justhelpme Posted July 2, 2024 Posted July 2, 2024 Уже три дня как поддержка авто проброса портов UPnP в статусе запускается Скрытый текст Скрытый текст Вставить ник Quote
justhelpme Posted July 4, 2024 Author Posted July 4, 2024 Vendor specific option 43 is not null, try helpers for select service and try configure. Что мне делать? Вставить ник Quote
Morty Posted July 5, 2024 Posted July 5, 2024 11 часов назад, justhelpme сказал: Vendor specific option 43 is not null, try helpers for select service and try configure. Что мне делать? Вставить ник Quote
justhelpme Posted July 5, 2024 Author Posted July 5, 2024 Логи Цитата Попытался перенастроить через приложение но не помогло Jul 4 21:22:00 ntp: Starting NTPD Jul 4 21:22:00 hotplug: Generate config file. Jul 4 21:22:00 hotplug: Set mdev as kernel hotplug helper and enable device autoprobe. Jul 4 21:22:00 hotplug: Refresh dev nodes. Jul 4 21:22:00 lo: Start loopback interface. Jul 4 21:22:00 lan: Start LAN network interfaces. Jul 4 21:22:00 ESW: Double vlan tag disabled. Jul 4 21:22:00 ESW: eth2 MACADDR F8:F0:82:C1:24:F4 txqueuelen 160 Jul 4 21:22:00 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jul 4 21:22:00 kernel: raeth: HW VLAN TX offload enabled Jul 4 21:22:00 kernel: raeth: HW Scatter/Gather TX offload enabled Jul 4 21:22:00 ESW: eth3 MACADDR F8:F0:82:C1:24:F3 txqueuelen 160 Jul 4 21:22:00 ESW: Restore internal MT7621 switch mode to dumb mode Jul 4 21:22:00 ESW: Reset WAN port phy Jul 4 21:22:00 ESW: Reset LAN ports phys Jul 4 21:22:01 ESW: Config internal MT7621 switch mode WLLLL Jul 4 21:22:01 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jul 4 21:22:01 lan: Add bridge in the system Jul 4 21:22:01 lan: br0_MACADDR F8:F0:82:C1:24:F4 Jul 4 21:22:01 lan: Up bridge interface Jul 4 21:22:01 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jul 4 21:22:01 resolv: Generate resolv at local. Jul 4 21:22:01 dnsserver: Generate /etc/hosts file. Jul 4 21:22:01 dnsserver: Starting DNSMASQ Jul 4 21:22:01 inetd: Starting inetd Jul 4 21:22:02 dnsmasq[1079]: started, version 2.80 cachesize 1024 Jul 4 21:22:02 dnsmasq[1079]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN no-DHCP no-scripts no-TFTP no-conntrack no-ipset no-auth DNSSEC no-loop-detect inotify no-dumpfile Jul 4 21:22:02 dnsmasq[1079]: read /etc/hosts - 4 addresses Jul 4 21:22:02 dnsmasq[1079]: ignoring nameserver 127.0.0.1 - local interface Jul 4 21:22:03 2nd_stage: Switch to 2nd boot stage and start webui. Jul 4 21:22:03 reconfig: Reload modules. Jul 4 21:22:03 modules: link wifi down first Jul 4 21:22:03 modules: Shutdown all wireless interfaces. Jul 4 21:22:03 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jul 4 21:22:04 modules: Unload wireless modules. Jul 4 21:22:04 modules: Load conntrack helpers modules. Jul 4 21:22:04 modules: Load application depended modules. Jul 4 21:22:04 modules: Prepare wifi config. Jul 4 21:22:04 modules: Load wireless modules. Jul 4 21:22:04 modules: Load wifi AP module. Jul 4 21:22:05 kernel: PCI: Enabling device 0000:01:00.0 (0000 -> 0002) Jul 4 21:22:05 kernel: MT7603 AP Driver version: 4.1.0.0.P54 Jul 4 21:22:06 kernel: PCI: Enabling device 0000:02:00.0 (0000 -> 0002) Jul 4 21:22:06 modules: WiFi ra0 interface up with txqueuelen 50. Jul 4 21:22:06 kernel: MT7603 Andes FW Version: