Доброе время.
Товарищи знатоки есть catalyst 6509
cisco#sh ver
Cisco Internetwork Operating System Software
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF17b, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by cisco Systems, Inc.
Compiled Tue 15-Mar-11 21:24 by ccai
Image text-base: 0x40101040, data-base: 0x42DDD9B0
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF17b, RELEASE SOFTWARE (fc1)
cisco uptime is 2 days, 10 hours, 37 minutes
Time since cisco switched to active is 2 days, 10 hours, 36 minutes
System returned to ROM by s/w reset (SP by power-on)
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF17b.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID SCA042505N5
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
5 Virtual Ethernet/IEEE 802.3 interfaces
122 Gigabit Ethernet/IEEE 802.3 interfaces
8 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
BOOT variable = disk0:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin,12;
При настройке BGP возникает ошибка, связана с тем что номер AS шестизначное
#router bgp ?
  <1-65535>  Autonomous system number
Понимаю что в настройках выше 65535, AS не поддерживается. Но дело в том что ранее на ней была настроена данная AS, при транспортировке разобрали, и после сбора обратно слетели настройки, при попытки восстановлении с бекапа, или вводе руками, на месте номера AS вылазит ошибка.
Просьба помочь с решением проблемы.
Заранее спасибо.
