Всем привет. Начала ребутаться голова. Последним событием, прилетающим в сислог значится
MONITOR[339]: /usr/bin/pondevctrl abnormal termination, signal code[11]
Что означает Segmentation fault.
Но может падать и так
Sep 22 10:25:17 LPX_1 EPON[493]: stack:0xa4faf000-0xa57ae000
Sep 22 10:25:17 LPX_1 EPON[493]: #012******* task /usr/bin/pondevctrl(2776290512) exit ****#012* info.si_signo = 11   *#012* info.si_errno = 0    *#012* info.si_code = 1     *#012* info.si_addr = 0x10e      *#012* EPC=0x0000010e           *#012* RA=0x000baec8            *#012**************************#012
Sep 22 10:25:17 LPX_1 EPON[493]: #012r0 ($ 0) = 0xa57ac9de          r1 ($ 1) = 0x0000010f
Sep 22 10:25:17 LPX_1 EPON[493]: #012r2 ($ 2) = 0x000000fe          r3 ($ 3) = 0x00000000
Sep 22 10:25:17 LPX_1 EPON[493]: #012r4 ($ 4) = 0x002783f4          r5 ($ 5) = 0x00000001
Sep 22 10:25:17 LPX_1 EPON[493]: #012r6 ($ 6) = 0x00000006          r7 ($ 7) = 0xa57ac7e4
Sep 22 10:25:17 LPX_1 EPON[493]: #012r8 ($ 8) = 0xa57ac8dc          r9 ($ 9) = 0xfffffed2
Sep 22 10:25:17 LPX_1 EPON[493]: #012r10($10) = 0x000000ff          fp ($11) = 0xa57aca44
Sep 22 10:25:17 LPX_1 EPON[493]: #012ip ($12) = 0x00000002          sp ($13) = 0xa57ac7b0
Sep 22 10:25:17 LPX_1 EPON[493]: #012lr ($14) = 0x000baec8          pc ($15) = 0xb6cbdb08
Sep 22 10:25:17 LPX_1 EPON[493]: #012cpsr ($16) = 0x60000010           = 0x0000010e
Sep 22 10:25:17 LPX_1 EPON[493]: #012#015
Sep 22 10:25:17 LPX_1 EPON[493]: i=0xa57ac2a4 :18 signal_segv address=f6fc4 initialized_data=0x274a04
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00000000
Sep 22 10:25:17 LPX_1 EPON[493]: 0xa57ac7e4
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00000006
Sep 22 10:25:17 LPX_1 EPON[493]: 0xa57ac7ec
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00000004
Sep 22 10:25:17 LPX_1 EPON[493]: message repeated 30 times: [ 0x00000000 ]
Sep 22 10:25:17 LPX_1 EPON[493]: 0xa57aca90
Sep 22 10:25:17 LPX_1 EPON[493]: 0xfffffed2
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00000001
Sep 22 10:25:17 LPX_1 EPON[493]: 0xa57aca70
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00018050
Sep 22 10:25:17 LPX_1 EPON[493]: 0xb6db75d2
Sep 22 10:25:17 LPX_1 EPON[493]: 0x31384131
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00003436
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00003837
Sep 22 10:25:17 LPX_1 EPON[493]: 0x6179616e
Sep 22 10:25:17 LPX_1 EPON[493]: 0x29343636
Sep 22 10:25:17 LPX_1 EPON[493]: 0x00000100
Sep 22 10:25:17 LPX_1 EPON[493]: message repeated 7 times: [ 0x00000000 ]
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01fc3078
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01fd3150
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01f240d8
Sep 22 10:25:17 LPX_1 EPON[493]: 0x35363233
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01fbd0f0
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01f23f78
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01f24478
Sep 22 10:25:17 LPX_1 EPON[493]: 0x0000000e
Sep 22 10:25:17 LPX_1 EPON[493]: 0x0000000f
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01fbb9d8
Sep 22 10:25:17 LPX_1 EPON[493]: 0x01fc3780
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00000000
Sep 22 10:25:18 LPX_1 EPON[493]: 0x01fbbd28
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57acd64
Sep 22 10:25:18 LPX_1 EPON[493]: 0x01ef0fd0
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57ad034
Sep 22 10:25:18 LPX_1 EPON[493]: 0x01fdcce0
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57ace50
Sep 22 10:25:18 LPX_1 EPON[493]: 0x000000f0
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57acdb0
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00000001
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00000800
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 6 times: [ 0x00000000 ]
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00000018
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 7 times: [ 0x00000000 ]
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00134708
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00800000
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 14 times: [ 0x00000000 ]
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57ad538
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57ad4d0
Sep 22 10:25:18 LPX_1 EPON[493]: 0xb6f84c44
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 78 times: [ 0x00000000 ]
Sep 22 10:25:18 LPX_1 EPON[493]: 0x0000028d
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00000063
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 24 times: [ 0x00000000 ]
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00000002
Sep 22 10:25:18 LPX_1 EPON[493]: 0x00001000
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 29 times: [ 0x00000000 ]
Sep 22 10:25:18 LPX_1 EPON[493]: 0xa57ad784
Sep 22 10:25:18 LPX_1 EPON[493]: message repeated 103 times: [ 0x00000000 ]
Sep 22 10:26:15 LPX_1 MONITOR[339]: /usr/bin/pondevctrl normal termination, exit code[245].
Если отключить все пон порты и включать по одному, то 7 порт вызывает падение. Но если его отключить, то она все равно рано или поздно упадет. Идеи кончились