ap_pcie Jul 4 21:22:06 kernel: MT7603 Andes FW Build Date: 20160107100755 Jul 4 21:22:06 modules: WiFi rai0 interface up with txqueuelen 50. Jul 4 21:22:09 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jul 4 21:22:09 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jul 4 21:22:09 kernel: efuse_probe: efuse = 511161 Jul 4 21:22:11 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jul 4 21:22:11 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jul 4 21:22:11 kernel: INIT REDUCE TCP ACK, rai0 Jul 4 21:22:12 reconfig: Reconfigure lan. Jul 4 21:22:12 lan: Stop LAN network interfaces. Jul 4 21:22:12 lan: Start LAN network interfaces. Jul 4 21:22:12 lan: Add bridge in the system Jul 4 21:22:12 lan: br0_MACADDR F8:F0:82:C1:24:F4 Jul 4 21:22:12 lan: Up bridge interface Jul 4 21:22:12 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jul 4 21:22:12 kernel: raeth: HW VLAN TX offload enabled Jul 4 21:22:12 kernel: raeth: HW Scatter/Gather TX offload enabled Jul 4 21:22:13 lan: Add LAN1 Mode is 1 lan iface br0, adress 192.168.1.1 Jul 4 21:22:13 reconfig: Gateway OperationMode: 1 Jul 4 21:22:13 reconfig: Readd eth2 in br0 Jul 4 21:22:13 kernel: raeth: HW IP/TCP/UDP checksum RX/TX offload enabled Jul 4 21:22:13 kernel: raeth: HW VLAN TX offload enabled Jul 4 21:22:13 kernel: raeth: HW Scatter/Gather TX offload enabled Jul 4 21:22:13 kernel: device eth2 entered promiscuous mode Jul 4 21:22:13 kernel: br0: port 1(eth2) entered forwarding state Jul 4 21:22:13 reconfig: Readd ra0 in br0 Jul 4 21:22:14 kernel: device ra0 entered promiscuous mode Jul 4 21:22:14 kernel: br0: port 2(ra0) entered forwarding state Jul 4 21:22:14 reconfig: Readd rai0 in br0 Jul 4 21:22:14 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 54:3a:d6:d9:ca:1e Jul 4 21:22:14 kernel: ASSOC - HT support STA. Update AP OperaionMode=2, fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jul 4 21:22:14 kernel: EXIT REDUCE TCP ACK, rai0 Jul 4 21:22:17 kernel: ASSOC - Assign AID=2 to 2.4GHz AP 72:3d:a5:87:04:fb Jul 4 21:22:17 kernel: ASSOC - HT support STA. Update AP OperaionMode=3, fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jul 4 21:22:17 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jul 4 21:22:17 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jul 4 21:22:17 kernel: efuse_probe: efuse = 511161 Jul 4 21:22:18 kernel: RTMPSetProfileParameters: Mcast frame, i=0, Mode=2! Jul 4 21:22:18 kernel: RTMPSetProfileParameters: Mcast frame, i=0, MCS=3! Jul 4 21:22:19 kernel: INIT REDUCE TCP ACK, rai0 Jul 4 21:22:20 kernel: device rai0 entered promiscuous mode Jul 4 21:22:20 kernel: br0: port 3(rai0) entered forwarding state Jul 4 21:22:20 wan: Start WAN config Jul 4 21:22:20 wan: Allow forward for eth3 Jul 4 21:22:20 wan: Start DHCP client at eth3. Jul 4 21:22:20 udhcpc[1965]: started, v1.34.1 Jul 4 21:22:20 ESW: Restore internal MT7621 switch mode to dumb mode Jul 4 21:22:20 udhcpc: All deconfig eth3. Jul 4 21:22:20 ESW: Reset WAN port phy Jul 4 21:22:20 kernel: ESW: WAN Link Status Changed - Port4 Link Down Jul 4 21:22:20 udhcpc[1965]: broadcasting discover Jul 4 21:22:20 ESW: Reset LAN ports phys Jul 4 21:22:21 ESW: Config internal MT7621 switch mode WLLLL Jul 4 21:22:21 ESW: Config internal vlan parts switch mode WLLLL, masklan:01111010,maskwan:10000100,pvids:2 