Всем привет,
Купили в далеком 2017 году у НАГа ASR 1002-X. Сейчас уже забыли, что там и как там. Не получается зайти в rommon режим для сброса пароля. Юзаю миником, отсылаю Ctrl-a f для break в первые 60 сек, так же жал ESC. Ничего не происходит. Вот логи оборудования.
Помогите, люди добрые, как пароль то сбросить?
Initializing Hardware ...
System integrity status: 00000610
System Bootstrap, Version 16.3(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
SPI Flash 4KB Descriptor Area Checksum = 0x6f5a0db2
ASR1002-X platform with 16777216 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Warning: filesystem is not clean
File size is 0x1ba02ea4
Located asr1002x-universalk9.03.16.02b.S.155-3.S2b-ext.SPA.bin
Image size 463482532 inode num 12, bks cnt 113155 blk size 8*512
Boot image size = 463482532 (0x1ba02ea4) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
        calculated 7356c9c8:abfc9467:be92826f:4cd85b45:ab71bc0f
        expected   7356c9c8:abfc9467:be92826f:4cd85b45:ab71bc0f
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 6 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 9 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 10 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 11 contained errors which were auto-corrected.
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S2b, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 21-May-16 09:07 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 6801457K/6147K bytes of memory.
Processor board ID FOX2144P90E
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
6684671K bytes of eUSB flash at bootflash:.
Warning: When Cisco determines that a fault or defect can be traced to
the use of third-party transceivers installed by a customer or reseller,
then, at Cisco's discretion, Cisco may withhold support under warranty or
a Cisco support program. In the course of providing support for a Cisco
networking product Cisco may require that the end user install Cisco
transceivers if Cisco determines that removing third-party parts will
assist Cisco in diagnosing the cause of a support issue.
Press RETURN to get started!
@MrNv
Рабочая. Ща логи докину. Вот эту комбинацию и использую
*Dec  4 07:43:12.831: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Dec  4 07:43:14.169: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
*Dec  4 07:43:14.197: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = asr1002x Next reboot level = adventerprise and License = adventerprise
*Dec  4 07:43:15.564: %IOSXE_THROUGHPUT-6-LEVEL: Throughput level has been set to 36000000 kbps
*Dec  4 07:43:20.101: dev_pluggable_optics_selftest attribute table internally inconsistent @ 0x125
*Dec  4 07:43:24.488: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Dec  4 07:43:26.247: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Dec  4 07:43:27.331: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Dec  4 07:43:27.331: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Dec  4 07:43:27.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec  4 07:43:27.332: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Dec  4 07:43:27.332: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Dec  4 07:43:27.335: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Dec  4 07:43:28.280: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Dec  4 07:43:28.332: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Dec  4 07:43:28.332: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Dec  4 07:43:28.332: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Dec  4 07:43:17.273: %CMLIB-6-THROUGHPUT_VALUE: F0: cmand:  Throughput license found, throughput set to 36000000 kbps
*Dec  4 07:43:18.696: %IOSXE-4-PLATFORM: R0/0: kernel: CE: hpet4 increasing min_delta_ns to 15000 nsec
*Dec  4 07:43:18.696: %IOSXE-4-PLATFORM: R0/0: kernel: CE: hpet4 increasing min_delta_ns to 22500 nsec
*Dec  4 07:43:18.696: %IOSXE-4-PLATFORM: R0/0: kernel: hrtimer: interrupt took 4831 ns
*Dec  4 07:43:19.092: %IOSXE-4-PLATFORM: R0/0: kernel: CE: hpet5 increasing min_delta_ns to 15000 nsec
*Dec  4 07:43:19.092: %IOSXE-4-PLATFORM: R0/0: kernel: CE: hpet5 increasing min_delta_ns to 22500 nsec
*Dec  4 07:43:30.311: %SYS-6-CLOCKUPDATE: System clock has been updated from 07:43:30 UTC Wed Dec 4 2024 to 12:43:30 UZT Wed Dec 4 2024, configured from c.
*Dec  4 07:43:30.339: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
*Dec  4 07:43:30.969: %SYS-5-CONFIG_I: Configured from memory by console
*Dec  4 07:43:30.980: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Dec  4 07:43:30.980: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/1, interfaces disabled
*Dec  4 07:43:30.982: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/2, interfaces disabled
*Dec  4 07:43:30.986: %SPA_OIR-6-OFFLINECARD: SPA (6XGE-BUILT-IN) offline in subslot 0/0
*Dec  4 07:43:30.987: %SPA_OIR-6-OFFLINECARD: SPA (SPA-1X10GE-L-V2) offline in subslot 0/1
*Dec  4 07:43:30.988: %SPA_OIR-6-OFFLINECARD: SPA (SPA-1X10GE-L-V2) offline in subslot 0/2
*Dec  4 07:43:30.990: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Dec  4 07:43:30.990: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Dec  4 07:43:31.016: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Dec  4 07:43:32.537: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Dec  4 07:43:33.583: %SNMP-5-COLDSTART: SNMP agent on host artemka is undergoing a cold start
*Dec  4 07:43:32.672: %LINK-3-UPDOWN: SIP0/0: Interface EOBC0/1, changed state to up
*Dec  4 07:43:32.901: %LINK-3-UPDOWN: SIP0/1: Interface EOBC0/1, changed state to up
*Dec  4 07:43:34.404: %SPA_OIR-6-ONLINECARD: SPA (6XGE-BUILT-IN) online in subslot 0/0
*Dec  4 07:43:33.600: %LINK-3-UPDOWN: SIP0/2: Interface EOBC0/1, changed state to up
*Dec  4 07:43:35.593: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Dec  4 07:43:35.593: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Dec  4 07:43:36.402: %LINK-3-UPDOWN: Interface Crypto-Engine0/0/6, changed state to up
*Dec  4 07:43:36.415: %SPA_OIR-6-ONLINECARD: SPA (SPA-1X10GE-L-V2) online in subslot 0/2
*Dec  4 07:43:36.444: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/2/0, link down due to local fault
*Dec  4 07:43:37.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Crypto-Engine0/0/6, changed state to up
*Dec  4 07:43:38.240: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/2/0, changed state to down
*Dec  4 07:43:38.441: %LINK-3-UPDOWN: SIP0/2: Interface TenGigabitEthernet0/2/0, changed state to down
*Dec  4 07:43:40.100: %SPA_OIR-6-ONLINECARD: SPA (SPA-1X10GE-L-V2) online in subslot 0/1
*Dec  4 07:43:40.119: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/1/0, link down due to local fault
*Dec  4 07:43:41.925: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/1/0, changed state to down
*Dec  4 07:43:42.117: %LINK-3-UPDOWN: SIP0/1: Interface TenGigabitEthernet0/1/0, changed state to down
User Access Verification
Username: admin
Password:
% Authentication failed
Username: admin
Password:
