыпет сообщениями Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Подскажите пожалуйста куда копать? Та же ситуация на SNR-S2995G-48TX-POE NKI-PY-SNR-S2995G-24TX#sh power inline Power Inline Status: Off Power Available: 370 W Power Used: 0 W Power Remaining: 370 W Police: Off Legacy: Off Disconnect: Dc Mode: Signal Pse Type: GD SW Version: 1.4.8.1 NKI-PY-SNR-S2995G-24TX#Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). NKI-PY-SNR-S2995G-24TX#no debug power inline POE debug is off NKI-PY-SNR-S2995G-24TX#Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). Power inline is not supported on interface (null). SNR-S2995G-24TX-POE Device, Compiled on Mar 31 11:16:20 2023 sysLocation 4F, Krasnolesya st, 12a, Ekaterinburg, Russia CPU Mac f8:f0:82:d8:1c:45 Vlan MAC f8:f0:82:d8:1c:44 SoftWare Package Version V705R002C002 BootRom Version 7.5.35 HardWare Version 2.0.1 CPLD Version 2.02 Serial No.:SW002520O106000213 Copyright (C) 2023 NAG LLC All rights reserved Last reboot is warm reset. Uptime is 0 weeks, 0 days, 0 hours, 17 minutes Edited April 15, 2025 by Vital_G Вставить ник Quote
Evgeniy Rychkov Posted April 15, 2025 Posted April 15, 2025 Здравствуйте. Обновите прошивку на коммутаторе. Если не поможет, то создайте обращение к нам на саппорт. Вставить ник Quote
Vital_G Posted April 16, 2025 Author Posted April 16, 2025 Обновление прошивки до V705R002C013 решило проблему. Только после обновление нагрузка на проц возросла с 20 до 30%, но не думаю, что это критично. Спасибо! Вставить ник Quote
Evgeniy Rychkov Posted April 16, 2025 Posted April 16, 2025 Здравствуйте. Увеличение нагрузки это нормально в данном случае Вставить ник Quote