1 1 1 1 Jul 4 21:22:21 kernel: ASSOC - Assign AID=1 to 5GHz AP b2:d6:bb:38:f4:98 Jul 4 21:22:21 kernel: ASSOC - HT support STA. Update AP OperaionMode=0 , fAnyStationIsLegacy=0, fAnyStation20Only=0, fAnyStationNonGF=1 Jul 4 21:22:21 kernel: ASSOC - VHT support STA Jul 4 21:22:21 advanced: Tune wifi advanced parametrs for ra0. Jul 4 21:22:21 kernel: Set_Led_Proc ==> arg = 01-00-00-00-02-00-00-02 Jul 4 21:22:21 kernel: Set_Led_Proc Jul 4 21:22:21 kernel: 01 Jul 4 21:22:21 kernel: 00 Jul 4 21:22:21 kernel: 02 Jul 4 21:22:21 kernel: 00 Jul 4 21:22:21 kernel: 02 Jul 4 21:22:21 advanced: Tune wifi advanced parametrs for rai0. Jul 4 21:22:21 kernel: Set_Led_Proc ==> arg = 01-00-00-00-02-00-00-02 Jul 4 21:22:21 kernel: Set_Led_Proc Jul 4 21:22:21 kernel: 01 Jul 4 21:22:21 kernel: 00 Jul 4 21:22:21 kernel: 02 Jul 4 21:22:21 kernel: 00 Jul 4 21:22:21 kernel: 02 Jul 4 21:22:21 services: Restart needed services and scripts. Mode all Jul 4 21:22:22 QoS: Stopping SHAPER Jul 4 21:22:22 QoS: Set default rules. Jul 4 21:22:22 kernel: ASSOC - Assign AID=3 to 2.4GHz AP d0:a4:6f:34:7e:47 Jul 4 21:22:22 kernel: ASSOC - HT support STA. Update AP OperaionMode=3, fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jul 4 21:22:22 Codel: QoS Add codel for all interfaces. Jul 4 21:22:22 iptables: Add netfiler rules Jul 4 21:22:22 iptables: Allow established/related in input Jul 4 21:22:22 iptables: Drop invalid state connections Jul 4 21:22:22 iptables: Service limit set Jul 4 21:22:22 iptables: Set igmp input rules Jul 4 21:22:22 iptables: DHCP server allow Jul 4 21:22:22 iptables: Dnsproxy allow to connect Jul 4 21:22:22 iptables: allow local port range 32768:61000 from LAN, need for some local service Jul 4 21:22:22 iptables: UPNP allow to connect Jul 4 21:22:22 iptables: Remote managment web limit Jul 4 21:22:22 iptables: CWMP limit to 4 callback connections from WAN. Jul 4 21:22:22 iptables: Remote managment ssh limit Jul 4 21:22:22 iptables: Remote managment telnet limit Jul 4 21:22:23 iptables: Allow rate limited ping from all interfaces. Jul 4 21:22:23 iptables: Set forward rules Jul 4 21:22:23 iptables: Set igmp forward rules Jul 4 21:22:23 iptables: Allow forward from LAN to any Jul 4 21:22:23 iptables: Add SNAT from 192.168.1.1/255.255.255.0 to 169.254.123.92 at eth3. Jul 4 21:22:23 iptables: Add base upnp rules Jul 4 21:22:23 iptables: Run scripts from /etc/iptables.d Jul 4 21:22:23 iptables: Allow established/related in forward Jul 4 21:22:23 ipv6: Deconfigure ipv6 interfaces/route. Jul 4 21:22:23 dnsserver: Generate /etc/hosts file. Jul 4 21:22:23 dnsserver: Send HUP to dnsmasq. Jul 4 21:22:23 dnsmasq[1079]: read /etc/hosts - 5 addresses Jul 4 21:22:23 dnsmasq[1079]: ignoring nameserver 127.0.0.1 - local interface Jul 4 21:22:23 kernel: ESW: call DHCP client for renew address. Jul 4 21:22:23 kernel: ESW: WAN Link Status Changed - Port4 Link Up Jul 4 21:22:23 ntp: Stopping NTPD Jul 4 21:22:24 ntp: Starting NTPD Jul 4 21:22:24 upnpd: Starting UPNP at 169.254.123.92 Jul 4 21:22:24 igmpproxy: Replace route to multicast subnet via eth3. Jul 4 21:22:24 igmpproxy: Starting IGMPPROXY Jul 4 21:22:25 kext: Nat mode Linux Hybrid Jul 4 21:22:25 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths. Jul 4 21:22:25 kext: NAT fastpath enabled. Jul 4 21:22:25 kext: Route