pandrew Posted July 13, 2024 Posted July 13, 2024 Здравствуйте, Коллеги! На данной железке интерфейс XGigabiteEthernet0/0/0.612 - смотрит на провайдера. disp int xg0/0/0.612 выдает XGigabitEthernet0/0/0.612 current state : UP Line protocol current state : UP Last line protocol up time : 2024-07-03 01:33:41 UTC+09:00 Description:HUAWEI, AR Series, XGigabitEthernet0/0/0.612 Interface Route Port,The Maximum Transmit Unit is 1500 Internet Address is x.x.x.x/30 IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 9017-3fc4-5a6f Current system time: 2024-07-14 01:00:07+09:00 Last 300 seconds input rate 2608 bits/sec, 2 packets/sec Last 300 seconds output rate 0 bits/sec, 0 packets/sec Realtime 0 seconds input rate 0 bits/sec, 0 packets/sec Realtime 0 seconds output rate 0 bits/sec, 0 packets/sec Input: 10593917 packets,955930726 bytes, 10593917 unicast,0 broadcast,0 multicast Output:4724 packets,302576 bytes, 816 unicast,3908 broadcast,0 multicast Input bandwidth utilization : 0% Output bandwidth utilization : 0% Совсем маленькая нагрузка. Должно быть много больше. Смотрим на самом интерфейсе. disp int xg0/0/0 выдает XGigabitEthernet0/0/0 current state : UP Line protocol current state : DOWN Description:HUAWEI, AR Series, XGigabitEthernet0/0/0 Interface Route Port,The Maximum Transmit Unit is 1500 Internet protocol processing : disabled IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 9017-3fc4-5a6f Last physical up time : 2024-07-03 01:32:16 UTC+09:00 Last physical down time : 2024-07-03 01:32:11 UTC+09:00 Current system time: 2024-07-14 01:01:36+09:00 Port Mode: COMMON FIBER Speed : 10000, Loopback: NONE Duplex: FULL, Negotiation: DISABLE Mdi : - Clock : - Last 300 seconds input rate 385991968 bits/sec, 40395 packets/sec Last 300 seconds output rate 89510944 bits/sec, 53221 packets/sec Input peak rate 1489482872 bits/sec,Record time: 2024-07-04 19:32:28 Output peak rate 1395354488 bits/sec,Record time: 2024-07-12 11:16:01 Input: 39576868992 packets, 48117442988361 bytes Unicast: 39571336517, Multicast: 2157922 Broadcast: 3374553, Jumbo: 0 Discard: 0, Total Error: 0 CRC: 0, Giants: 0 Jabbers: 0, Throttles: 0 Runts: 0, Symbols: 0 Ignoreds: 0, Frames: 0 Output: 30397621574 packets, 11575143094516 bytes Unicast: 30397617637, Multicast: 0 Broadcast: 3937, Jumbo: 0 Discard: 0, Total Error: 0 Collisions: 0, ExcessiveCollisions: 0 Late Collisions: 0, Deferreds: 0 Input bandwidth utilization threshold : 100.00% Output bandwidth utilization threshold: 100.00% Input bandwidth utilization : 3.66% Output bandwidth utilization : 0.44% Вот тут уже похоже на правду input rate - 385Mbit. Сейчас на этом интерфейсе один рабочий субинтерфейс. Соответственно, что субинтерфейс и интерфейс данные одинаковы. Планируется ввести в работу второй аплинк до другого оператора. И нужно иметь данные с обоих субинтерфейсов. На данный момент zabbix рисует график в 20кбит 🙂 Почему врет статистика субинтерфейса? Как получить верную статистику по субинтерфейсу? Вставить ник Quote
