mikhail Posted July 31, 2024 Posted July 31, 2024 Приветствую! Попала в руки эта железяка, пытаюсь настроить подключение по l2tp, по тем крохам документации, что нашел, что-то сделал, но не подключается, в логах пишет %L2TP-6-TUNNEL: HS: Couldn't create peer for incoming SCCRQ конфиг ! ! Configuration last changed by user 'admin' at Sun Jan 1 01:37:33 2023 ! ! ! aaa last-resort context local ! ! no service multiple-contexts ! ! ! software license subscriber active 8000 encrypted 1 $1$ffmEStpA$8POhnM9E8SFdL/OefM/o01 subscriber bandwidth 60 encrypted 1 $1$EPfBcMtz$AQxP5H.nXgaSVMbeAu98h0 ! ! Bridge global configuration bridge profile default loop-detection ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! context local ! no ip domain-lookup ! interface Int93 description Port to 93 subnet ip address 10.93.1.20/24 ! interface L2vpn ip address 10.95.1.1/24 ! interface LNS loopback ip address 10.3.3.3/32 ! interface l2tp multibind ip address 10.8.10.254/24 ip pool 10.8.10.0/24 ! interface mgt ip address 10.94.2.2/24 logging console ! enable encrypted 1 $1$Io9kjLVQ$ZeKzAqQ3..VAj1p3XRvLH. enable authentication local ! aaa authentication administrator local aaa accounting subscriber radius radius accounting server 10.94.1.22 encrypted-key BC542E87AB678B8814474231571493ED ! administrator admin encrypted 1 $1$gHw2FiVf$/gHoDRmQVgyXRbSHuLmDz0 privilege max 15 ! radius server 10.94.1.22 encrypted-key BC542E87AB678B8814474231571493ED ! subscriber default ppp mtu 1460 dns primary 8.8.8.8 dns secondary 8.8.4.4 ! subscriber name user password 123456789 ! ip route 0.0.0.0/0 10.93.1.1 ip route 10.94.1.0/24 10.94.2.1 service ssh server ! bridge 93 ! ! l2tp-peer unnamed local 10.3.3.3 session-auth chap context local function lns-only ! ! ! ! ! ** End Context ** logging tdm console logging active logging standby short ! ! ! ! link-group users ether description linkgroup-logical-iface lacp active ! ! ! ! ! ! port ethernet 1/1 ! XCRP management port on slot 1 no shutdown bind interface mgt local ! card carrier 2 mic 1 ge-2-port mic 2 ge-2-port ! port ethernet 2/1 no shutdown medium-type copper ! port ethernet 2/2 no shutdown ! port ethernet 2/3 no shutdown ! port ethernet 2/4 no shutdown ! port ethernet 2/15 no shutdown bind interface Int93 local ! port ethernet 2/16 no shutdown bind interface L2vpn local ! system hostname GW2 ! ! ! ! end Вставить ник Quote
stalker86 Posted July 31, 2024 Posted July 31, 2024 sh licenses all | i l2tp что говорит? Вставить ник Quote
mikhail Posted July 31, 2024 Author Posted July 31, 2024 l2tp NO Как я понимаю, нет соответствующей лицензии и ничего не выйдет? Вставить ник Quote
stalker86 Posted July 31, 2024 Posted July 31, 2024 Угу. лицензия нужна. редбаки много кто юзал и инаверняка кто-то поделится лицензией на каких либо условиях Вставить ник Quote
mikhail Posted July 31, 2024 Author Posted July 31, 2024 Спасибо, буду искать. И еще вопрос: он умеет по pppoe подключаться? Провайдер только такое подключение дает. Вставить ник Quote
stalker86 Posted July 31, 2024 Posted July 31, 2024 врядли сам брас умеет быть PPPoE клиентом... сильно в этом сомневаюсь. Вставить ник Quote
mikhail Posted July 31, 2024 Author Posted July 31, 2024 Жаль, железяка пригодилась бы. Вставить ник Quote
stalker86 Posted July 31, 2024 Posted July 31, 2024 странное желание BRAS подключать по PPPoE. Железка уровня ISP, не SOHO.. Вставить ник Quote
mikhail Posted July 31, 2024 Author Posted July 31, 2024 Работаем с тем что есть. РТ дает десятку, но только по pppoe, если по официальным каналам, то это много месяцев согласований с неясным результатом. Вставить ник Quote
Technologia Posted July 31, 2024 Posted July 31, 2024 20 минут назад, mikhail сказал: Работаем с тем что есть. РТ дает десятку, но только по pppoe, если по официальным каналам, то это много месяцев согласований с неясным результатом. Необязательно РТ втыкать напрямую в SE100, пусть работает через CPE. Вставить ник Quote
mikhail Posted July 31, 2024 Author Posted July 31, 2024 Т.е. какой-нибудь микрот (есть Hap Ax) сделать клиентом ppoe и бриджом подключить к SE? Вставить ник Quote
stalker86 Posted July 31, 2024 Posted July 31, 2024 У Вас по ПППоЕ же 1 адрес выдаётся. какой там бридж может быть. а так 2 ната подряд...3 если ртк серый даёт. Но если Вы не провайдер -то SE100 Вам не нужен. линукс бокс... Вставить ник Quote