fastpath enabled. Jul 4 21:22:25 kext: Netfilter fastpath enabled. Jul 4 21:22:25 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1 Jul 4 21:22:25 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384 Jul 4 21:22:25 kext: hw_nat: set binding threshold to 50. Jul 4 21:22:25 kext: Enable multicast to unicast conversion for ra0 rai0 Jul 4 21:22:25 udhcpc[1965]: broadcasting discover Jul 4 21:22:25 udhcpc[1965]: broadcasting select for 100.115.185.80, server 100.115.128.1 Jul 4 21:22:25 udhcpc[1965]: lease of 100.115.185.80 obtained from 100.115.128.1, lease time 3600 Jul 4 21:22:25 lld2d: Starting LLD2D Jul 4 21:22:26 inetd: Stopping inetd Jul 4 21:22:26 kernel: ASSOC - Assign AID=2 to 5GHz AP 70:bc:10:25:ec:e7 Jul 4 21:22:26 kernel: ASSOC - HT support STA. Update AP OperaionMode=0 , fAnyStationIsLegacy=0, fAnyStation20Only=0, fAnyStationNonGF=1 Jul 4 21:22:26 kernel: ASSOC - VHT support STA Jul 4 21:22:27 inetd: Starting inetd Jul 4 21:22:27 dhcpd: Configure dhcpserver Jul 4 21:22:27 dhcpd: Start dhcpserver Jul 4 21:22:27 udhcpd[3423]: started, v1.34.1 Jul 4 21:22:28 udhcpc: Renew ip adress 100.115.185.80 and netmask 255.255.0.0 for eth3 from dhcp Jul 4 21:22:28 udhcpc: Deleting default route dev eth3 Jul 4 21:22:28 udhcpc: Apply route list. And replace DGW. Jul 4 21:22:28 udhcpc: ip -4 route replace 100.115.128.1/32 via 0.0.0.0 dev eth3 metric 100 Jul 4 21:22:28 udhcpc: ip -4 route replace default via 100.115.128.1 dev eth3 metric 0 Jul 4 21:22:28 udhcpc: Set fist default gateway to 100.115.128.1 dev eth3 via 100.115.128.1 metric 0 Jul 4 21:22:28 udhcpc: Add route to multicast subnet. Jul 4 21:22:28 kernel: br0: port 1(eth2) entered forwarding state Jul 4 21:22:28 udhcpc: Flush route cache Jul 4 21:22:28 udhcpc: Flush conntrack table Jul 4 21:22:28 udhcpc: Renew DNS from dhcp 46.191.224.42 46.191.224.62 Jul 4 21:22:28 udhcpc: Add static route to DNS 46.191.224.42 via 100.115.128.1 dev eth3 Jul 4 21:22:28 udhcpc: Add static route to DNS 46.191.224.62 via 100.115.128.1 dev eth3 Jul 4 21:22:28 udhcpc: Reload DNS server Jul 4 21:22:28 dnsserver: Generate /etc/hosts file. Jul 4 21:22:28 dnsserver: Send HUP to dnsmasq. Jul 4 21:22:28 dnsmasq[1079]: read /etc/hosts - 5 addresses Jul 4 21:22:28 cwmpd: Starting CWMPD with static ACS URL Jul 4 21:22:28 dnsmasq[1079]: using nameserver 46.191.224.42#53 Jul 4 21:22:28 dnsmasq[1079]: using nameserver 46.191.224.62#53 Jul 4 21:22:28 autocwmphelper: Vendor specific option 43 is not null, try helpers for select service and try configure. Jul 4 21:22:28 udhcpc: Restart needed services Jul 4 21:22:28 irqbalance: Start irqbalance routing/wifi optimize mode Jul 4 21:22:28 cwmpd[3797]: Log set filename=stdout Jul 4 21:22:28 cwmpd[3797]: Log set level=INFO Jul 4 21:22:28 cwmpd[3797]: Log started: level=INFO, filename=stdout Jul 4 21:22:28 irqbalance: Start irqbalance auto mode Jul 4 21:22:28 cwmpd[3797]: CONF: write_to_nvram=true, read_from_nvram=true Jul 4 21:22:28 cwmpd[3797]: Log set level=INFO Jul 4 21:22:28 cwmpd[3797]: SSL Initialization... Jul 4 21:22:28 cwmpd[3797]: SSL loading public certificate: /etc/certs/server.pem Jul 4 21:22:29 cwmpd[3797]: SSL loading private key: /etc/certs/server.key Jul 4 21:22:29 cwmpd[3797]: SSL loading trusted CA: /etc/certs/ca.pem Jul 4 21:22:29 cwmpd[3797]: SSL loading DH