Вот такая вот картина
192.168.1.2 -днс-сервер
192.168.1.128/26 зона dhcp
Код:
my# arp -a
localhost (192.168.1.1) at 00:80:48:27:4e:e5 on fxp0 [ethernet]
my.domine.int (192.168.1.2) at 00:02:b3:96:23:a2 on fxp0 permanent [ethernet]
? (192.168.1.17) at 00:11:95:e3:a4:42 on fxp0 [ethernet]
? (192.168.1.129) at 00:0e:a6:4e:73:c8 on fxp0 [ethernet]
? (192.168.2.1) at 00:50:bf:03:d0:7c on ed0 [ethernet]
my# nslookup
> 192.168.1.17
Server:         192.168.1.2
Address:        192.168.1.2#53
** server can't find 17.1.168.192.in-addr.arpa: NXDOMAIN
> 192.168.1.129
Server:         192.168.1.2
** server can't find 129.1.168.192.in-addr.arpa: NXDOMAIN
# cat /etc/hosts
::1 localhost.domine.int localhost
127.0.0.1 localhost.domine.int localhost
192.168.1.2 my.domine.int my
192.168.1.2 my.domine.int.
#tail -f /var/log/messages
Apr 20 14:17:11 my named[1746]: starting BIND 9.3.2 -u bind -t /var/named
Apr 20 14:17:12 my named[1746]: command channel listening on 127.0.0.1#953
Apr 20 14:17:12 my named[1746]: logging channel 'security_log' file 'dns-security.log': permission denied
Apr 20 14:17:12 my named[1746]: running
# cat dns-security.log
20-Apr-2006 12:38:11.009 update: info: client 127.0.0.1#60880: updating zone 'domine.int/IN': adding an RR at 'lsv-4puarkzkn7h.domine.int' A
20-Apr-2006 12:38:11.011 update: info: client 127.0.0.1#60880: updating zone 'domine.int/IN': adding an RR at 'lsv-4puarkzkn7h.domine.int' TXT
20-Apr-2006 12:38:11.024 update: info: client 127.0.0.1#55381: updating zone '1.168.192.in-addr.arpa/IN': deleting rrset at '254.1.168.192.in-addr.arpa' PTR
20-Apr-2006 12:38:11.024 update: info: client 127.0.0.1#55381: updating zone '1.168.192.in-addr.arpa/IN': adding an RR at '254.1.168.192.in-addr.arpa' PTR
20-Apr-2006 12:56:07.917 update: info: client 127.0.0.1#52048: updating zone 'domine.int/IN': deleting an RR
20-Apr-2006 12:56:07.929 update: info: client 127.0.0.1#63906: updating zone 'domine.int/IN': deleting an RR
20-Apr-2006 12:56:07.944 update: info: client 127.0.0.1#53318: updating zone '1.168.192.in-addr.arpa/IN': deleting rrset at '254.1.168.192.in-addr.arpa' PTR
Apr 21 17:57:16 my ppp[76646]: Warning: 246.48.14.55: Cannot determine ethernet address for proxy ARP
Apr 21 17:57:16 my ppp[76646]: Warning: Local: bind: Address already in use
Apr 21 17:57:16 my ppp[76646]: Warning: set server: Failed 2
Apr 21 17:57:25 my pptpd[76645]: GRE: read(fd=7,buffer=804db80,len=8196) from PTY failed: status = 0 error = No error
Apr 21 17:57:25 my pptpd[76645]: CTRL: PTY read or GRE write failed (pty,gre)=(7,6)
Apr 21 17:57:25 my ppp[76646]: Warning: 246.48.14.55: Cannot determine ethernet address for proxy ARP
И ещё странно узел 192.168.1.1 почему то с именем локалхост?Когда у него в резолф прописано так
domain domine.int
nameserver 192.168.1.2
в качестве днс-сетрвера BIND 9.3.2 и DHCP 3.0.3
Так в чём может быть загвостка?
