asduks Posted January 9, 2025 Posted January 9, 2025 (edited) Здравствуйте. Может есть у кого свежие прошивки для данного коммутатора J8697A? В данный момент установлена 15.04 Edited January 9, 2025 by asduks Вставить ник Quote
tt128 Posted January 9, 2025 Posted January 9, 2025 (edited) Есть K_15_16_0021 Edited January 9, 2025 by tt128 Вставить ник Quote
asduks Posted January 9, 2025 Author Posted January 9, 2025 Хотя бы для начала, выложите куда-нибудь пожалуйста. Там дальше обновления могут быть через промежуточные. Вставить ник Quote
tt128 Posted January 9, 2025 Posted January 9, 2025 https://drive.google.com/file/d/1mLF8nbgays_Tgkad5RWnsy0UmK1UgcgV/view?usp=sharing Вставить ник Quote
asduks Posted January 9, 2025 Author Posted January 9, 2025 Забрал, премного благодарен Вставить ник Quote
jffulcrum Posted January 9, 2025 Posted January 9, 2025 Скрытый текст CAUTION: If you are updating from a software version that is susceptible to the 'hang' problem to this software, HP recommends that software updates and reboots occur when there can be someone onsite to power cycle any switch that does not recover spontaneously after reload. These software versions are susceptible: K.15.01.xxxx - K.15.05.xxxx K.15.06.0006 - K.15.06.0014 K.15.07.0002 - K.15.07.0005 K.15.08.0007 K.15.04.0007m - K.15.04.0010m +++++++++++++++++++++++++++++++++++++++++++++++++ Digital Signature Note: Beginning with K.15.09, the switch software includes a digital signature. However, if this software is downloaded by an earlier software version that does not understand digital signatures, the earlier software will remove the digital signature before storing the new software in flash. In order to have digitally-signed software in the switch, you must boot the switch into K.15.09 or later software, and then re-download the K.15.09 or later software into the same flash it is already in (primary or secondary). Because the switch is now using a software version that understands digital signatures, the signature is not stripped during the download. Use the verify signature flash command to see if the software has a digital signature. After entering the command, if the software is digitally signed the switch does nothing for approximately 30 seconds, then responds. If the software is not digitally signed, the switch responds in approximately 10 seconds. +++++++++++++++++++++++++++++++++++++++++++++++++ IMPORTANT: If your switch is running a software version earlier than K.15, your BootROM will be updated when you upload K.15.15.0009 software to your switch. All switches must be running a BootROM version of K.12.17 or newer in order to load K.15 software. Do not interrupt power to the switch during this important update! A successful update to K.15 software may require multiple steps, depending on your current software and BootROM levels. Please see details in the table below. If your software version is: Your next step should be: K.11.11 through K.12.29(BootROM K.11.00 - K.11.03) Update and reload into software version K.12.31 or K.12.62 K.12.31 through K.13.55(BootROM K.12.12 - K.12.14) Update and reload into software version K.13.58 or K.13.68 K.13.58 or newer(BootROM K.12.17 or newer;use 'show flash' command) Update directly into software version K.15.15.0009 (BootROM K.15.30) 15.09 см. личку Вставить ник Quote
No_name Posted January 9, 2025 Posted January 9, 2025 Скрытый текст Switch 5406# sh fl Image Size (bytes) Date Version ----------------- ------------ -------- -------------- Primary Image : 15733602 05/12/17 K.16.02.0019 Secondary Image : 16740639 01/30/15 K.15.16.0006 Boot ROM Version ---------------- Primary Boot ROM Version : K.15.30 Default Boot Image : Primary ------------------------------------------------------ Есть и последняя К_16.02.0036 Вставить ник Quote
asduks Posted January 10, 2025 Author Posted January 10, 2025 (edited) jffulcrum - благодарю за информацию и прошивку No_name - можете поделиться? Edited January 10, 2025 by asduks Вставить ник Quote
No_name Posted January 10, 2025 Posted January 10, 2025 Скрытый текст https://disk.yandex.ru/d/fSkS9Hhe2xJ6PQ Вставить ник Quote