parameters: /etc/certs/dh Jul 4 21:22:29 cwmpd[3797]: SSL DH parameters loaded. Jul 4 21:22:29 cwmpd[3797]: SSL Initialized. Jul 4 21:22:29 2nd_stage: Copy web pages to tmpfs. Jul 4 21:22:29 kernel: br0: port 2(ra0) entered forwarding state Jul 4 21:22:29 services: Restart needed services and scripts. Mode dhcp Jul 4 21:22:29 QoS: Stopping SHAPER Jul 4 21:22:29 2nd_stage: Start WEB Managment Server. Jul 4 21:22:29 udhcpd[3423]: sending OFFER to 192.168.1.116 Jul 4 21:22:29 QoS: Set default rules. Jul 4 21:22:30 Codel: QoS Add codel for all interfaces. Jul 4 21:22:30 iptables: Add netfiler rules Jul 4 21:22:30 iptables: Allow established/related in input Jul 4 21:22:30 iptables: Drop invalid state connections Jul 4 21:22:30 iptables: Service limit set Jul 4 21:22:30 iptables: Set igmp input rules Jul 4 21:22:30 iptables: DHCP server allow Jul 4 21:22:30 iptables: Dnsproxy allow to connect Jul 4 21:22:30 iptables: allow local port range 32768:61000 from LAN, need for some local service Jul 4 21:22:30 iptables: UPNP allow to connect Jul 4 21:22:30 iptables: Remote managment web limit Jul 4 21:22:30 iptables: CWMP limit to 4 callback connections from WAN. Jul 4 21:22:30 iptables: Remote managment ssh limit Jul 4 21:22:30 iptables: Remote managment telnet limit Jul 4 21:22:30 iptables: Allow rate limited ping from all interfaces. Jul 4 21:22:30 iptables: Set forward rules Jul 4 21:22:30 iptables: Set igmp forward rules Jul 4 21:22:30 iptables: Allow forward from LAN to any Jul 4 21:22:30 iptables: Add SNAT from 192.168.1.1/255.255.255.0 to 100.115.185.80 at eth3. Jul 4 21:22:30 iptables: Add base upnp rules Jul 4 21:22:30 iptables: Run scripts from /etc/iptables.d Jul 4 21:22:30 iptables: Allow established/related in forward Jul 4 21:22:31 dnsserver: Generate /etc/hosts file. Jul 4 21:22:31 dnsserver: Send HUP to dnsmasq. Jul 4 21:22:31 dnsmasq[1079]: read /etc/hosts - 5 addresses Jul 4 21:22:31 dnsmasq[1079]: using nameserver 46.191.224.42#53 Jul 4 21:22:31 dnsmasq[1079]: using nameserver 46.191.224.62#53 Jul 4 21:22:31 ntp: Stopping NTPD Jul 4 21:22:31 udhcpd[3423]: sending OFFER to 192.168.1.30 Jul 4 21:22:31 ntp: Starting NTPD Jul 4 21:22:32 cwmpd[3797]: cpe_refresh_dhcpstatic: empty nvram value dhcpStatic Jul 4 21:22:32 cwmpd[3797]: PortMapping[WAN]: no rules Jul 4 21:22:32 cwmpd[3797]: PortMapping[VPN]: no rules Jul 4 21:22:32 upnpd: Starting UPNP at 100.115.185.80 Jul 4 21:22:32 igmpproxy: Stopping IGMPPROXY Jul 4 21:22:32 kernel: 2.4GHz AP AUTH - receive DE-AUTH(seq-2) from 54:3a:d6:d9:ca:1e, reason=3 Jul 4 21:22:32 igmpproxy: Replace route to multicast subnet via eth3. Jul 4 21:22:33 igmpproxy: Starting IGMPPROXY Jul 4 21:23:13 udhcpd[3423]: sending OFFER to 192.168.1.104 Jul 4 21:23:13 cwmpd: Stopping CWMPD Jul 4 21:23:14 cwmpd: Starting CWMPD with ACS URL from DHCP Jul 4 21:23:14 cwmpd[4945]: Log set filename=stdout Jul 4 21:23:14 cwmpd[4945]: Log set level=INFO Jul 4 21:23:14 cwmpd[4945]: Log started: level=INFO, filename=stdout Jul 4 21:23:14 cwmpd[4945]: CONF: write_to_nvram=true, read_from_nvram=true Jul 4 21:23:14 cwmpd[4945]: Log set level=INFO Jul 4 21:23:14 cwmpd[4945]: SSL Initialization... Jul 4 21:23:14 kernel: br0: port 3(rai0) entered forwarding state Jul 4 21:23:14 cwmpd[4945]: SSL loading public certificate: /etc/certs/server.pem