при добавлении вот этих строчек в файлик ядра
options IPFILTER
options IPFILTER_LOG
выполнение make depend прошло успешно , а вот на make all выдало следуеще
# make all
cc -c -O -pipe -mcpu=pentiumpro -Wall -Wredundant-decls -Wnested-externs -Wstric t-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -fforma t-extensions -std=c99 -nostdinc -I- -I. -I../../.. -I../../../contrib/dev/acpi ca -I../../../contrib/ipfilter -I../../../contrib/dev/ath -I../../../contrib/dev /ath/freebsd -I../../../contrib/ngatm -D_KERNEL -include opt_global.h -fno-commo n -finline-limit=15000 -fno-strict-aliasing -mno-align-long-strings -mpreferred -stack-boundary=2 -ffreestanding -Werror ../../../contrib/ipfilter/netinet/ip_f il.c
../../../contrib/ipfilter/netinet/ip_fil.c: In function `fr_check_wrapper':
../../../contrib/ipfilter/netinet/ip_fil.c:319: error: `PFIL_OUT' undeclared (fi rst use in this function)
../../../contrib/ipfilter/netinet/ip_fil.c:319: error: (Each undeclared identifi er is reported only once
../../../contrib/ipfilter/netinet/ip_fil.c:319: error: for each function it appe ars in.)
../../../contrib/ipfilter/netinet/ip_fil.c: In function `fr_check_wrapper6':
../../../contrib/ipfilter/netinet/ip_fil.c:329: error: `PFIL_OUT' undeclared (fi rst use in this function)
../../../contrib/ipfilter/netinet/ip_fil.c: In function `iplattach':
../../../contrib/ipfilter/netinet/ip_fil.c:376: warning: unused variable `ph_ine t'
../../../contrib/ipfilter/netinet/ip_fil.c:378: warning: unused variable `ph_ine t6'
../../../contrib/ipfilter/netinet/ip_fil.c: At top level:
../../../contrib/ipfilter/netinet/ip_fil.c:317: warning: `fr_check_wrapper' defi ned but not used
../../../contrib/ipfilter/netinet/ip_fil.c:327: warning: `fr_check_wrapper6' def ined but not used
*** Error code 1
Stop in /usr/src/sys/i386/compile/SERVER_KERNEL.
что это может быть? как мне включить ipnat
Попробуйте собирать ядро официальным способом:
cd /usr/src
make KERNCONF=SERVER_KERNEL buildkernel
make KERNCONF=SERVER_KERNEL installkernel
Естественно, конфиг ядра надо скопировать в /usr/src/sys/i386/conf
cd /usr/src
мда.... неприятно конечно. Но таже самая ошибка :-((
ша покажу конфиг ядра
machine i386
cpu I686_CPU
ident GENERIC
options IPFIREWALL
options IPFIREWALL_VERBOSE
options IPFIREWALL_VERBOSE_LIMIT=10
options DUMMYNET
options HZ=1000
options IPDIVERT
options SCHED_4BSD #4BSD scheduler
options INET #InterNETworking
options INET6 #IPv6 communications prot
options FFS #Berkeley Fast Filesystem
options SOFTUPDATES #Enable FFS soft update
options UFS_ACL #Support for access control l
options UFS_DIRHASH #Improve performance on
options MD_ROOT #MD is a potential root device
options NFSCLIENT #Network Filesystem Client
options NFSSERVER #Network Filesystem Server
options NFS_ROOT #NFS usable as /, requires NFSCLIENT
options MSDOSFS #MSDOS Filesystem
options CD9660 #ISO 9660 Filesystem
options PROCFS #Process filesystem
options PSEUDOFS #Pseudo-filesystem framework
options COMPAT_43 #Compatible with BSD 4.3
options COMPAT_FREEBSD4 #Compatible with FreeBSD4
options SCSI_DELAY=15000 #Delay (in ms) before probing SCSI
options KTRACE #ktrace(1) support
options SYSVSHM #SYSV-style shared memory
options SYSVMSG #SYSV-style message queues
options SYSVSEM #SYSV-style semaphores
options _KPOSIX_PRIORITY_SCHEDULING #Posix P1003_1B real-
options KBD_INSTALL_CDEV # install a CDEV entry in /dev
options AHC_REG_PRETTY_PRINT # Print register bitfie
options AHD_REG_PRETTY_PRINT
options IPFILTER
options INVARIANT_SUPPORT
# To make an SMP kernel, the next two are needed
options SMP # Symmetric MultiProcessor Kernel
device apic # I/O APIC
device isa
device eisa
device pci
# ATA and ATAPI devices
device ata
device atadisk # ATA disk drives
device atapicd # ATAPI CDROM drives
device atapist # ATAPI tape drives
options ATA_STATIC_ID #Static device numbering
# atkbdc0 controls both the keyboard and the PS/2 mouse
device atkbdc # AT keyboard controller
device atkbd # AT keyboard
device vga # VGA video card driver
device splash # Splash screen and screen saver support
# syscons is the default console driver, resembling an SCO console
device sc
device agp # support several AGP chipsets
device npx
device pmtimer
# Parallel port
device ppc
device ppbus # Parallel port bus (required)
device lpt # Printer
device plip # TCP/IP over parallel
device ppi # Parallel port interface device
# PCI Ethernet NICs.
device de # DEC/Intel DC21x4x (``Tulip'')
device em # Intel PRO/1000 adapter Gigabit Ethernet Card
device txp # 3Com 3cR990 (``Typhoon'')
device vx # 3Com 3c590, 3c595 (``Vortex'')
# PCI Ethernet NICs that use the common MII bus controller code.
device miibus # MII bus support
device bfe # Broadcom BCM440x 10/100 ethernet
device bge # Broadcom BCM570xx Gigabit Ethernet
device dc # DEC/Intel 21143 and various workalikes
device fxp # Intel EtherExpress PRO
device pcn # AMD Am79C97x PCI 10/1
device re # RealTek 8139C+
device rl # RealTek 8129/8139
device sf # Adaptec AIC-6915 (``St
device sis # Silicon Integrated Systems
device sk # SysKonnect SK-984x and
device ste # Sundance ST201 (D-Link
device ti # Alteon Networks Tigon I/II
device tl # Texas Instruments Th
device tx # SMC EtherPower II
device vr # VIA Rhine, Rhine II
device wb # Winbond W89C840F
device xl # 3Com 3c90x (``Boomerang'', ``Cyclone'')
# 'device ed' requires 'device miibus'
device ed # NE[12]000, SMC Ultra, 3
device ex # Intel EtherExpress Pro/10
device ep # Etherlink III based cards
device fe # Fujitsu MB8696x based c
device ie # EtherExpress 8/16, 3C507,
device lnc # NE2100, NE32-VL Lance s
device sn # SMC's 9000 series of ips
device xe # Xircom pccard ethernet
# Pseudo devices - the number indicates how many units to allocate.
device random # Entropy device
device loop # Network loopback
device ether # Ethernet support
device sl # Kernel SLIP
device ppp # Kernel PPP
device tun # Packet tunnel.
device pty # Pseudo-ttys (telnet etc)
device md # Memory "disks"
device gif # IPv6 and IPv4 tunneling
device faith # IPv6-to-IPv4 relaying ion)
device bpf # Berkeley packet filter
какая версия FreeBSD? В старых версиях 5.x может потребоваться еще options PFIL_HOOKS.
5.2
ой спасибочки! прокатило!