Jul 4 21:23:14 cwmpd[4945]: SSL loading private key: /etc/certs/server.key Jul 4 21:23:14 cwmpd[4945]: SSL loading trusted CA: /etc/certs/ca.pem Jul 4 21:23:14 cwmpd[4945]: SSL loading DH parameters: /etc/certs/dh Jul 4 21:23:14 cwmpd[4945]: SSL DH parameters loaded. Jul 4 21:23:14 cwmpd[4945]: SSL Initialized. Jul 4 21:23:14 irqbalance: Stopping irqbalance Jul 4 21:23:14 kernel: 2.4GHz AP AUTH - receive DE-AUTH(seq-83) from 72:3d:a5:87:04:fb, reason=3 Jul 4 21:23:15 udhcpd[3423]: sending OFFER to 192.168.1.181 Jul 4 21:23:15 udhcpd[3423]: sending ACK to 192.168.1.116 Jul 4 21:23:15 udhcpd[3423]: sending OFFER to 192.168.1.30 Jul 4 21:23:15 udhcpd[3423]: sending ACK to 192.168.1.30 Jul 4 21:23:15 irqbalance: Start irqbalance routing/wifi optimize mode Jul 4 21:23:15 irqbalance: Start irqbalance auto mode Jul 4 21:23:15 kernel: ASSOC - Assign AID=1 to 2.4GHz AP 72:3d:a5:87:04:fb Jul 4 21:23:15 kernel: ASSOC - HT support STA. Update AP OperaionMode=3, fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jul 4 21:23:15 udhcpc: End renew procedure. Jul 4 21:23:16 cwmpd[4945]: cpe_refresh_dhcpstatic: empty nvram value dhcpStatic Jul 4 21:23:16 cwmpd[4945]: PortMapping[WAN]: no rules Jul 4 21:23:16 cwmpd[4945]: PortMapping[VPN]: no rules Jul 4 21:23:17 udhcpd[3423]: sending OFFER to 192.168.1.215 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.30 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.104 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.116 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.30 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.104 Jul 4 21:23:17 udhcpd[3423]: sending OFFER to 192.168.1.215 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.104 Jul 4 21:23:17 udhcpd[3423]: sending ACK to 192.168.1.215 Jul 4 21:23:19 dropbear[5046]: Child connection from 192.168.1.30:60838 Jul 4 21:23:19 dropbear[5046]: Password auth succeeded for 'Admin' from 192.168.1.30:60838 Jul 4 21:23:26 cwmpd[4945]: http session: open (requested=no, evented=yes) Jul 4 21:23:26 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 21:23:26 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999917, send: 14.999907]) Jul 4 21:23:26 dropbear[5046]: Exit (Admin) from <192.168.1.30:60838>: Exited normally Jul 4 21:23:28 get_ieee_oui: Get OUI list from http://update.snr.systems/updates/oui Jul 4 21:23:37 kernel: ReASSOC - Assign AID=2 to 2.4GHz AP 9c:4e:36:28:0c:04 Jul 4 21:23:37 kernel: ReASSOC - HT support STA. Update AP OperaionMode=3, fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jul 4 21:23:38 fwupdate[5066]: You are using the latest firmware version. Jul 4 21:23:41 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 21:23:41 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 21:23:41 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 21:23:48 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 21:23:48 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999967, send: 14.999957]) Jul 4 21:23:57 kernel: ASSOC - Assign AID=4 to 2.4GHz AP 54:3a:d6:d9:ca:1e Jul 4 21:23:57 kernel: ASSOC - HT support STA. Update AP OperaionMode=3, fAnyStationIsLegacy=0, fAnyStation20Only=1, fAnyStationNonGF=1 Jul 4 21:23:57 udhcpd[3423]: sending OFFER to 192.168.1.181 Jul 4 21:23:57 udhcpd[3423]: sending ACK to 192.168.1.181 Jul 4 21:24:03 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 21:24:03 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 21:24:03 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 21:24:14 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 21:24:14 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999962]) Jul 4 21:24:29 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 21:24:29 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 21:24:29 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 21:24:42 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 21:24:42 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999970, send: 14.999961]) Jul 4 21:24:57 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 21:24:57 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 21:24:57 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 21:25:07 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 21:25:07 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999961]) Jul 4 21:25:22 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 21:25:22 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 21:25:22 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 21:25:35 cwmpd[4945]: http session: close Jul 4 21:25:43 fwupdate[5071]: You are using the latest firmware version. Jul 4 21:52:51 udhcpc[5044]: sending renew to server 100.115.128.1 Jul 4 21:52:52 udhcpc[5044]: lease of 100.115.185.80 obtained from 100.115.128.1, lease time 3600 Jul 4 21:52:54 autocwmphelper: Vendor specific option 43 is not null, try helpers for select service and try configure. Jul 4 22:11:29 cwmpd[4945]: http session: open (requested=no, evented=no) Jul 4 22:11:29 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 22:11:29 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999962]) Jul 4 22:11:44 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 22:11:44 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 22:11:44 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 22:11:51 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 22:11:51 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999962]) Jul 4 22:12:06 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 22:12:06 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 22:12:06 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 22:12:13 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 22:12:13 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999962]) Jul 4 22:12:28 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 22:12:28 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 22:12:28 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 22:12:33 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 22:12:33 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999972, send: 14.999962]) Jul 4 22:12:48 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 22:12:48 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 22:12:48 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 22:13:21 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 22:13:21 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999972, send: 14.999963]) Jul 4 22:13:36 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 22:13:36 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 22:13:36 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 22:13:48 cwmpd[4945]: http session: close Jul 4 22:22:54 udhcpc[5044]: sending renew to server 100.115.128.1 Jul 4 22:22:54 udhcpc[5044]: lease of 100.115.185.80 obtained from 100.115.128.1, lease time 3600 Jul 4 22:22:56 autocwmphelper: Vendor specific option 43 is not null, try helpers for select service and try configure. Jul 4 22:47:22 fwupdate[5377]: You are using the latest firmware version. Jul 4 22:52:42 kernel: ASSOC - Assign AID=3 to 5GHz AP 90:6a:eb:89:f4:d0 Jul 4 22:52:42 kernel: ASSOC - HT support STA. Update AP OperaionMode=0 , fAnyStationIsLegacy=0, fAnyStation20Only=0, fAnyStationNonGF=1 Jul 4 22:52:42 kernel: ASSOC - VHT support STA Jul 4 22:52:44 udhcpd[3423]: sending OFFER to 192.168.1.125 Jul 4 22:52:44 udhcpd[3423]: sending ACK to 192.168.1.125 Jul 4 22:52:56 udhcpc[5044]: sending renew to server 100.115.128.1 Jul 4 22:52:56 udhcpc[5044]: lease of 100.115.185.80 obtained from 100.115.128.1, lease time 3600 Jul 4 22:52:59 autocwmphelper: Vendor specific option 43 is not null, try helpers for select service and try configure. Jul 4 23:11:30 cwmpd[4945]: http session: open (requested=no, evented=no) Jul 4 23:11:30 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 23:11:30 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999937, send: 14.999927]) Jul 4 23:11:45 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 23:11:45 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 23:11:45 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 23:11:51 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 23:11:51 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999962]) Jul 4 23:12:06 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 23:12:06 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 23:12:06 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 23:12:18 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 23:12:18 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999932, send: 14.999916]) Jul 4 23:12:33 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 23:12:33 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 23:12:33 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 23:12:54 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 23:12:54 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999962]) Jul 4 23:13:09 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 23:13:09 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 23:13:09 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 23:13:37 cwmpd[4945]: resolving destination 92.50.143.180:80 Jul 4 23:13:37 cwmpd[4945]: connecting to address: 92.50.143.180:80 (1/1, timeouts=[recv: 14.999971, send: 14.999961]) Jul 4 23:13:52 cwmpd[4945]: connect(): timeout reached, value=15 Jul 4 23:13:52 cwmpd[4945]: connect to ACS faild. Host is 92.50.143.180:80. Jul 4 23:13:52 cwmpd[4945]: http session: connect to acs: http://92.50.143.180/tr069/server.php failed. Jul 4 23:13:57 cwmpd[4945]: http session: close Jul 4 23:22:58 udhcpc[5044]: sending renew to server 100.115.128.1 Jul 4 23:22:58 udhcpc[5044]: lease of 100.115.185.80 obtained from 100.115.128.1, lease time 3600 Jul 4 23:23:00 autocwmphelper: Vendor specific option 43 is not null, try helpers for select service and try configure. Вставить ник Quote
